Results 1 to 18 of 18
    Veteran Member Three Rings rkern's Avatar
    Jul 26 2012
    93 Corrado VR6
    SoMD
    Upper Oil Pan Replacement
    Need to replace upper pan. Any tips or tricks? Been reading a few things and I know engine needs supporting in order to drop subframe. Looking for other tips.
    01.5 S4 Avant Imola Yellow Stg 3
    93 Corrado VR6 3.0L
    Established Member Two Rings McFlyy256's Avatar
    Feb 17 2019
    Huntsville, AL
    It will be easier if the pull the engine
    Jul 26 2012
    93 Corrado VR6
    SoMD
    I see people say that but it doesn’t seem much different with it in car.
    93 Corrado VR6 3.0L
    Veteran Member Three Rings harryn's Avatar
    Dec 03 2016
    2021 Audi A4, 2000 Audi S4, 1995 BMW M3
    Quote Originally Posted by rkern View Post
    The transmission being separated from the block will make the job much easier than with it in the car and attached to the block.
    It's all about your tenacity on how you want to get it done. There's no real wrong way to do it, just a way and a long way. 🙂
    Jul 26 2012
    93 Corrado VR6
    SoMD
    I have the front end apart. I’ll see how it with it in the car and if it becomes a bear then I’m almost at the point of pulling the motor.
    93 Corrado VR6 3.0L
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Why would the trans being separated help that much. I don really see it being in the way
    Only hard part I see doing it in car is getting the block surface nice and clean
    Jul 26 2012
    93 Corrado VR6
    SoMD
    Right now I've gotten the car to the point of pulling the motor. I just have to loosen the subframe bolts and pull it out. I'll probably separate the trans from the motor when out to make it easier to work around underneath it. There is no sealant where it seats up to the trans or at least that's the way it looks. I have another pan arriving on Thursday so that will give me something to do this weekend. I bought a metal wheel for the drill to clean the block down with.
    93 Corrado VR6 3.0L
    Feb 17 2019
    Huntsville, AL
    Also when install the lower oil pan go to your local parts store and buy a gasket for a A4 with a 2.8 it will fit the 2.7 so u don’t have to use the sealant
    Jul 26 2012
    93 Corrado VR6
    SoMD
    Quote Originally Posted by McFlyy256 View Post
    A4 2.8 upper oil pan will work? That's great to know, I would hate to go through all this and then it leaks.
    93 Corrado VR6 3.0L
    Jul 26 2012
    93 Corrado VR6
    SoMD
    NVM, lower pan.
    93 Corrado VR6 3.0L
    Feb 17 2019
    Huntsville, AL
    No the upper will not work
    Jul 26 2012
    93 Corrado VR6
    SoMD
    Removed old pan and installed new. Hope I have enough sealant on so that it doesn’t leak.
    93 Corrado VR6 3.0L
    Dec 03 2016
    Why did you use the red RTV sealant? I was told the red RTV sealant is the wrong one to use and to ONLY use the black sealant because it is an oil repellent, while the red stuff is oil absorbent. Here is what I was told to use:
    https://www.amazon.com/Permatex-8522...7751190&sr=8-5
    Jul 26 2012
    93 Corrado VR6
    SoMD
    I used Dirko HT which is a high temp gasket maker.
    93 Corrado VR6 3.0L
    Jul 26 2012
    93 Corrado VR6
    SoMD
    I used Dirko gray sealant on the lower pan before and had no issues. This time I used a gasket.
    https://gzhls.at/blob/ldb/9/b/4/f/f2...2bd461e42b.pdf
    93 Corrado VR6 3.0L
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    +1 for Dirko HT, that's what I have for all my sealing needs. Even used it to seal the case on my '01 Corvette Z06 transmission when I rebuilt it.
    2001 Corvette (C5) Z06
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Just use Silicone-based RTV sealant and you're good to go. Color doesn't matter. Dirko is good stuff, doesn't have to be the HT variety.
    OP your squeeze-out looks pretty good in the photos, just make sure you don't overdo it along the inner part of the flange to where pieces come free in the pan.
    Jul 26 2012
    93 Corrado VR6
    SoMD
    Quote Originally Posted by PwrWgn View Post
    I did check the inside after it had dried before I placed the lower pan. It looked to be the same as it was factory, we will see.
    93 Corrado VR6 3.0L
