Results 1 to 11 of 11
    New Member One Ring
    Aug 09 2020
    SA
    Angry TONS of error codes
    I really love this car, but recently got all these codes, some of them were old like Intake manifold stuck open but most of the codes are new and now im stuck on what to do?
    I dont want to pay tons of money but I also really wanna drive this car, any advice would be really appreciated.
    Thanks
    Car: Audi S6
    Year: 2013
    Body type: Saloon
    Engine: CEUC 309 kW (420 HP) 4.0 l
    Mileage: 95484 KM
    01 Engine
    System description: 4.0l V8TFSI /
    Software number: 4G0906014
    Software version: 0012
    Hardware number: 4H0906014
    Hardware version: H56
    ODX name: EV_ECM40TFS0114G0906014
    ODX version: 001014
    Long coding: 0A2500326526010A1000
    Trouble codes:
    U111300 - Function limitation due to received malfunction value
    static
    Date: 2019-08-22 22:19:18
    Mileage: 89939 km
    Priority: 6
    Malfunction frequency counter: 17
    Unlearning counter: 255
    Engine speed: 0.00 1/min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 86 °C
    Intake air temperature: 77 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 12.203 V
    Dynamic environmental data: 20962810160000128C0000000013380512160A16129D5B11D9 31E510100000
    static
    P209800 - Post Catalyst Fuel Trim System Bank 2 Too Lean
    static
    P209600 - Post Catalyst Fuel Trim System Bank1 Too Lean
    static
    P201400 - Intake Manifold Runner Position Sensor/Switch Circuit
    static
    P030000 - Random/Multiple Cylinder Misfire Detected
    Intermittent
    P030600 - Cyl.6 Misfire Detected
    Intermittent
    02 Transmission
    System description: 0B5 40TFSIRdW
    Software number: 4G1927156L
    Software version: 0011
    Hardware number: 0B5927156K
    Hardware version: H07
    ODX name: EV_TCMDL501021
    ODX version: 001025
    Long coding: 000001
    Trouble codes:
    No trouble codes found
    03 Brakes
    System description: ESP PREMIUM
    Software number: 4G0907379H
    Software version: 0361
    Hardware number: 4G0907379H
    Hardware version: H09
    Serial number: --------------
    ODX name: EV_ESPPremiAU57X
    ODX version: 004028
    Long coding: 65A6C701A665E380CB00
    Trouble codes:
    static
    Date: 2019-08-22 22:20:02
    Mileage: 89939 km
    Priority: 6
    Malfunction frequency counter: 14
    Unlearning counter: 130
    VzRef: 0
    Bit Info 1: 0
    Bit Info 2: 3
    Bit Info 3: 2
    Bit Info 4: 1f
    F-Path: 2
    F-Type: 4
    Uz: 9d
    Intermittent
    Date: 2020-04-13 10:40:38
    Mileage: 95457 km
    Priority: 6
    Unlearning counter: 151
    VzRef: 0
    Bit Info 1: 0
    Bit Info 2: 43
    Bit Info 3: 22
    Bit Info 4: 1f
    F-Path: 2
    F-Type: 16
    Uz: b9
    C101A14 - Left front ABS wheel speed sensor Open circuit/short circuit to ground
    static
    Date: 2019-09-01 21:23:17
    Mileage: 90298 km
    Priority: 2
    Malfunction frequency counter: 15
    VzRef: 0
    Bit Info 1: 80
    Bit Info 2: 40
    Bit Info 3: 26
    Bit Info 4: 1f
    F-Path: 1
    F-Type: b0
    Uz: b1
    C101A01 - Left front ABS wheel speed sensor Electrical error
    Intermittent
    Date: 2019-09-06 20:01:52
    Mileage: 90522 km
    Priority: 2
    Malfunction frequency counter: 9
    Unlearning counter: 170
    VzRef: 0
    Bit Info 1: 0
    Bit Info 2: 2
    Bit Info 3: 0
    Bit Info 4: 1f
    F-Path: 1
    F-Type: b3
    Uz: a1
    static
    Mileage: 89939 km
    Priority: 2
    Malfunction frequency counter: 26
