Originally Posted by
sj9ninety
Only 45k miles on the struts :(, however, the thought did cross my mind.
My lowering springs are brand new though lol...
Audizine
Yeah, that's painful then. I'd say you will probably have to replace the strut regardless tho, the threads are probably messed up on it already at this point.
Chaoscreature
What you do on your own car is your decision, but I wouldn't drive too much with a stripped strut nut.
If the nut is spinning on the stud, then either the male or the female threads are pretty much gone, which means there is not much material holding your strut to the chassis.
The good news is the nuts is normally not loaded since the weight of the car holds the strut in place, BUT if you were to hit a bump or pot-hole large enough to fully extend the strut, it could come loose on you and your entire front wheel/strut assembly could fall out/off.
How did you strip the nut BTW? Impact gun?
I had both sides come loose on me after I installed the Euro Sport Camber Inserts. I had hand threaded them then used a impact to try and tighten them since the shaft kept spinning. They made quite a racket going over bumps/speed bumps/potholes when they loosened up.
I had a real hard time getting them torqued enough because I have adjustable struts and nothing to grip and hold up top while trying to torque them. I ended up using a piece of heater hose and channel locks on the shaft of the strut, as far up as I could. Was quite scary hoping to not mar the shaft, but I was finally able to get them to the correct torque.
I think if it is going to loosen up you'll know it before it comes completely apart by the noises you'll get. But I too would recommend fixing the issue sooner than later, just so you don't have some sort of catastrophic failure.
