Results 1 to 40 of 52
    Aug 19 2020
    On the globe
    3.0TFSI tuning/upgrade
    Hi
    What are your expirences with tuning the 3.0 TFSI (CAJA) with Triptronis and Quattro drive?
    Im thinking no parts exchanged just reprogramed ECU.
    Seems to be adding about 100hp and 50Nm torqe with most tuners.
    How would the transmission corb with the tuning? how about the engine?
    And will I get fuel effincy in crusing area?
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    Welcome to AZ and the C6 forum. If you do a search, you will find quite a few posts about tuning the C6 platform. I myself went with EPL and find those guys to be the gold standard for tuning this motor.
    I don’t know how much HP and TQ is added but it is significant (even better with a few gallons of E85) with just a simple stage 1 tune.
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    Most people run a reflash with little to zero issues, aside from a little more oil consumption, probably because of increased cylinder pressure.
    Transmission holds up well, even though online you'll find mixed number on the 6HP19A's max torque rating depending on application.
    Sent from my PH-1 using Audizine mobile app
    Established Member Two Rings pewpewprince's Avatar
    Nov 14 2018
    DC
    Quote Originally Posted by Tobisen View Post
    Hi
    This is how A6 C6 can move vs Audi S4 Integrated Engineering dual pulley ultracharged with full bolt on's
    Audi A6 C6 2011 3.0tfsi turbo'ed with gtx3076r
    Mar 07 2018
    Utah
    Quote Originally Posted by pewpewprince View Post
    Lordy, what's that? Is that an upgraded throttle body on the A6?
    Nov 14 2018
    DC
    Quote Originally Posted by a1dan_87 View Post
    57/196 pulleys, gutted cats, guttes stock airbox, ecs pipe, kn s5 filter, 7100 redline on 93 oct. Stock cooling. 510hp. 60-130mph in 10.5 sec
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    https://jhmotorsports.com/auxiliary-...6-a6-3-0t.html
    Nov 14 2018
    DC
    Aug 19 2020
    On the globe
    Nice set!
    Active Member Two Rings jnaarnold's Avatar
    Feb 22 2017
    2011 Range Rover HSE Sport Lux, 2005 Yukon XL
    Triad, NC
    When you say ECS pipe...are you talking about the x-pipe they sell to replace the suitcase muffler?
    2015 Audi A6
    2011 Land Rover Range Rover HSE Sport LUX
    2005 Yukon XL
    2001.5 Audi S4 AWE Stage 3 456hp
    Instagram: @three_dot_knives
    Aug 31 2011
    Lathrop
    Try again? the link is working for me
    Nov 14 2018
    DC
    Quote Originally Posted by jnaarnold View Post
    This one
    U have to cut an inch from box side to fit it.
    Nov 14 2018
    DC
    iam not from usa, so i cant see whats going on :)
    Nov 14 2018
    DC
    Another run vs 2020 Audi RS5 450hp 30-160mph
    he floored a bit earlier, but i still got him
    Mar 07 2018
    Utah
    Do they offer a 3.0t test pipe/"downpipe"? I can't remember who does, but they specify it fits everything except the C6 3.0t. wonder if it'd fit our car
    Aug 19 2020
    On the globe
    Du you change gas or do you still run on 95oct with stage 1 ECU flash?
    What about the transmission would I gain anything from tuning the TCU?
    Jul 03 2020
    Michigan
    Most tuners offer a 91 and a 93 octane map. I have mine tuned for 93 since it's readily available where I'm at. There are no shops in the US that offer a tune for the ZF6 trans, although there is a tune available in europe from what I've heard around here. The main downsides of this transmission is its inability to hold revs and its slow shift times. It's a fairly reliable trans and I haven't heard of anyone blowing the torque converter. Even with the lack of a tcu tune, I've had a blast with just an EPL stage 1 tune, and I run 93 all the time with a couple gallons of e85 every few fill ups.
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    Quote Originally Posted by picubed View Post
    JHM is developing a TCU tune that can be flashed from home
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Aug 19 2020
    On the globe
    What Airfilter fits the 3.0 Tfsi? The only one I can find is a foam filter from Pipercross.
    The filter looks like it´s the same as for the 2.8Fsi
    Im looking for a replacement in the stock filterbox
    Jan 04 2017
    El Monte/CA/United States
    I used afe pro dry S oil free
    part# 11-10125
    There is also an oiled version to
    Mar 07 2018
    Utah
    Quote Originally Posted by Ynnekdude View Post
    Wait, their TCU tune can be flashed from home? 0-0
    Dec 10 2008
    Chicago
    Yep, using the new JHM flashing cable. Very straightforward and quick process though the OBD.
