Results 1 to 14 of 14
    May 13 2015
    United States
    Anyone try the Raybestos DSG clutch packs?
    I'm getting clutch slip on my DP S4. Looks like Audi sell complete clutch pack, but i was wondering if anyone has tried the Raybestos clutch pack? It would save $900, but I've researched online and couldn't find any reviews on them.
    2011 Audi S4 DSG JHM HD Overdrive 179mm/EPL 57mm | AWE Tuning Audi S-FLO | Intake EPL 93 Stage 2 + TCU tune | ECS full drivetrain insert kit | 034 Street Density Motor Mounts
    Established Member Three Rings shortyolsen2017's Avatar
    Jul 31 2019
    2013 Audi S5 Premium Plus stage 3+, and 04 Ranger Edge Tremor
    Denver, Colorado
    Quote Originally Posted by FastAudiS4 View Post
    Looks like $180 for discs and plates. The quality doesnt look bad either.
    New clutch kits, complete baskets start about $500 and go up to $5k.
    https://www.raybestospowertrain.com/...ts-of-interest
    https://images.app.goo.gl/iEpPvDfPVmbM61et8
    I'll be doing mine over the winter but going with performance clutch kit for added durability and extra clutch discs.
    Sent from my SM-N960U1 using Tapatalk
    May 13 2015
    United States
    Quote Originally Posted by shortyolsen2017 View Post
    Yes, they look good I just saw on eBay for the price you just said. The OEM replacement is $1400. So it would save $1220. I just don't want them to go out and have to have the work done twice. I'm dual pulley and will get autotechs and lpfp shortly.
    Jul 31 2019
    Denver, Colorado
    I'm aiming for 3.5-3.6 pulley ratio, dual pulley can mean alot (APR DP is only 3.238) for example and I will be stepping up the stock clutches, stock clutches are for stock cars.
    I agree price sucks but honestly I'd say find the best deal on some performance ones its your safest bet and they will live longer under the abuse.
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    I've put them in, need both steels and friction plates, seem to be okay. Are you sure you are not getting clutch slip because of the ecu tune not reporting torque to the trans correctly? Some stage 2 tunes overcome trans torque restrictions by reporting lower torque on the CAN. Which clutch is slipping, odd or even gears? How many miles do you have total and how many are with tunes? Depending on the mileage and other factors, steels/friction plates might not be enough. Can have worn clutch piston(s) or your front clutch cover bearing seat can be broken. If it's broken, the clutch will wobble slightly in the oil pump and you'll lose the oil pressure and slip anyway. Also, if your clutch drum is discolored from heat, you need a new one.
    May 13 2015
    United States
    No it's not tune related. Audi mechanic looked at it.
    Sent from my SM-G960U using Tapatalk
    Apr 23 2019
    CA
    Did he look at the car or the clutch itself? Imo, if you are having somebody do it for you, not worth the trouble skipping on complete clutch replacement. But do have them take a look at the dmf and front clutch cover, if the bearing for the input shaft has some play (slightly loose I should say) then replace that cover, too.
    May 05 2018
    South Florida
    We share the dl501 with the S6 which makes more stock hp and tq, even more when tuned. These “stock clutches” can take abuse.
    Apr 23 2019
    CA
    Quote Originally Posted by killer_s4 View Post
    Half true. Stock s6/s7 clutch pn is different, and it has one more friction and steel plate in either odd or even packs or both, don't remember. But agree that stock clutch should take some abuse for some time.
    Senior Member Three Rings usmcfieldmp's Avatar
    May 04 2020
    Fort Worth, TX
    Is there a DIY tutorial or how-to on replacing the clutch packs?
    I'm having weird delays/slips in my upper gear shifts at WOT and want to be prepared. I've Googled a bit but haven't found anything too specific.
    2002 Audi TT Quattro || Entering Racecar Status | Needs a LOT of love || Project Thread
    2013 Audi S5 || TOTALED ||
    || 1986 Volkswagen GTI || 1997 Dodge Viper GTS || 2005 Chevrolet Cobalt SS ||
    May 13 2015
    United States
    You can swap the whole clutch pack unit. That's the only way Audi sells it and ECS carries it, but you may have other problems. It's like $1450 though. After taking to a reputable local shop they recommended replacing other parts as well. There's a YouTube video from Raybestos though that shows them disassembling the clutch pack and then explaining replacing the clutches and steel plates.
    Jul 31 2019
    Denver, Colorado
    Quote Originally Posted by usmcfieldmp View Post
    https://youtu.be/OB4sKKOqqAQ
    https://youtu.be/0C5bUKBtFyI
    https://youtu.be/G5OBQvI2A0E
    May 04 2020
    Fort Worth, TX
    If I did it, I'd likely want to upgrade the disks, but I guess a new OEM unit honestly wouldn't be bad, just more expensive. I'll have to look up that Raybestos video.
    I've watched the two "professional" videos previously - they didn't disassemble the clutch pack to replace disks in the DL501 video, and I wasn't sure how similar it would be to the transverse units.
    May 13 2015
    United States
    https://youtu.be/oeTrxEirH0Y
