Results 1 to 23 of 23
    Jul 24 2020
    holland
    installing seal cam's adjustment magnet
    looks like the seal of the cam's adjustment magnet is leaking some oil. so i want to replace this seal (06H-103-483-D) and the o-ring inside :WHT-007-212-B
    my question is if i can just take out the 3 bolts of the adjustment magnet, take the adjustment magnet out and put a new seal in or do i have to take off the complete upper timing cover to be able to put a new seal in ?
    this thread was very informative but couldn't find out if possible without taking off the timing cover:
    https://www.audizine.com/forum/showt...oil-leak-FIXED
    and does anyone know the torque specs of the 3 bolt on the cam's adjustment magnet ?
    thanks
    arthur
    Jul 16 2018
    Atlanta
    You can replace them with the timing cover still installed. That's what I did. I believe I had to at least loosen the bolt further down the oil dipstick also, iirc. Torque spec is 9 Nm.
    Jul 24 2020
    holland
    thanks Smac770 , i am gonna order the 2 seals and fix the leak
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Quote Originally Posted by Smac770 View Post
    Accurate.
    Sent from my SM-N976V using Tapatalk
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    If you don't have the magnet with the black plastic cover on it, its actually the magnet itself that will leak.
    Jul 24 2020
    holland
    Quote Originally Posted by Spawne32 View Post
    it already crossed my mind although i didn't notice oil on the metal part of magnet , just under the edge of it where the seal sits but i will surely check the magnet when taking it off.
    i assume i still have the old magnet version without the plastic cover:
    Nov 20 2016
    Quote Originally Posted by audi-art View Post
    https://live.staticflickr.com/65535/...f61092dd_c.jpg
    Yeh that's an original design. ECS sells some Febi camshaft adjuster magnets for pretty cheap. Some are sold with a connector some without. Word on the street is that the connector design changed with the new revisions but mine plugged right in and my car is an 09, so I don't forsee any issues.
    Jul 24 2020
    holland
    .... ECS sells some Febi camshaft adjuster magnets for pretty cheap. Some are sold with a connector some without. Word on the street is that the connector design changed with the new revisions but mine plugged right in and my car is an 09, so I don't forsee any issues.
    is it in this case not important to get an original oem audi part from dealer as with the pcv valve........so a febi or whatever aftermarket brand is fine ?
    Nov 20 2016
    Perfectly fine. Not entirely sure who the OEM mfg is of that part anyway, but case in point, I ordered a standard motor products ignition switch, and out of the box was an OEM audi switch.
    Jul 16 2018
    Atlanta
    The metal one is fine; the gaps between the cover plate and the actual solenoid device won't leak if the two seals are correctly installed. Keep in mind that inner o-ring is replace if the N205 is removed. Audi isn't kidding with that; is why I had to go back in and replace it when I didn't the first time. Then again, being 10 years old might have played a part too. :-)
    Nov 20 2016
    Well 10 years later, its not an oring its a plastic circle. :p
    Jul 08 2022
    London
    Do these cam adjustment seals come out easily with the upper timing cover still in place? - just wandering if they pop in easily with the cover intact?
    I need to change my seals as I can see a small leak from the screws of the cam magnets weeping through.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by akz786 View Post
    Easy.. even removing the she co dr is easy if you need to 10mm socket.
    There is a seal and an o ring. Get both.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 08 2022
    London
    Thanks - mine is actually for a Audi A3 8V, I think its all relatively similar but I could not find anyone from the A3 community who has tried to change these seals by just removing the cam magnets - also the o-ring you mention - what is that for?
    Feb 15 2016
    Cambridge,Ontario
    The oring goes around the magnet and stops you losing oil/pressure around the magnet in the cam bridge
    The gasket stops oil leaks out of the cover.
    1976 Yamaha XS 360
    Senior Member Two Rings tomsgtr's Avatar
    Aug 06 2013
    San Jose, CA
    There's three seals. 1 Big gasket for the timing cover, One Circle gasket that has a slight taper that goes around the cam bridge, and one O-Ring inside the cam bridge where the electrical actuator slides into. You have to remove the timing cover which is not a big deal. It think it's like 5-6 bolts, the dipstick, and the cam actuator.
    B8.5 A4 BOSS500 , B8.5 S4 DP+
    Feb 15 2016
    Cambridge,Ontario
    You don't have to remove the whole cover if it's just leaking from n205. But likely it's leaking from everywhere as that big gasket turns to plastic with time and heat.
    1976 Yamaha XS 360
    Jul 08 2022
    London
    Thanks for all the replies guys - great information - will try the cam seals first and see if that solves the issue.
    Established Member Two Rings Ejr's Avatar
    Mar 24 2021
    Duluth, GA
    What torque wrench did you use that fitted between that small gap?
    Mar 24 2021
    Duluth, GA
    Was it in fact the adjuster seal and leak was solved? At least for the frontal leak.
    Jul 16 2018
    Atlanta
    Quote Originally Posted by Ejr View Post
    https://www.tekton.com/1-4-inch-driv...rench-trq21101
    That's the small one I picked up a few years ago. Been very useful for various low torque fasteners on the car.
    Mar 24 2021
    Duluth, GA
    I appreciate the link!
    Have you had Electronic Parking Brake malfunction light together with ESP faulty but the EPB works except for the autorelease feature and solved it?
    Please check out my reply which is the last comment on this thread;
    help with epb faults.....but epb works
    https://www.audizine.com/forum/showthread.php?t=721049
    Jul 16 2018
    Atlanta
    I've never had an EPB problem. Whenever I get the ESP+EPB lights on the instrument cluster, it means I forgot to plug the MAF back in. No, really. Leave the MAF unplugged, and you get stupid unrelated issues like that. Who knows.