    VzRef: 0
    Bit Info 1: 0
    Bit Info 2: 3
    Bit Info 3: 2
    Bit Info 4: 1f
    F-Path: 1
    F-Type: ad
    Uz: 9e
    04 Steering Angle Sensor
    Trouble codes:
    05 Keyless System
    System description: BCM2 2.0
    Software number: 4H0907064DT
    Software version: 0510
    Hardware number: 4H0907064CT
    Hardware version: H32
    Long coding: 05882F46000000000000
    Trouble codes:
    01330 - Comfort system central control module Please read DTC
    static
    Priority: 6
    Frequency counter: 25
    Driving cycle: 130
    Mileage: 89939 km
    Date: 2019-08-22 22:20:03
    00955 - Key 1 Lower limit not reached
    Intermittent
    Priority: 3
    Driving cycle: 131
    Mileage: 94734 km
    Date: 2020-01-11 22:33:39
    08 Air Conditioning
    System description: KLIMA 4 ZONEN
    Software number: 4G0820043AD
    Software version: 0070
    Hardware number: 4G0820043AD
    Hardware version: H13
    Serial number: 05071200040779
    ODX name: EV_AirCondiComfoUDS
    ODX version: 002036
    Long coding: 680120783D
    Trouble codes:
    U111100 - Function limitation due to missing message
    Intermittent
    Date: 2020-03-19 22:35:52
    Mileage: 95087 km
    Priority: 6
    Malfunction frequency counter: 3
    Unlearning counter: 128
    Dynamic environmental data: 02860E0E0288012609A0
    Intermittent
    Date: 2020-03-19 22:35:55
    Mileage: 95087 km
    Priority: 6
    Dynamic environmental data: 02860DF62609A0F40C0299
    09 Central Electrics
    System description: BCM1 2.0
    Software number: 4H0907063CG
    Software version: 0130
    Hardware number: 4H0907063
    Hardware version: H12
    Serial number: 00000001545298
    Long coding: 0907201009749FE0898100C4A0001800CF9CC3082E08020180 0108546F01
    Subsystems:
    System description: WWS57X 120606
    Software number: 4G1955119
    Software version: 0080
    Hardware version: H36
    Serial number: 120620163850
    Long coding: 0045F7
    System description: G397_RLFS
    Software number: 8U0955559B
    Software version: 0002
    Hardware version: H06
    Serial number: 20396879
    Long coding: 02006D
    System description: E1 - LDS
    Software number: 4G0941531G
    Software version: 0044
    Serial number: 28 06 2012 00001302
    System description: A31 LED Mod1L
    Software number: 4H0907472B
    Software version: 0006
    Hardware version: H03
    Serial number: 00000010071200010821
    Long coding: 110000
    System description: A27 LED Mod1R
    Serial number: 00000017121300010067
    Long coding: 110000
    System description: EVLS-SG
    Software number: 4H0907705K
    Software version: 0300
    Hardware version: H08
    Serial number: WA103815000001527270
    Long coding: 020300
    System description: AQ_Hum_Sensor
    Software number: 4H0907658
    Software version: 0003
    Serial number: 6F180936000000000001
    Trouble codes:
    01316 - Brake control module Please read DTC
    static
    Priority: 6
    Frequency counter: 254
    Driving cycle: 119
    Mileage: 89939 km
    Date: 2019-08-22 22:18:00
    03608 - Humidity sensor in fresh air intake duct No signal/communication
    Intermittent
    Priority: 3
    Frequency counter: 3
    Driving cycle: 128
    Mileage: 95087 km
    Date: 2020-03-19 22:35:00
    03608 - Humidity sensor in fresh air intake duct no or incorrect basic setting/adaptation
    Intermittent
    Priority: 3
    Frequency counter: 1
    Driving cycle: 128
    Mileage: 95345 km
    Date: 2020-04-03 11:23:00
    15 Airbag
