Curious if anyone is still contemplating this swap. I am close to finishing up my big turbo 1.8T build hopefully it will be up and running before this winter. However I sold the two 2.7T engines I had and picked up a early 07K with a forged crank for pennies literally. Already have engine mount brackets ordered and oil filter block on order as well. Now its gonna come down to getting a intake manifold made, oil pan, valve cover and exhaust manifold. I also ordered a 2.5 cylinder beetle harness as the early 2006-2010 beetle ran me7.1.1 management and since i purchased pnp standalone for me7.5 all I need to do is swap 1 pin and Ill be able to utilize the same standalone ecu for the 5 cylinder. I would like to make this more of a information thread than a build thread as Im not much for build threads. I just don't have the time as it is. I will keep you guys updated. I would like to mention the following for those that are potentially interested in this swap.
For a budget build you want a 2005-2006 5 cylinder. Anything that has torx T30 securing the lower oil pan will have a forged crank.
Only 07K105101E cranks are forged,only exception to this rule is the $1500 TTRS crank.
Early 07K suffered from some timing issues because of the long service intervals. If you plan on building make sure you use good quality synthetic oil and change it every 5k miles max. That being said timing chain components cannot be swapped from later model year vehicles as the timing gear on the crank is different. There is also not way to swap that gear.
1.8T flywheels are the same bolt pattern as the 07K.
1.8T starter can be used but needs to be trimmed to fit as well as the lower timing cover.
01E transmission can be used but bell housing needs to be cut/trimmed because of the hump for the vacuum pump. Vacuum pump needs to be deleted as wel..
Your gonna need engine mounting brackets made or purchased.
Oil filter block to use for drivers side engine mount bracket is the only option.
For hydralic power steering I think the best approach is a electrci power steering pump made by TRW thats used in europe in some vw and gm cars.
Height wise the engine will fit but useing a billet valve cover wont hurt especially if running a catchcan.
Length wise theres a difference of about 4 inches. I think pulling the radiator fans and using pusher fans from other side should give you the room without modifying the rad support.
I think stock oil pan with modified subframe is the best and cheapest option.
Exhaust and intake manifolds if going turbo its your best bet for make good power.
06-10 2.5 beetle engine harness to make one hybrid harness using the stock 1.8T harness. Ideally you want to use the short ecu connector with the associated wiring and modify the pin out if needed. Having said that you will still need to use the long ecu connector with wiring from the 1.8T engine harness. Doing it this way ill take some work but will require the least amount of modification to engine harness.
Hope this helps demystify some of the things people have heard about this engine. FYI the stock forged crank should will handle more power than a 1.8T engine. I have yet to hear anyone snapping a crank.
