Need help, I bought this car last September for $3500 with 120k miles. I have put 10k miles on it have dumped 2k in at this point. It was running real good until late may of this year and then its been problem after problem, some I think the shop I had working on it created. Now I have the ABR and brake light coming intermittently and it causes the speedometer to go out since there tied together.
The shop I had working on it thought it was the speed sensor so they changed it out and $300 later that was not the problem. They quoted me $2700 for a new ABR module not including labor, they stated thats how much the dealership sells it to them for. It just seems after almost 9 months of no issues once they made the first repair changing the crankshaft sensor, its been downhill with other issues heater hoses, crankshaft sensor, coolant sensor etc. There a good shop for my other non foreign cars but struggle with this one.
I talked to the only foreign car shop locally and they wanted a couple hundred to pull the ABR to get the part number and said they would not send it out to get rebuilt but would put a new one in. What concerned me he stated Audi's at that mileage typically have the turbos go out. Any truth to that?
What does everyone recommend, is rebuilding the ABR a bad move? I don't want to spend 2k plus to try and fix the ABR for a car this old especially at the rate I'm going with repairs. Can I get this repair done for under 1k?
Also had the check engine light go off again yesterday with the code P0507 air control system, but it ended up going away by the end of the day.
