Had to pull off front end and swung a/c condenser off to side only because I was pulling engine/trans. But doing the TB was so much easier because you can literally do it sitting down.
However, in order to pull off front end you have to disconnect coolant hoses and I always wrestle w/ the passenger lower radiator hose for at least 15min before it finally comes out.
If you stick w/ service position, get a telescopic mirror and mind this bolt. Almost stripped it thinking it was hex.
Good luck!
Sent from my iPhone using
Audizine
