Results 1 to 40 of 46
    Established Member Two Rings Orch's Avatar
    May 29 2018
    UK
    S6 - DSG to ZF8 Swap?
    Anyone know if this has been done and how much work is involved? Been having a load of issues so pondering whether this is a potential fix for improved reliability?
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Quote Originally Posted by Orch View Post
    I DON"T know if this has been done, but AFAIK in most cars the engine programming is different depending on transmission.
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    Quote Originally Posted by WatchMeSpend View Post
    Usually not the case with VW/Audi cars, all the software is usually identical however coding is different for auto an manuals. Given that rs6 had a zf8, chances are zf8 should work with 4.0tt in the s6 given that trans connector is repinned and component protection is updated. I was musing about doing the same dl501 to zf8 swap in my s4, however I decided not to spend anymore money on that junker than necessary and just get a car I want instead of presumably more "reliable" s4. S6 with 4.0tt however deserves some like this done to it, its good to have this engine and not worry about the junktronic transmission issues.
    P.S. I started to think about zf8 in the s4 because a6 3.0t came with dl501 instead of zf8 outside the NAR, so these 2 transmissions are fairly interchangeable.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Is the bell housing bolt pattern the same? The engine to trans connection shafts might be off as well.
    Apr 23 2019
    CA
    Quote Originally Posted by Valpo A7 View Post
    Are you talking about 3.0t? Let me put it this way - the flange plate in the back of the engine where it's bolted up is the same part for CCBA with DSG and a bunch of other Audi engines including 2.0t, 3.2 and 3.0t. That plate has holes to accommodate several different transmissions, I saw that some holes were not used with dsg when I dropped mine. So no, bolt patterns for dsg and zf 8 are most likely not identical, but all the holes are there and dowel pins just might need to be moved to different positions. What's more, flex plate is also the same across at least 3.0t engines.
    Nov 27 2018
    Valparaiso, IN
    If all the hardware on the back of the engine will line up properly to the trans bell housing with minimal problems then that is a huge step forward in getting it done. Now it’s all software which a good tuner can probably help with. A good driveline shop can fabricate a driveshaft if it’s needed to modify the connection from the DSG trans to the ZF driveshaft. The flange might be different or the shaft length might need altered. That’s just cutting, welding, and a quick balancing.
    But being the A and the S are the same basic platform the trans length and driveshaft length might be right to begin with. You might need the shifter guts for the connection to the DSG. Just tossing things out here to think about. They might be perfectly compatible to begin with and it’s really just a plug and play tuning effort needed.
    May 29 2018
    UK
    Thanks guys, lots to think about here. Would love to find someone that’s done it to get the full low down
    Apr 23 2019
    CA
    I probably should have done this when my selector lever sensor went out and I had a shop replacing it. this idea occurred to me when I dropped it to replace the dual mass flywheel, front dsg clutch cover which I didn't tell the shop to do when they did the sensor. So now that is fixed and I'm ready to jump the Audi ship, i'm probably not gonna bother dropping the trans again and putting the zf8 in the car. Unless somebody drops an s4 with broken trans at my doorstep and tells me it's now mine, I won't be looking for any broken s4s either. Too mucho dinero and trouble with these cars for not much more performance than something with n54 or n55.
    Mar 11 2007
    Colorado Springs
    And I remember being pissed that Audi didn't offer the DSG on A6/A7 variants in the US. I think I'll take the zero...
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by A6sport View Post
    Um, what? DSG is the same as S-Tronic. Which my S6 has. In the USA.
    18 S6
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Audisthesia View Post
    I believe he might be referring specifically to how outside the US the C7 A6 and A7 came with the S-tronic as well.
    Funny, now Audi USA reversed it and the C8 A6/A7 are S-tronic while the S6/S7 are ZF(Tiptronic).
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Has anyone ever done this?
    It seems like they should be compatible, with ODIS and TCU tuning but I havent seen it done.
    It would be great if you could use an A6/A7 ZF8 because used ones are pretty cheap,
    If those dont work, the S8 or Rs6 transmission should work as they are also mated to a 4.0t
    My transmission is in good condition but I would definitely do a project like this If my clutch goes bad or my transmission ever needs replacing. I know it may be a tricky/expensive job but It could be worth it IMO over changing out a whole new dsg especially if you can use an A6/A7 Zf8
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Active Member One Ring BoostedDesigns's Avatar
    Oct 28 2014
    San Diego, Ca.
    just came across this looking as well. more for research than need
    Jun 28 2019
    California
    Quote Originally Posted by BoostedDesigns View Post
    Hope we get more info on this I would 100% do this if my dsg goes bad
    IG:@stolens6
    Jul 28 2013
    TTS roadster, IE stg 3 TCU + ECU, intercooler/pipes/76mm HFC downpipe/APR HPFP/GT6 355x32 fronts
    SGP/Beijing
    I just did this in my 09 Q5. Went from 1st gen DL501 to ZF8HP55A. You would need the following hardware items to get it done, trans, atf cooling lines, propshaft and rear diff. Best to get the support brackets of the trans and diff as well. Mine didn’t require driveshafts but YMMV. You will need the gear selector assembly as well since the cable connecting to the trans is of different length.
