He is my fix.....
I bought some stainless M6
weld nuts from McMaster Carr. P#98697A63
I think there were $17 for a ten pack.
Then I removed the plate backer with a T-25 torx bit. I wasn’t able to get floss under it to cut the double sided tape, so I just used a plastic trim tool to pry it away enough so I could gently pull it off. From the back side of the plate backer I used 2 part epoxy to attached the weld nut and then used the plate and 6mm bolts to hold it in place till it dries.
After it dries I will use the proper length bolt so it doesn’t impact the trunk lid behind it. Should work nicely. So if somebody is looking for a repair across all model lines this might be the one.
Powered by iPhone using Tapatalk
