Results 1 to 7 of 7
    Feb 27 2013
    Twin turbo 350Z, Mercedes ML350, Audi Q3 and BMW 535i M sport
    New York
    Brake Upgrade Options For The Q3?
    Hey Guys,
    I was curious after doing the S4 brake upgrade on my B7 A4 and sport brake conversion on my ML350 if there was a option for the 2015 Q3? Like can we fit the S3 brakes or Q5 brakes on the Q3? With my A4 the difference with the S4 was the larger rotor and the caliper bracket to accommodate the larger rotor and the same for my ML350. Here are some pics of the upgrade i did on those.
    B7 A4, 6MT, Quattro - Sliver (Sold)
    JHM HPFP upgrade, JHM Test Pipe, JHM Y pipe, B7 S4 exhaust, JHM flywheel and RS4 clutch, GFB DV+, P3 boost gauge, S4 front & Rear brake upgrade, 034 rear sway bar, ST Coilovers, K&N filter, ECS Oil catch can, JHM K04-R Turbo Kit.
    Audi Q3 8U-White
    https://www.youtube.com/channel/UCWU...e_polymer=true
    Feb 27 2013
    New York
    I did see some one said that the MK6 Golf R brakes would fit so that might be an option and they look just like my B7 S4 calipers.
    Audi Q3 8U-White
    Feb 27 2013
    New York
    I do see that ECS sell an adapter bracket to run the Porsche 986/987 calipers on the A3/MK6 models and it looks like the stock Q3 size rotors would work with them but cant get a confirmation from ECS. I might just buy them and test fit it and see if it would work. You can find use 986 calipers pretty cheap so it might be worth the risk.
    Audi Q3 8U-White
    Jul 14 2009
    Pasadena
    i had a set of rs3/ttrs brakes front and rear that I was going to slap onto the q3. they are the same as rsq3 brakes. i would go that route.
    IG: @matthewee
    Feb 27 2013
    New York
    Quote Originally Posted by itsmatt33 View Post
    oh wow that's kool do you have any pics of the install if you did it? I would think that would be really expensive, If my idea works the whole setup would be around 700-800 dollars maybe less.
    Audi Q3 8U-White
    Feb 27 2013
    New York
    I think I have decided to go with the Porsche Macan base calipers which are 4 piston. I ordered one of the calipers from Porsche to test fit.
    Audi Q3 8U-White
    Mar 29 2021
    Ontario, Canada
    Did you end up doing this? If so how did it turn out?