    Now the difficult part is repinning + addition of 1 pin in the wiring, component protection and ECU flashing. My initial assumption was that the long coding in the ECU would allow me to swap from 7spDSG to 8sp Stepped transmission. No luck there… had to use Odis to flash the correct software version. Was on IE stage 3 K04 file and IE after sales was stellar in helping me get the right tune after the ECU change. You may need to check your ESP coding if there’s any selection for transmission but in my case this was not required.
    To sum up, it was a tough one but DSG was just so problematic, I’d rather just have a ZF8. A plus point is 1800rpms @100kmh is awesome for fuel economy
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Not an S6, but a C7 TDi, but this guy has done it.
    https://youtu.be/c7JB0_rzn28?si=XsK4Sp4qz0T56MVu
    Jun 28 2019
    California
    Quote Originally Posted by Audibellybutton View Post
    I am a man of my word.
    I am in the midst of this swap right now. I will report back with an overview once its done.
    IG:@stolens6
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    I don't see why not. As long as the back of the engine is in the same place, which I think they do, it sure looks like it. I have yet to figure out if the 3.0t and 4.0t actually have different variations of the ZF8. Everything seems to contradict, but it looks to me the 3.0t and 4.0t use the same variation.
    Theoretically, you should just need to find a 3.0t parts car and swap everything over, which would be a better solution if you have room, as you'd be able to sell off the additional parts and make ok money on the remaining aluminum for scrap.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Jun 28 2019
    California
    Quote Originally Posted by Burkeomatic View Post
    Its actually a lot more simple than you might think. Definitely dont need a parts car either. ZF swaps have been done on virtually every car, but one must remember in our scenario, our engine and chassis are both physically compatible with the ZF8 so not much needs to be changed physically. As for coding one must remember all 4.0t have the same ecu MED17.1.1 so of course with some tweaks it is definitely compatible with the ZF8/AL551 without the need of a standalone controller like cantcu or turbolamik which most cars need to be able to run a ZF8
    I dont want to spoil too much (or jinx myself) but I will give all the details when I'm done. I also have the parts list for the swap as well.
    Another note is that i have found that the RS7,S8,A8, and A6/A7 all use the 8HP55 transmission despite rumors otherwise. They have different trans codes for example an A6 one is NNT whereas an RS7 transmission code is PTT
    I have no idea what the difference is between each transmission code, but I imagine not much. Obviously the RS models are rated for more torque? but what exactly is improved if anything? For that I am not sure.
    The transmission i'm using is from an A6 so I will see how it holds up. I predict that it will hold up great
    Edit: forgot to mention, the RS variant does have different cooler and a diff cooler as well, but i am unsure about any internal differences
    IG:@stolens6
    Feb 22 2021
    San Antonio
    I typed a lot.
    TLDR - All of the larger ZF8 cars (A6,A7,A8,RS7) available in the U.S. use some variation of the ZF8 HP55 rated at 479lb/ft of torque. We don't know what the different codes mean. MEE is an A8 4.0t, NCT is an A8 3.0t. and the RS7 has the PTT.
    I didn't think you would need a parts car, but it could be nice, and sometimes little stuff like connectors, bolts, and the like will nickel and dime you to death. I was just thinking of the cheapest C7s I've seen and you'd probably be able to snag one for a few grand on copart, what the engines go for and other things like that. You'd also get a back up diff, some extra axles, and maybe some upgrade interior parts for your car.
    I just don't like speaking with authority on these things unless I'm absolutely sure, but I'm 90% sure that the A8, C7 3.0T, and RS7 have the same transmission. My A8 has a MEE transmission code, whatever that means. I've read several of the self study guides and tons of info, and it all points to them being the same. There are several different iterations of the ZF8, and it's hard to tell. I also believe the diesel has the beefy box because of it's hi torque output.
    But the 3.0t and 4.0t cars no matter what all say HP-55 on them, and if you do some looking on ZF8s, a ZF8 HP55 is 479lbft rated.
    This is exactly what my transmission tag says.
    https://www.ebay.com/itm/19662821379...3Avlp_homepage
    This is the RS7 one.
    https://www.ebay.com/itm/13415935978...Bk9SR87Sr7nZZA
    So is there something different? Or are RS7 transmissions about $5-6k overpriced?