    System description: Airbag10.43
    Software number: 4H0959655C
    Software version: 0040
    Hardware number: 4H0959655C
    Hardware version: H43
    Serial number: 003JG009DWPV
    ODX name: EV_AirbaAU10BPAAU64X
    ODX version: 001014
    Long coding: 30323436313330303432554A304C34473053
    Trouble codes:
    U112300 - Databus error value received
    static
    Date: 2019-08-22 22:20:05
    Mileage: 89939 km
    Priority: 6
    static
    Date: 2019-08-22 22:22:22
    Mileage: 89939 km
    Priority: 6
    16 Steering Column
    System description: Lenks.Modul
    Software number: 4H0953568G
    Software version: 0005
    Hardware number: 4H0953568G
    Serial number: 90372LFT001UM
    Long coding: 0000F4
    Subsystems:
    System description: E221 - MFL
    Software number: 4G0951528A
    Software version: 0009
    Serial number: 26 05 2012 C0074631
    Trouble codes:
    static
    Priority: 6
    Frequency counter: 27
    Driving cycle: 119
    Mileage: 95450 km
    Date: 2020-04-12 11:39:14
    28 Rear Climate Control
    System description: KLIMA FOND
    Software number: 4G0919158J
    Hardware number: 4G0919158J
    Serial number: 12071200040542
    ODX name: EV_ClimaContrUnitRearUDS
    ODX version: 002018
    Long coding: 20
    Trouble codes:
    B10D322 - Left rear upper body vent motor Upper limit exceeded
    static
    Date: 2019-08-22 22:19:11
    Mileage: 89939 km
    Priority: 3
    Malfunction frequency counter: 254
    Unlearning counter: 119
    Dynamic environmental data: 02860C592609BB26A62DB52DB52C8D2710
    B10D422 - Right rear upper body vent motor Upper limit exceeded
    static
    Date: 2019-08-22 22:19:08
    Mileage: 89939 km
    Priority: 3
    Dynamic environmental data: 02860C592609BB26A72DB52DB52C8F2710
    B10D421 - Right rear upper body vent motor Lower limit not reached
    Intermittent
    Date: 2019-08-23 12:38:44
    Mileage: 89964 km
    Priority: 3
    Malfunction frequency counter: 220
    Unlearning counter: 155
    Dynamic environmental data: 02860DFB2609B226A7267926792C8F2710
    34 Chassis Control
    System description: LUFE-DAEMPFER
    Software number: 4G0907553F
    Software version: 0782
    Hardware number: 4G0907553F
    Hardware version: H18
    Serial number: �‰ xe
    ODX name: EV_AirSuspe
    ODX version: 003024
    Long coding: 008000
    Trouble codes:
    C104600 - Level control system
    Intermittent
    Date: 2020-04-13 10:40:37
    Mileage: 95457 km
    Priority: 2
    Intermittent
    Mileage: 95457 km
    Priority: 2
    C104807 - Level control system sensor mechanical malfunction
    Intermittent
    Date: 2019-12-16 15:19:16
    Mileage: 94030 km
    Priority: 2
    Malfunction frequency counter: 38
    Unlearning counter: 135
    C10C800 - Function deactivation active
    Intermittent
    Date: 2020-08-03 18:17:54
    Mileage: 95480 km
    Priority: 6
    Malfunction frequency counter: 4
    Unlearning counter: 159
    C1031F1 - Level control pressure sensor Residual pressure for lowering rear axle too low
    Intermittent
    Date: 2020-01-02 22:01:49
    Mileage: 94475 km
    Priority: 6
    Malfunction frequency counter: 41
    U111200 - Function limitation due to implausible message
    static
    Date: 2019-08-22 22:19:06
    Mileage: 89939 km
    Priority: 6
    P178E00 - Function limitation due to excessive temperature
    Intermittent
    Date: 2020-01-05 09:47:35
    Mileage: 94511 km
    Priority: 6
    Malfunction frequency counter: 34
    36 Driver Seat
    System description: MEM-FS
