Results 1 to 11 of 11
    Feb 04 2007
    Toronto, Canada
    RS6 Active Cruise Problems
    Hey everyone,
    I recently purchased a 2014 C7 RS6, got the car for good value. Had the car compression tested and leak down and that was perfect so I bought the car as it was mechanically excellent but have some fault codes with one MAJOR MAJOR problem, my Adaptive cruise control and Brake guard fault comes on the dash and does not work and I have tried the following:
    - Connected a new cable from the image processor to the camera and nothing, the code still comes up.
    - Replaced the camera with another used camera, still nothing the code still comes up (a new camera is 15 days order and super expensive in UAE)
    - Checked all the wiring seems ok and cant seem to figure out the problem. any help would be amazing because I really want the cruise control to work.
    Also the trunk issue is confusing me, I recalibrated everything code went away and now back again.
    Code:
    Sunday,26,July,2020,18:15:49:02798
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.1.0 (x64)
    Data version: 20200331 DS317.0
    www.Ross-Tech.com
    VIN: WUA82DFC2EN901082   License Plate: RS
    Mileage: 128246km-79688mi   Repair Order: Rs
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 20 22 28 36 3B 3C
              42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 85 8B 8E 8F 90 BA
    VIN: WUA82DFC2EN901082   Mileage: 128246km-79688miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1B-Active Steering -- Status: OK 0000
    20-High Beam Assist. -- Status: OK 0000
    22-AWD -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: OK 0000
    8E-Image Processing -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    BA-Motor Mounts -- Status: Malfunction 0010
    Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 906 560     HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0012
       Revision: NCH62---
       Coding: 122A003265460B0A1000
       Shop #: WSC 23688 002 1048576
       ASAM Dataset: EV_ECM40TFS0114G0906560 001013
       ROD: EV_ECM40TFS0114G0906560.rod
       VCID: 65C1DB64646B28AE98-8030
    No fault code found.
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
       Component: 0BK 40TFSIRdW H16 1007
       Revision: --H16---
       Coding: 000001
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMAL551211 002022
       ROD: EV_TCMAL551211_002_AU48.rod
       VCID: 71E9BF34A0A3F40EF4-8024
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
       Component: ESP PREMIUM   H09 0100
       Revision: --------    Serial number: --------------
       Coding: 64BF890126FD9180CB00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004036
       ROD: EV_ESPPremiAU57X_004_AU57.rod
       VCID: 3E735408A17D5B7639-806A
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 DT    HW: 4H0 907 064 DT
       Component: BCM2 2.0      H35 0510
       Revision: 00002001
       Coding: 05A92F06000000000000
       VCID: 7EF39408E9FD9B7679-802A
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-4Z.clb
       Part No SW: 4G0 820 043 AD    HW: 4G0 820 043 AD
       Component: KLIMA 4 ZONEN H13 0088
       Serial number: 23081300040090
       Coding: 680220780D
       ASAM Dataset: EV_AirCondiComfoUDS 002043
       ROD: EV_AirCondiComfoUDS_002.rod
       VCID: 61C9CF747043448E64-8034
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0130
       Revision: 11012002    Serial number: 00000001619772
       Coding: 0907201009749FF2B98100C4A0001800CF9CC7082E080201800108546F01
       VCID: 6FEDB94CBE97E2FEE2-803A
       Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119   Labels: 1KX-955-119.CLB
       Component: WWS57X 130715  H36 0080
       Serial number:         130821080637
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0002
       Serial number: 21666342
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Serial number: 29 08 2013  00000977
       Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Component: A31 LED Mod1L  H03 0006
       Serial number: 00000020081300010247
       Coding: 110000
       Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Component: A27 LED Mod1R  H03 0006
       Serial number: 00000030071300010701
       Coding: 110000
       Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA106232000004383150
       Coding: 020300
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H03 0003
       Serial number: B6F843C6000000000001
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4H0 919 475 AB    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0060
       Revision: --------    Serial number: 56231323901502
       Coding: B80B1B