    Interestingly, the wikipedia page doesn't mention the RS7, but mentions the RS6 comes with the HP90.
    https://en.wikipedia.org/wiki/ZF_8HP_transmission
    It looks like they're the same. Maybe the longevity can be attributed to the tune.
    Here's what I am sure of though.
    The 3.0t transmission can handle whatever you want to throw at it from that motor.
    If you're really, really worried if it can handle the power or not. You can still get an A8 transmission with the MEE code. We know for a fact that will hold 4.0t power reliably with more junk in the trunk. Plenty of folks out there hauling around a 5000lb car with over 750 horsepower.
    If it were me, I'd just throw in whatever one I could get for the cheapest and go with that. Actually, if I somehow needed a replacement transmission for my car, I'd buy the $500 one. If I theoretically owned an RS7 and on the outside chance it went out, I'd throw in the $500 3.0T transmission and see what happened. YMMV, these transmissions are reliable enough, I don't think we'll need to worry about it.
    Edit: that's super cool about the TCU, would it be easier to reflash the one in your car, or get the one from the donor car and have that coded to your car. Like, I wonder if the firmware is different.
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    One thing I've found is there are different torque converters for the hp55. Also another difference is some versions have that accumulator inside for auto stop start cars. Those differences may be what the codes mean. However you can use a trans from auto stop start in a car without it. I installed a c7 3.0 xf8 into a b8 a4 and everything seemed the same However It has a different stall converter, i now can't boost brake as high
    Sent from my SM-S921U using Audizine Forum mobile app
    Jun 28 2019
    California
    I typed a lot.
    Wont need a parts car, for me personally the entire swap I will be out around $1200 ish, theres not many parts you need from the A6. One must also remember that majority of C7 parts are cross compatible with each other.
    As for the differences, what shane said about the torque converter makes sense. I imagine the difference between the RS models and the other HP55 could be the torque converter
    Update: Shane was definitely right the torque converter is different. I pulled an example part number 0BK323573A
    it lists A8/S8/RS7 as compatible. These torque converters can be bought used for cheap, so I'm going to buy one of those and see if I can put it on the A6 transmission. I dont see why not. Great budget RS trans if so
    IG:@stolens6
    Feb 22 2021
    San Antonio
    Quote Originally Posted by Shane Horning View Post
    That makes a whole lot of sense, like a ton. I also agree about the C7 3.0t torque converter being extra lame. It absolutely blows my mind that we're making all of this power with a transmission rated for 479lb/ft. But I suppose the tuning probably also makes up for a lot. I'm sure most if not all tunes increase line pressure (probably not the Audi specific correct term, but the pressure that holds the clutches closed) like a shift kit would in, say an Allison 6 speed, which is the last transmission I put a shift kit in. Heck, I bet Audi may do something like that in the RS7 and the S8s. So between that and I think we mostly all agree that this transmission is underrated or has a massive margin of safety built in, that's why we can wring every last lb/ft out of it hauling these lard cars around and they stand up.
    Absolutely. I bet that's right. I really just want to have a parts car and to live vicariously through other people, but I live in a neighborhood where a 60' wide lot is the "premium" lot, may as well be townhouses so that's why I'm pushing it. Or I want to relive my lemons glory days. $1200, that's less than an upgraded clutch pack for an hard to kill low maintenance transmission. What a deal! To be honest, I probably wouldn't buy a parts car either. Kind of makes me want to get an S6 and try it, but the next C7 I get will be diesel.
    Jun 28 2019
    California
    exactly, the a6 hp55 rating is so low. ZF is known for massively underrating transmission tq lmits but still
    Ill be adding a used torque converter from Rs7/A8/S8 since the transmission is out already, why not. Should be a nice upgrade. But other than that I think the A6/A7 transmission will hold up just fine. On the DSG once you get over a certain power level the DSG starts acting up although it should be able to handle more. But i wont go too deep on that tangent. Ill share all my thoughts once I get the swap finished.
    but yeah definitely cheaper than a clutch upgrade. And i see so many people upgrading clutches and still destroying the DSG so its like whats the point. the clutch itself is not the main issue. DSG is a great transmission its just massively misunderstood. But i digress..
    IG:@stolens6
    Nov 16 2018
    Upstate. New York.
    Good idea on the torque converter
    Jun 28 2019
    California
    Thanks! you educated me just in time
    IG:@stolens6
    Established Member Two Rings NorthernGTI's Avatar
    Oct 19 2024
    C7 TDI
    Mississauga, Canada
    Quote Originally Posted by gk1 View Post
    Not sure about the C8 but the S6/S7 are DSG in Canada. Id assume the same for USA.