    Software number: 4G8959760
    Software version: 0154
    Hardware number: 4G8959760
    Serial number: 00000033479737
    Long coding: 00581B0000006001000001010101102030303232203232
    Trouble codes:
    3B Sensor Electronics
    System description: SARA 6D
    Software number: 4G0907637K
    Software version: 0053
    Hardware number: 4G0907637F
    Hardware version: H02
    Serial number: EJ1BPA8200HCF5����������
    ODX name: EV_SARA2
    ODX version: 005011
    Trouble codes:
    44 Steering Assistance
    System description: RCEPS
    Software number: 4G0909144L
    Software version: 0010
    Hardware number: 4G0909144G
    Hardware version: H35
    Serial number: 0022672695
    ODX name: EV_RCEPS
    ODX version: 009008
    Long coding: 101001010000
    Trouble codes:
    static
    Date: 2019-12-20 16:28:40
    Mileage: 94131 km
    Priority: 6
    Wheel_speed_Front_Left: 100.00 km/h
    Wheel_speed_Front_Right: 0.00 km/h
    Wheel_speed_Rear_Left: 0.00 km/h
    Wheel_speed_Rear_Right: 0.00 km/h
    Supply voltage, terminal 30: 14.16 V
    46 Comfort System
    Serial number: 0179746203
    Long coding: 011A0E2000B93185833008800A030300000000000000000000 0000000000
    Subsystems:
    System description: DWA-Sensor
    Software number: 4G0951177
    Hardware version: H01
    System description: LIN BACKUP HO
    Software number: 1K0951605C
    Software version: 1501
    Hardware version: H05
    System description: J245 PS40.039
    Software number: 4G8959591
    Software version: 0008
    Serial number: WOO1725280%
    Long coding: 901F00
    System description: Dachelektroni
    Software number: 4G0947135F
    Software version: 0100
    Hardware version: H10
    Serial number: 0000000AP00001577243
    Long coding: 010000
    System description: GEB.F.Heckoef
    Software number: 3AA962243
    Software version: 0719
    Serial number: 84274004
    Trouble codes:
    03637 - Roof electronics ctrl module fcn limit due to excess temp
    Intermittent
    Priority: 6
    Frequency counter: 52
    Driving cycle: 159
    Mileage: 94977 km
    Date: 2020-03-04 12:44:49
    01134 - Alarm horn Faulty
    static
    Priority: 2
    Driving cycle: 218
    Mileage: 89939 km
    Date: 2019-08-22 22:19:13
    static
    Priority: 6
    Driving cycle: 130
    Mileage: 89939 km
    Date: 2019-08-22 22:19:14
    52 Passenger Door
    System description: TSG BF
    Software number: 4G8959792J
    Software version: 0506
    Hardware number: 4G8959792G
    Long coding: 011F16005E00628002080002
    Trouble codes:
    53 Parking Brake
    System description: EPB-4
    Software number: 4H0907801F
    Software version: 0013
    Hardware number: 4H0907801A
    Serial number: 00000000405934
    ODX name: EV_ParkiBrake
    ODX version: 001027
    Trouble codes:
    static
    Date: 2019-08-22 22:20:16
    Mileage: 89939 km
    Priority: 6
    Voltage terminal 30: 12.3 V
    Internal Fault ID: 139
    Network management state: normal
    Function light in parking brake button: On
    Red operating lamp: On
    Red warning lamp: Off
    Green operating lamp: Off
    Yellow warning lamp: On
    Terminal 15 status: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    ACC requested apply: not active
    Auto Adjust: not active
    General Inspection Function: not active
    Internal Parking Brake state: static
    Status of parking brake button: not operated
    Status ParkingBrake left: Set
    Status ParkingBrake right: Set
    55 Headlight Regulation
    System description: ....LWR12....
