Results 1 to 14 of 14
    Junior Member Two Rings
    Dec 03 2019
    DFW
    Must use crush washer on oil change
    So I did the 1st oil change today on the SQ5. I got some generic copper washers for the oil drain bolt but it still leaked. Went to VW dealer and got the right ones. I've owned 10+ cars (various OEs) and never had issues either re-using the washer or using a generic copper washer. These cars require the crush washer in the right size to confirm to the oil pan and bolt.
    N0138157 - washer
    Veteran Member Four Rings EvoToSQ5's Avatar
    Aug 09 2018
    2017 Audi SQ5
    Leominster, MA
    I think most of us do a top side oil change. I have yet to crack open the oil drain plug in the 2 years I’ve owned mine. The dealer I go to locally typically gives me a drain plug and crush washer with the filter free of charge.
    Jul 31 2016
    PA
    Quote Originally Posted by EvoToSQ5 View Post
    Same here, had the car since new in 2016 and never opened the drain plug. Always get out the full amount of oil too, sometimes need to fish a little with the suction tube but super easy.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Senior Member Three Rings eruben123's Avatar
    Sep 06 2014
    Boston
    I've always gone through the bottom, don't feel fully comfortable with sucking the oil out. I order through (and work at) FCP Euro. We have kits together for the SQ5 specifically, including a new drain plug and crush washer for each oil change. I usually use this kit.
    Also - FWIW - the FCP Euro Lifetime Replacement Guarantee applies to everything on the site including oil, meaning free oil changes for life less the cost of shipping your oil back to FCP Euro's location.
    YouTube: http://www.youtube.com/IgnitionTube
    2019 SQ5 - Audi Exclusive Chalk Grey | 2000 S4 - Hibiscus Red | 2013 Allroad - Ibis White
    Gone but not forgotten - '16 S6 - '04 M3 - '07 RS4 - '16 SQ5 - '10 GTI - '13 S4 - '08 GTI
    Dec 03 2019
    DFW
    Quote Originally Posted by eruben123 View Post
    Thanks for the link. I do follow your channel and saw your DIY on the oil change. Walmart has Mobil 1 0w40 Euro for $22 (5qt jug) and Mobil 1 has $10 rebate right now for 5qt jugs so it's hard to beat. I think it's more convenience since Mobil 1 is readily available. I guess I'd have to compare shipping cost. Sounded like you are selling the SQ5 tho.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by djn876 View Post
    I've done it both ways on my 3.0T Q5. Always did from the bottom on other cars because the filter was there. First oil change on this one was from the bottom. OP is right, you must use a crush washer to seal the pan plug.
    Then, realizing the filter was up top and that most here were vacuum draining from the dipstick tube, I got a metal Topsider. Big, mistake. The hand pump never sealed properly in the metal can. Slow as Christmas. Went back to bottom drain. For a while . . .
    After doing some more research, I got the Schwaben tube set and an EWK pneumatic system that uses compressed air. The Schwaben tubes fit the EWK, which has standard size fittings. Since I had a 30 gallon compressed air tank system already, it was an easy choice. It will work with little pancake compressors, too, since it does not require a lot of volume. Just about any compressed air source with at least 90 psi will work.
    It comes with automatic transmission fill fittings, a plus, as my ZF8 is due. Flip the valve one way for vacuum drain, the other way for pressure fill. Easy, no pumping, super quick. Obviously, no need for pressure fill with oil bottles and a funnel, but it will be great for the transmission.
    The EKW seems to be on back order at the moment for those interested. Probably a COVID supply chain thing that will resolve when things normalize.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    I used to do vacuum changes on my A4 but after seeing a couple people get those tubes stuck in the block I went back to using the drain plug. I know it's a different engine but same concept. I bought a bunch of plugs for $1 each from fcpeuro and they came with new washers.
    2011 A4 Avant Prestige S-Line
    Apr 08 2009
    Connecticut
    Quote Originally Posted by Novarider View Post
    I extract my oil as well with an ecs kit I bought a while back. Every 3rd oil change I drain.
    Funny you mention this, my last oil change my cousin got the tube stuck. Just gently twisted and pulled and it finally came out.
    I was sweating bullets thinking how much this would cost to fix. Always measure the length with the actual dip stick.
    - dubgli
    stock
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by dubgli View Post
    - dubgli
    I have some black electrical tape wrapped around the extraction tube to mark the proper depth. Actually about 1/2" deeper than the dipstick. That way I don't push it in too far.
    Aug 09 2018
    2017 Audi SQ5
    Leominster, MA
    Quote Originally Posted by MSq5 View Post
    Can you give me a measurement on that? I don’t have a dipstick so I just slowly lower it down the tube. I have yet to get it stuck though.
    Feb 14 2017
    Gulfport, MS
    The dipstick is 17.5" from tip to the flange that seats against the tube. Add 1/2" and mark your drain tube at 18".
    BTW, because the oil level sensor and hood switch are notoriously unreliable, I strongly recommend you get a real dipstick and use it to avoid the all-too-common overfilling. MMI often tells owners their car is a quart low, when it is not.
    Aug 09 2018
    2017 Audi SQ5
    Leominster, MA
    Is that the oem dip stick or aftermarket? I see FCP offers both and the aftermarket is half the cost. I like the ECS one but I don’t know how I feel about paying $70 for a dip stick.
    Jul 31 2016
    PA
    I have the ECS one and to be honest it is kind of hard to read, and gets super hot because the handle is metal. Probably would get OEM if I could do it again.
    The MTC one on FCP will work just fine I'm sure. If it makes you feel better, just don't leave it in and carry it in the trunk just to check level at a gas station or something.
    Feb 14 2017
    Gulfport, MS
    I believe it to be OEM part purchased from ECS. If you look close you can see the four interlocking Audi circles logo just below the flange. However, it is orange at the top. Genuine Audi is yellow, I recall. I don't know if color has changed over time. It appears identical.