    813garage(on instagram) is currently doing a ZF trans swap in his big turbo S6. I think he ran into a software issue though. Might be worthwhile to send him a msg and see where hes at with it.
    Oct 21 2021
    2019 A6 Prestige
    Man, I'm very curious as to the source on your ZF info. EVERYTHING I had found pointed to the RS cars running the HP90.
    ETA..... Well I'll be damned.
    https://avtgr.ru/upload/iblock/f91/x...ansmission.pdf
    2018 A6 3.0 P+ Sport - Stg 1 APR - IE Intake - RS6 Seats - S6 Sport Exhaust
    2019 A6 3.0 Prestige
    Junior Member Two Rings
    May 16 2024
    Scottsdale AZ
    S[emoji239] - DSG to ZF[emoji239[emoji239]] Swap?
    There’s a guy on instagram, eight one three garage, who appears to have done the swap. Might be worth while to get in contact with him for some tips on how to do it
    Ps
    (His account is the numbers not them spelled out. I can’t put them in the post without it turning into a bunch of emoji code for some reason)
    Last edited by devo321; 10-28-2024 at 07:42 AM. Reason: Putting the number is messing up my post lol
    Feb 22 2021
    San Antonio
    Quote Originally Posted by RLCree View Post
    Good find, that would have saved me the research on ebay....lol.
    I'm saving that for later, I'm sure the conversation will come up again. Looks like the only ones that got the big boy transmission is the newer S8 and the V8 diesels. Essentially unobtanium, only required for those really swinging for the fences. Not that I keep up with them that much, but even the 1000 hp guys are keeping the HP55 together.
    So people asking $7k for an RS7 transmission are just doing so because it came out of an RS7. Go laugh in their face. On that note, i wonder what the difference in the V8 torque converters are. Shane made it sound like they were more alike than different.
    These transmissions are dirt cheap out of the other cars for a reason, it's because they don't break, and there isn't considerable demand.
    This is good stuff guys, soon there will be an army of diet rs7s and rs6 sedans running around.
    Now let's figure out a cheap way to get the low compression rs7/s8 motors (not gonna happen).
    Oct 19 2024
    C7 TDI
    Mississauga, Canada
    Quote Originally Posted by devo321 View Post
    Ps
    Noticed that earlier. Didnt quiet know what to reply to it.
    Oct 21 2021
    2019 A6 Prestige
    I bet the converters boil down to stall and clutch differences. Size and shape should be the same, minus possibly bolt pattern.
    Jun 28 2019
    California
    I dont blame you, ive been told the same thing and always thought that, even heard rumors it was a 70 but every single one ive seen is hp55
    a compatible hp90 we could use would be the bentley HP90
    IG:@stolens6
    Jun 28 2019
    California
    Ps
    Hes a friend of mine, I am doing what I can to help him and he has helped me a lot on the prep and stuff. As for coding we are pretty sure we have it figured out thanks to the advice of others who did similar swaps. But he is waiting on someone to help him flash the tcu side. In my case I am purchasing the tools to do it myself. Once i get it all done I can confirm what did or did not work. There are several different approaches I am going for the simplest one if that makes sense. But if i run into any issues I will use the more complex way
    IG:@stolens6
    Feb 22 2021
    San Antonio
    a compatible hp90 we could use in the same way with the same coding process would be the bentley HP90
    Well, I don't think it's necessary.
    Well, maybe for you since your car's probably a rocket ship with your over compensator turbos.
    I had read both ways. I forget what self study I was reading, or maybe it was my build sheet. I was fairly convinced my A8 had a different trans than my A7 did, but I came to realization that it didn't. So then I started looking at the transmission tags, and ebay was the best place. I've found others. Although, if you want to turn a profit, you could buy 3.0t zf8s for $500-1000 and sell them as RS7 transmissions on ebay for $5k. I wonder if the ones where you can't see the transmission tags are like that.
    Jun 28 2019
    California
    Yeah I'm not that fast yet. I will try to beat this transmission to death, if it dies, swapping in an HP90 is cheaper and more worth it than building the 55
    IG:@stolens6
    Apr 19 2023
    Wisconsin
    Like to see the out come of this. Keep us posted.
    Oct 19 2024
    C7 TDI
    Mississauga, Canada
    Saw him post on Instagram that he finished the swap and is driving it. Spoke to him briefly. Super nice guy.
    Sent from my SM-S916W using Audizine Forum mobile app
    2014 TDI
    Aug 14 2019
    Tampa
    813garage zf swapped S6.
    18 S6
    Oct 21 2021
    2019 A6 Prestige
    813garage zf swapped S6 is now driving. It's a f*$#!@#g animal.
    Sure hope he has a parts list and something of a guide on it. The DSG was the only thing that kept me out of an S6.