    Aug 19 2020
    On the globe
    What benefits this inlet tube?
    And where can I get it if needed?
    This one
    Sent from my ELE-L29 using Audizine mobile app
    Aug 19 2020
    On the globe
    Besides from the added oil consumption what are little issues?
    Mar 07 2018
    Utah
    As a direct result of the tune? None that come to mind. These engines handle the extra power pretty well. The S4 application can handle 500+ horsepower, and I haven't heard of any transmission issues popping up unlike the 7DCT in the S4.
    Aug 19 2020
    On the globe
    Got this filter today from Ebay.
    Still considering the ECU flashing...
    Aug 19 2020
    On the globe
    Does anyone know if the inlet hose is the same on the A6 3.0tfsi as for S4 and S5?
    It looks the same on pictures.
    Found this one in silicone but seller doesn't know if it fits the A6...
    https://www.ebay.co.uk/itm/264640525433Screenshot_20201010_235419_com.ebay.mobile.jpg
    Sent from my ELE-L29 using Audizine Forum mobile app
    Dec 31 2018
    Chevy Chase MD
    Yeah for 3.0T it is the same. That will fit.
    Dec 10 2008
    Chicago
    Quote Originally Posted by DC Dawg View Post
    I don't believe that's correct. It likely will not fit without modification, unfortunately. While it may mate with the TB, it won't line up properly with the stock airbox.
    JHM is releasing a silicone pipe for the A6 soon. I'd recommend waiting on that, OP.
    Apr 16 2019
    Sweden
    I have that one in my A6C6 3,0 Tfsi. It's not at direct fit. I had to trim it down a bit. Close to 2 inch on the filterside and maybe half inch on engine side.
    Aug 19 2020
    On the globe
    Quote Originally Posted by BomberViking View Post
    That's a hand on experience!
    Good to hear!
    What benefits did you get?
    In the stock one I believe is resonated so I think there will be more engine growl from the intake?
    Apr 16 2019
    Sweden
    Good to hear!
    Just a little bit more growl (still on stock filter). And it looks way better! :)
    Aug 19 2020
    On the globe
    By the way
    Can the SC pulley be removed/changed with these tools without putting the front in service mode? 10913611441097160394.jpg
    Aug 31 2011
    Lathrop
    Our Silicone Throttle Body Hose will be available shortly. It is a direct fit, no modification and provides a nice smooth transition with no obstruction of flow.
    Aug 19 2020
    On the globe
    Quote Originally Posted by Jake@JHM View Post
    I can wait but you ship out from the states right?
    Our Danish postal service take more than $25 in fee just to let me pay the tax
    Aug 31 2011
    Lathrop
    Yes. We ship from California
    Aug 19 2020
    On the globe
    So I had the car at the dyno today.
    I have upgraded the SC pulley to 57mm
    Changed the air filter to a Green filter in the stock filter box. I have taken out the damping material inside the box.
    I have upgradet the intake hose and modified one from a S5 model.
    The car is tuned to run RON 95 which is the most common gas here in Europe.
    The output was:
    411Hp and 524Nm
    I also had the transmission tuned to higer clutch pressure and had the torque limitations raised and the speed limit removed.
    I think he may have improved the shifting time as well but I forgot to ask.
    I also asked to make the afr slightly leaner at cruising to improve the fuel economy.
    Total budget all inclusive close to $1000
    I'm satisfied
    Only thing I could have wished for was a dyno roll before I walnutblasted the inlet and after with the stock pulley.
    I could feel the difference after the blasting and I could also feel the difference after changing the pulley but I have no dyno proof... Not that it matters but it would have been nice though! IMG_20201028_145448.jpgIMG_20201028_145054.jpgIMG_20201020_171000.jpgIMG_20201016_162148.jpgIMG_20200908_172645.jpg
    Senior Member Two Rings 11A6's Avatar
    Jan 04 2018
    Maine
    Nice work on the intake hose - might need to do that myself or see how much longer til JHM's is available. I know you posted one DIY but did you happen to shoot any pics/videos of the steps to take and put back on the supercharger ie how you drained coolant etc. If you used an existing video can you share a link to it?
    2011 A6 Avant Prestige w/CWP 1/20
    Aug 31 2011
    Lathrop
    Quote Originally Posted by 11A6 View Post
    Should be live in a week or so if everything goes as planned
    Aug 19 2020
    On the globe
    I have made a video of how to pull the pulley without removing or putting the front in service mode.
    Sorry for not showing the final installation. I got quite frustrated as I was to slow bringing it from the oven to the car so the last attempt with success was not recorded...
    https://youtu.be/dCCX4QOzsC4