    Software number: 4H0907357A
    Hardware number: 4H0907357A
    Serial number: 120711-0004-1590
    ODX name: EV_HeadlRegulBasic
    ODX version: 005001
    Long coding: 11216F601002A300
    Trouble codes:
    Intermittent
    Date: 2019-12-15 11:28:54
    Mileage: 93930 km
    Priority: 6
    56 Radio
    System description: Radio U Basic
    Software number: 4G1035053G
    Software version: 0121
    Hardware number: 4G1035053
    Hardware version: H41
    Serial number: 227G10C7609763
    Long coding: 070003010000000001
    Trouble codes:
    5F Multimedia
    System description: H-BNT-RW
    Software number: 4G0035764F
    Software version: 0637
    Hardware number: 4G0035764H
    Hardware version: H49
    Serial number: 192GW0C7500553
    Long coding: 060D00000203F5EF4D90CB2E00000003740001020000000000
    Subsystems:
    System description: ROW 2012
    Software number: 8R0060884AJ
    Software version: 0403
    System description: DU8 C7 SV
    Software number: 4G0919605B
    Software version: 0021
    Hardware version: H42
    Serial number: AUZ8ZDC9401WK5%
    System description: E380 BDT C7
    Software number: 4G1919612Q
    Software version: 0204
    Hardware version: H11
    Serial number: 90349LFR00158
    System description: CD-Database
    Software number: 8R0060961C
    Software version: 3638
    Trouble codes:
    62 Rear Left Door
    System description: TSG HL
    Software number: 4G8959795J
    Hardware number: 4G8959795G
    Long coding: 010F14004000628002080002
    Trouble codes:
    6C Rear View Camera
    System description: TopView
    Software number: 4H0907428A
    Software version: 0111
    Hardware number: 7P6907441D
    Serial number: 82330JF0048302
    ODX name: EV_CamerSysteTopViewAUDI
    ODX version: 005022
    Long coding: 0201000001010000000102000000
    Trouble codes:
    6D Deck Lid Control
    System description: HDSG-Modul
    Software number: 4G5959107A
    Software version: 0038
    Hardware number: 4G5959107
    Serial number: 146200729
    ODX name: EV_HDSGAu571
    ODX version: 001001
    Long coding: 111104C000
    Trouble codes:
    85 On Board Camera
    System description: DPC-SG
    Software number: 4G0907217A
    Hardware number: 4H0907217A
    Hardware version: H25
    Serial number: 26213002542100000249209769
    ODX name: EV_OnBoardCamerDPC
    ODX version: 001007
    Long coding: E2040000
    Trouble codes:
    Intermittent
    Date: 2019-12-27 17:10:18
    Mileage: 94298 km
    Priority: 6
    Malfunction frequency counter: 35
    Control module temperature: 40.0 °C
    Voltage terminal 15: 14.2 V
    Outside air temperature: -38.0 °C
    8E Image Processing
    System description: BV-SG
    Software number: 4G0907107D
    Hardware number: 4H0907107
    Hardware version: H30
    Serial number: 00500005060712769104590000
    ODX name: EV_BC7
    ODX version: 001001
    Long coding: 04408A180111
    Trouble codes:
    static
    Mileage: 89939 km
    Priority: 6
    Voltage terminal 15: 12.1 V
    Control module temperature: 55.0 °C
    Outside air temperature: 43.5 °C
    C110800 - Function limitation due to missing image information
    Intermittent
    Date: 2019-12-15 11:28:56
    Mileage: 93930 km
    Priority: 6
    Malfunction frequency counter: 61
    Voltage terminal 15: 14.3 V
    Control module temperature: 26.0 °C
    Outside air temperature: 22.0 °C
    BA Assembly Mounting
    System description: AEM - LEAR
    Software number: 4H0907145
    Hardware number: 4H0907145
    Serial number: 97804000421104
    ODX name: EV_AEMLearAU64X
    ODX version: 002014
    Trouble codes:
    B201000 - No basic setting
    static
    Date: 2019-08-22 22:19:35
    Mileage: 89939 km
    Priority: 2
    Unlearning counter: 218
    B200500 - Data record invalid
    static
    Mileage: 89939 km
    Priority: 2
    C113107 - Actuator 1 for assembly mounting mechanical malfunction
    static
    Date: 2019-08-22 22:19:38
    Mileage: 89939 km
    Priority: 1
    Junior Member Two Rings
    Apr 15 2020
    Melbourne, VIC
    Could this be battery related?
    I've heard if the battery is dying it can make a lot of other things have a bad day
    New Member One Ring
    Aug 09 2020
    SA
    The battery status seemed to be okay, however I haven't driven the car for around two weeks
    Quote Originally Posted by Incandescent View Post
    Veteran Member Three Rings bpd's Avatar
    Feb 01 2017
    Seattle WA
    If its the original battery, time to retire it for a young one.