       ASAM Dataset: EV_EPHVA2CAU57X0000 002012
       ROD: EV_EPHVA2CAU57X0000.rod
       VCID: 72EBB038A5A5CF160D-8026
    Address 13: Auto Dist. Reg (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H19 0410
       Serial number: 00000000000000
       Coding: 7E04010102
       ASAM Dataset: EV_AdaptCruisContrAU57X 002010
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 285F925053F9F5C663-807C
    1 Fault Found:
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 164
                        Mileage: 128246 km
                        Date: 2020.07.26
                        Time: 17:35:02
                        Control Module temperature: 62 °C
                        Voltage terminal 15: 12.489 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
    Address 14: Susp. Elect.        Labels: None
       Part No SW: 4G0 907 376     HW: 4G0 907 376 A
       Component: J250 DRC FahrwerH01 0040
       Revision: 00000000    Serial number: 00894015097400
       Coding: 0000000
       VCID: 6BD5AD5C4A8F1EDECE-803E
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H43 0040
       Revision: --------    Serial number: 003JG00EK51Z
       Coding: 3032343631334E303438554A304C34473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 36634C28894D9336E1-8062
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB400U50JEC897B
       Crash sensor for side airbag: front passenger side:
       Serial number: 3585HRB400450J5SCHEC
       Crash sensor for side airbag: rear: driver side:
       Serial number: 3515JRB401C50LKOF8LU
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 3525JRB401I50LKOFABT
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB405322HCSJO9$
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB405722HCSNOTP
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H04 0005
       Revision: --------    Serial number: 90372MHU000DZ
       Coding: 00003D
       Shop #: WSC 00469 128 08858
       VCID: 377D412C86476A3EFA-8062
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Component: E221 - MFL  H08 0010
       Serial number: 19 07 2013  D0272836
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G0 920 931 B    HW: 4G0 920 931 B
       Component: TBenRdwAccNv  H80 0618
       Revision: 30460232    Serial number: 658300813596048
       Coding: 538F110BAFC10008010400
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 25419B6424EBE8AE58-8070
    Address 19: CAN Gateway (J533)       Labels:* None
       Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000001071112
       Coding: 00E5074800
       ASAM Dataset: EV_GatewPkoUDS 001018
       ROD: EV_GatewPkoUDS_001_AU57.rod
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 8984701103
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 13061000000000000379
    Address 1B: Active Steering (J792)       Labels: None
       Part No SW: 8K0 907 144 L    HW: 8K0 907 144 L
       Component: DYNAMIKLENK.  H06 0720
       Revision: 52001005    Serial number: --------------
       Coding: 010100
       VCID: 387F42108B596546F3-806C
    Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.clb
       Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
       Component: FLA           H04 0012
       Revision: AA001002
       Coding: 04018264747464545425363E00
       VCID: 7CF79E00FFE1896657-8028
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H16 0200
       Serial number: 002108130001211
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       ROD: EV_AllWheelDiffeQSPFR.rod
    Address 28: HVAC, Rear (E265)       Labels:* 4G0-919-158.clb
       Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
       Component: KLIMA FOND    H07 0088
       Serial number: 29081300041757
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
       ROD: EV_ClimaContrUnitRearUDS_002.rod
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000071533404
       Coding: 00581B0000006001000001010101102030303232203232
       VCID: 77FD812CC6C7AA3E3A-8022
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 L    HW: 4G0 907 637 G
       Component: SARA 6D red   H03 0056
       Revision: --------    Serial number: EJ1BPA7E00LX4U
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 377D412C8E476A3EFA-8062
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 K    HW: 4G0 907 566
       Component: J769  SWA MasterH04 0010
       Revision: 00H04000    Serial number: 6PZ 010 287-09
       Coding: 0000005
       VCID: 377D412C46476A3EFA-8062
       Subsystem 1 - Part No: 4G0 907 568 K
       Component: J770  SWA Slave H04 0020
       Subsystem 2 - Serial number: 6PZ 010 287-29
       Subsystem 3 - Serial number: 5F24.07.1300H04000AMS14086ÿ
