    Senior Member Three Rings FlyingGuy's Avatar
    May 23 2008
    Angry Code help... "02 sensor response too slow"?
    so, installed DP with the J o2 spacers, middle size restrictor.
    Now i expected an efficiency code... never got it. I did however get two codes that I cant find much info about:
    P013B oxygen sensor B1 S2: Response too slow Lean to Rich
    P013D oxygen sensor B2 S2: Response too slow Lean to Rich
    now, with little info ive found, its conflicting and uncertain. Some say its o2 sensor issue, some say its due to the o2 sensor spacers. The spacer issue would make sense, as its a "response" code, but i dont know if that actually makes sense.
    Cleared codes multiple times, always come back. I have a larger and smaller diameter restrictor to try, but not sure which to try, given the code. If it was purely an efficiency code, id go to the smaller one. But the way this code reads, a quicker response time is needed, so maybe the bigger diameter is better?
    Any thoughts are appreciated.
    -Currently shopping for my next toy-
    15 RS7 - DS1 stage 1 & downpipes (Wife's Daily)
    14 991.1 GT3 - Headers & Exhaust (sold)
    14 V10 R8 - Tune & Exhaust (sold)
    01 996 Turbo - Go-Fast mods (sold)
    02 B5 S4 - Nogaro stage 3 (sold)
    02 VW GTi - 24v VR6 - (Dead)
    Mar 30 2018
    long island
    id suggest a large diameter spacer.
    those codes are due to the limited exhaust flow reaching the sensor.
    you need to find the "sweet spot" of the proper restrictor.....allowing enough exhaust to reach the sensor, but not enough to trigger the CEL for lack of efficient cats.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    May 23 2008
    Quote Originally Posted by daytona rs7 View Post
    Thanks. So this code means it needs more flow?
    Sep 04 2011
    Central NJ
    I had similar codes after I had downpipes with spacers installed and it turned out to be switched connectors on the rear O2 sensors. Since OEM downpipes cross and APR downpipes don't, the installer forgot to flip the connectors. There is a test in VCDS to check this. Here is a link to my older post for more detail.
    https://www.audizine.com/forum/showt...highlight=rich
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    May 23 2008
    Quote Originally Posted by hmuller View Post
    thanks.
    Not sure i understand what error shows that the sensors are swapped or not...? your post #8 diag readout in that thread... im not sure what im looking at.