    2018 S6, 2023 S5 SB
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    As everyone else says. Check the battery.
    The ABS might be a good starting place after the battery.
    Left front ABS wheel speed sensor.
    A fault in the ABS can cascade other faults.
    Check fuses too.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    With that many codes you will be chasing your tail for a long time. Might considered clearing them all and see what comes back in the next 7 days.
    Like others have said, might be a battery. They say that a battery has had a good life if you can get abut 6 years out of it. Being trunk mounted these things seem to last better since they are not getting heat soaked under the hood. My A7 has the original battery so its 8 years old and has 205,000 miles on it. While the data says its getting tired, its not dead yet. I am getting ready to drop $1200 in parts for timing chains so I will wait until later in its life to replace. Since Covid hit its been a garage queen more than ever so I am in no rush to replace it. We need a jump pack around the house anyways with 5 vehicles to maintain so maybe this winter I will buy one and lug it around as a precaution for the times I actually have to get it out of the garage and drive it.
    Established Member Two Rings spdemon91's Avatar
    Jan 29 2019
    Bethlehem PA
    If I had that many error codes, I would be in the fetal position rocking back and forth nervously. Any updates bro? Let us know if the new battery fixed things. I just got my first CEL on my 2013 S8. One of the codes matches yours...
    P209800 - Post Catalyst Fuel Trim System Bank 2 - Too Lean
    Also throwing the following code...
    P14AB00
    If anyone out there can shed any light on these codes, it would be much appreciated. Thx.
    2013 Audi S8 4.0T (downpipes w/ APR stage 2)
    1997 Dodge Viper GTS (blue w/ white stripes)
    Aug 06 2014
    NJ->CO
    Should start a new thread, but...
    P2098 - Post Catalyst Fuel Trim System Bank 2 - Too Lean
    Fuel system out of range low
    Check the Heated Oxygen Sensor 2 -G108- / Oxygen Sensor 2 Heater - Z28- .
    Check the Oxygen Sensor 2 After Catalytic Converter -G131- / Heater For Oxygen Sensor 2 After Catalytic Converter - Z30- .
    P14AB - Exhaust door control unit mechanical malfunction
    valves in the exhaust are stuck??? that one is harder to find
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Established Member Two Rings orphancrippler's Avatar
    Aug 01 2020
    2018 Nissan Rogue SL, 2016 Nissan Rogue SV
    Telford, Pennsylvania
    Quote Originally Posted by gk1 View Post
    Sounds like you have a bad rear O2 sensor and one of the exhaust flaps is either stuck or is not opening and closing fully. The flaps are easy to check if you can get under the car, just manually actuate them back and forth to see if they move freely. If so, maybe one of the actuators could be going bad, although that would probably be an electrical error.
    Sent from my Galaxy S20 Ultra 5G
    2017 S6 DS1/SRT Custom ECU+TCU "Deathstroke the Terminator"
    SRM +4mm, HPA Street DPs, APR Catback w/X-pipe & 4" Tips, APR HX, MercRacing IC Core, SRM Short Intakes, AWE S-Flo V2, SRM Dual LPFP, Autotech Plungers, SRM FF Sensor + Engine Lines, 4 Bar MAP + Boost Sensors, TiAl WG Actuators, EMP Pump, JHM Oil Screen Kit, 034 Rear Swaybar/Endlinks/Drivetrain Inserts, SRM Driveshaft Carrier, iO2 CatSims, CF Spoiler + Mirrors, RS-Quattro Grille, Black Badging, CeramicPro Gold, 20mm R/17.5mm F Spacers
    Jan 29 2019
    Bethlehem PA
    Thank you sir! I appreciate the info. I will report back with final resolutions.
    Mar 30 2015
    Denver
    As others have said, battery is most likely culprit. I had the same long list of codes thrown when my battery started to die. New battery plus code clearing, everything went back to normal.
    2013 S6 - Estoril Blue - Lunar Silver