       Subsystem 4 - Serial number: S14086ÿ
    Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F1E005E00628002080013
       VCID: 45813BE4CCAB08AE78-8010
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H38 0010
       Revision: 00001000    Serial number: 0017775118
       Coding: 011100010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 326B703865258F16CD-8066
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0312359906
       Coding: 013A0E20A0B93095833009840E0312470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J245 PS20.008  H02 0007
       Serial number:     WOO2327218%
       Coding: 901F00
       Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
       Component: Dachelektroni  H10 0100
       Serial number: 0000000AP00004297376
       Coding: 010000
       Subsystem 5 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J394 PS20.008  H02 0007
       Serial number:     WOO2327225/
       Coding: 801F00
       Subsystem 6 - Part No SW: 3AA 962 243 B    HW: 3AA 962 243 B
       Component: GEB.F.Heckoef  H16 0810
       Serial number: 93002408
    1 Fault Found:
    01134 - Alarm Horn (H12)
                014 - Defective
                 Freeze Frame:
                        Fault Status: 01101110
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 128246 km
                        Time Indication: 0
                        Date: 2020.07.26
                        Time: 17:35:05
    Address 47: Sound System (J525)       Labels: None
       Part No SW: 4G0 035 465 C    HW: 4G0 035 465 B
       Component: BO G3 C7      H09 0160
       Revision: 11000000    Serial number: 0017594
       VCID: 25419B642CEBE8AE58-8070
       Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
       Component: BO C7 SLAVE  H51 0100
       Serial number: 00207130024410
    Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
       Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
       Component: TSG BF        H04 0507
       Coding: 011F1E005E00628002080002
       VCID: 448726E0C79131A66F-8010
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000800168
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2C576E404701D9E687-8078
    Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
       Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
       Component: ....LWR12.... H02 0010
       Serial number: 130824-0002-036
       Coding: 1122A6601002B300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D5163447C1BD0EE90-8078
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4G1 035 053 J    HW: 4G1 035 053
       Component: Radio U Basic H41 0133
       Revision: AB001007    Serial number: 227H+0D7847250
       Coding: 070003010000000001
       VCID: 26439C6851EDE3B651-8072
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 4G0 035 764 K    HW: 4G0 035 764 H
       Component: H-BNT-RW      H51 0732
       Revision: --------    Serial number: 192H-0D7504137
       Coding: 070D00010303E9EF75908B2E00000003740001020000000000
       VCID: 2F6D794C7E17A2FEA2-807A
       Subsystem 1 - Part No: 8R0 060 884 AS
       Component: ROW 2013  0506
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD0023Y8W
       Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
       Component: E380 BDT C7  H20 0250
       Serial number: 90349PGL00055
       Subsystem 4 - Part No: 8R0 060 961 F
       Component: CD-Database  5298
    1 Fault Found:
    03276 - Please Check Software Version Management
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 128246 km
                        Time Indication: 0
                        Date: 2020.07.26
                        Time: 17:35:05
                 Freeze Frame:
                        Text: KBD_FC7,KBD,A,fa,cc,1
    Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
       Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
       Component: TSG HL        H03 0507
       Coding: 010F1C004000628002080002
       VCID: 479D31ECF6A71ABE8A-8012
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273     HW: 4H0 907 273
       Component: RDKBERU25     H09 0700
       Serial number: 10000000003585
       ASAM Dataset: EV_RDKBERU25 003014
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 68DFD250937935C6A3-803C
    Address 6C: Back-up Cam. (J928)       Labels:* None
       Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
       Component: TopView       H05 0220
       Revision: 11001001    Serial number: 82330JF0103840
       Coding: 0203000101010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
       ROD: EV_CamerSysteTopViewAUDI_007.rod
    Address 6D: Trunk Elect. (----)       Labels:* Redir Fail!
       Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0143
       Revision: 14003001    Serial number: 235301198
       Coding: 097205C010
       ASAM Dataset: EV_HDSGAu572 001022
       ROD: EV_HDSGAu571.rod
       VCID: 35614B24944B982EE8-8060
    1 Fault Found:
    0114 - Load Space Cover
              B12EF 54 [137] - Missing Calibration / Basic Setting
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 128246 km
                        Date: 2020.07.26
                        Time: 17:35:01
                        Voltage terminal 30: 12.40 V
    Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
       Component: TSG HR        H03 0507
    Address 85: On Board Cam. (J852)       Labels:| 7P6-907-217.clb
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H26 0038
       Revision: --------    Serial number: 262130025421000
       Coding: 6A060000
       ASAM Dataset: EV_OnBoardCamerDPC 001007
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 26439C6859EDE3B651-8072
    Address 8B: Adaptive Cruise 2 (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Component: ACC3          H19 0400
       Coding: 7E04010102
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
       ROD: EV_AdaptCruisContr2AU57X_002.rod
    Address 8E: Image Processing (J851)       Labels:| 4H0-907-107-V2.clb
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H32 0041
       Serial number: 005000121608137
       Coding: 04809A1B0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    1 Fault Found:
    0161 - Video Cable for Image Processing
              C1107 02 [009] - Signal Failure
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 164
                        Mileage: 128246 km
                        Date: 2020.07.26
                        Time: 17:35:11
                        Outside air temperature: 39.5 °C
                        Voltage terminal 15: 12.5 V
                        Control Module temperature: 51.0 °C
    Address 8F: Pretens. Frt Left (J854)       Labels: 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 C
       Component: RGS-VL        H13 0080
       Coding: 0066E608031F0376070308014240C0010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L_VW51.rod
       VCID: 31697F346023B40EB4-8064
    Address 90: Pretens. Frt Right (J855)       Labels: 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946 B    HW: 4H0 980 946 C
       Component: RGS-VR        H13 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R_VW51.rod
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H07 0006
       Revision: 00001001    Serial number: 97809002397000
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X.rod
       VCID: 66C3DC68996D23B691-8032
    1 Fault Found:
    1294 - Actuator 1 for Drivetrain Mounts
              C1131 07 [009] - Mechanical Failure
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 128246 km
                        Date: 2020.07.26
                        Time: 17:35:03
    End-------------------------(Elapsed Time: 07:32)--------------------------
    now since the scan I have fixed the following:
    5F
    03276 - Please Check Software Version Management .FIXED and GONE
    000 - -
    Address BA:
    1294 - Actuator 1 for Drivetrain Mounts .ordered new mounts for this code
    01134 - Alarm Horn (H12) .ordered new alarm (wiper cover area I believe)
    Please guys any help would be greatly appreciated.
    2014 RS6 C7 | Blue on Lunar Interior | B&O |
    Established Member Two Rings Nhuthien12's Avatar
    Jun 24 2019
    Georgia
    Did you take it to dealer to cablirate ?
    Junior Member Two Rings
    Apr 15 2020
    Melbourne, VIC
    You've got an engine mount failure too? Edit: ignore this I can't read
    Also yeah has the ACC been calibrated? The bumper may have been removed and put on in a slightly different position, which is causing a misalignment
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Nhuthien12 View Post
    Exactly.
    I assume you also have component protection to contend with if replacing the camera.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    Could be a cable issue between the camera module (J852) and the image processing module (J851).
    Worth removing and refitting the cable at both ends.
    Veteran Member Three Rings spidey9999's Avatar
    Oct 19 2006
    How did you manage to find a C7 RS6 in Canada?
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by spidey9999 View Post
    I assume something has changed with OP's location and is now in UAE.
    From OP:
    " (a new camera is 15 days order and super expensive in UAE)"
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Oct 19 2006
    Quote Originally Posted by gk1 View Post
    From OP:
    Thanks. Missed that.
    Feb 04 2007
    Toronto, Canada
    No I have not.
    Could a recalibration fix this issue
    Feb 04 2007
    Toronto, Canada
    Guys I replaced the cable, no change, used camera no change.
    I can’t recalibrate with a fault. I get no sensor vision and it’s not the bumper sensors it’s the one on the windshield as shown on the vagcom scan.
    Mar 30 2018
    long island
    the ACC is a very finicky system.
    without knowing the cars history, I'm just spit balling ideas here....
    Windshield replacement required OEM glass. it also require re calibration after replacement. was the windshield ever replaced? was it with OEM glass? and was ACC recalibrated after?
    the (used) camera you installed may have component protection. it will need to be coded to your car. you may have inadvertently added a secondary problem be installing this.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
