Results 1 to 28 of 28
    Mar 14 2019
    Miami, FL
    ACC + Brake Guard Deactivation - VCDS
    Guys,
    Is there a way to deactivate/convert to non-ACC via VCDS Coding? If so has anyone done it successfully?
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    What's the issue to why'd you do this?
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Mar 14 2019
    Miami, FL
    The forward onboard camera is acting up and the image processing module is throwing codes. I see this becoming an expensive fix and TBH I was never a big fan of it operates in traffic and when changing lanes. I rather have a conventional Cruise Control. So If I have the option to disable it via coding and making it operates like there are no sensors connected I'd like to go that route.
    May 26 2015
    Mormon Country
    Hmm, that would be interesting if you could. I thinking finding a car like yours in options minus the ACC and getting its coding to compare against would make it easier to figure out what needs to be changed. There are times I wish the ACC could function at a "dumb" level like when I'm cruising along minding my own business and it says there's no sensor "vision" despite them being clean, clear and unobstructed. It's annoying that it's all or nothing.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Sub'd
    This is an often asked, but I think not yet answered question.
    Can ACC equipped cars be reverted to regular cruise control?
    I suspect the answer is "yes", but I personally do not know how.
    It might be as simple as unchecking the ACC box in the long coding. However I fear there are multiple places to modify and if not done correctly may make things worse. It would take a soul braver than mine to try it out and report back.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    ACC can simply be turned on/off. Changing it to standard cruise, fair question. Comparing code from non ACC car of same year would be best bet, as gk1 said likely multiple code changes required. However, you mention the forward onboard camera (I assume you mean camera in top center of windshield) acting up. Perhaps I'm mistaken, but that camera is for lane assist, not ACC. ACC uses 2 sensors in the front bumper, not that camera.
    18 S6
    Mar 14 2019
    Miami, FL
    Quote Originally Posted by Audisthesia View Post
    Yeah it is the windshield camera and ACC relies on it together with the bumper-mounted sensors to work as intended. That camera is also used for lane assist which is also not working for me.
    Let's see if someone can post their long coding info on their non ACC cars.
    Jan 31 2009
    2016 RS7-P
    That camera is for high beam assist too which makes the coding even more tied together, I used to have ACC issues on my S6 from being slammed so would've liked to turn off the ACC function. Hope the answer is found, the dash alerts are annoying reminders.
    Aug 14 2019
    Tampa
    Quote Originally Posted by widebodyfx View Post
    Isnt the HBA sensor on back side of the mirror?
    18 S6
    Jan 31 2009
    2016 RS7-P
    You're right that one is the main imaging sensor for HBA when you look at the retrofit kits, confused it to when I was doing the Matrix retrofit Alex@Europrice asked me to checked the upper windshield camera part number.
    Aug 06 2014
    NJ->CO
    I took a quick look just at long coding and there are at least 7 modules that have reference to ACC in the long coding and I could not look into my CAN (19) module long coding because VCDS does not have information for that for my ECU.
    module 34 Level control
    byte 2 - bit 1 checkbox regarding ACC
    module 10 Park/steer assist
    byte 1 - bit 3 - checkbox regarding ACC
    module 09 Cent. Electr.
    byte 7 - bit 1 - checkbox regarding ACC
    module 17 Instruments
    byte 1 - bit 5 - checkbox to enable regular CC ?
    byte 4 - bit 2 - checkbox regarding ACC
    module 01 Engine
    byte 5 - bit 5-6 - dropdown box to change between ACC and regular CC or no CC?
    Would this one dropdown change all the other check boxes automatically?
    module 5F information elect.
    byte 6 - bit 3 - checkbox regarding ACC
    module 8E image process
    byte 1 - bit 7 - checkbox (distance regulation installed) ?
    Is this used for pre-sense or other safety features and maybe should not be unchecked to switch to regular CC?
    Anyone brave enough to try? I am not.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    May 26 2015
    Mormon Country
    You would probably need to turn it off in the BCM as well so it isn't always looking for it.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    May 20 2010
    W.r.t. changing lanes, have you just turned off lane assist? My ACC is perfectly fine changing lanes.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Mar 14 2019
    Miami, FL
    I’m getting close to trying making the changes but I’ll wait a little longer to see if some guru here has the answers on how to do it.
    May 22 2016
    N/A
    Following up on this thread, did you ever try the change?
    Mar 14 2019
    Miami, FL
    Still waiting for someone else to do it successfully.
    May 22 2016
    N/A
    Quote Originally Posted by Cayo71 View Post
    What exactly led you to consider this path? Curious because I have a fault for image processing cable for ACC. Replaced cable, didn’t work. Going to be replacing the module itself soon and if that doesn’t fix, going to be looking at disabling ACC all together I guess. Can’t pay 1/4 the cars value to Audi to fix this lol
    Mar 14 2019
    Miami, FL
    Quote Originally Posted by fixedhat313 View Post
    Exactly what you are saying. I was never a fan of the ACC. My wife’s SUV ACC is better than the one in my car when it was working.
    I haven’t changed the cable, I don’t know how difficult it is and if that doesn’t cure the problem it will be the camera itself of the image processing unit. Both require going to the stealership. I want to make it work as standard CC for those reasons.
    Aug 14 2019
    Tampa
    I guess I'm the only one who likes ACC. It works awesome on the highway. Sure, you can disable ACC using VCDS, but you will get a plethora of error codes and you can't convert it to "dumb" cruise control. That would require reprogramming some stuff so the car isn't looking for all the ACC hardware.
    18 S6
    May 22 2016
    N/A
    I might be wrong but I think the only reason someone would want to do this is if there are errors that no one can solve. In my case, I’m considering a new car if I can’t resolve my ACC problem, that’s how important it is to me. But, I figured it would be easier to sell a car that at least has “dumb” cruise control as opposed to none at all.
    Aug 14 2019
    Tampa
    The issue is the inter-module dependencies.. You can turn it off but as other have noted there are several other modules that interact with ACC.
    18 S6
    May 22 2016
    N/A
    In case anyone is in the same boat and running out of options with ACC / Lane Assist, I replaced the camera module that sits behind the rearview mirror with a used one for $400. My issue is resolved, now I just need a $300 calibration.
    Mar 14 2019
    Miami, FL
    Did you get exactly the same model number? There are different revisions and model numbers for different Audi models but they all look physically the same. Curious to know also how hard it was to replace it. Let us know how it goes after calibration.
    May 22 2016
    N/A
    For this camera module, I didn’t see any revisions. I replaced it with the same exact part number from the same year A8. After plugging in the new camera module, the car threw 83 faults. It had to be long coded in VAG COM. There was a newer revision for the image processing module under the seat. I tried matching part #s of the imaging module but that didn’t fix it for me.
    To replace, had to take off the cap behind the rear view mirror. The plastic piece holding the module in place and against the windshield is very brittle from the years of sun light. I actually couldn’t get the old module out without completed destroying the plastic holding it in place so I’m having the dealership do that, since they’ll have to calibrate it anyway.
    Since I’m this far into explaining things, my car was throwing a fault for the image processing cable. I replaced the cable first and that didn’t fix.
    I’ll let you know about the calibration.
    May 22 2016
    N/A
    Giving hopefully the last update on this - had the camera module installed and calibrated by Audi. Took about 3.5 hours. They charged me a flat $300 for calibration and labor. They said the module had to be programmed, even though I long coded it and it was only throwing a calibration fault after that.. not sure if that’s true.
    Mar 14 2019
    Miami, FL
    That wasn’t bad. Is it working properly now?
    May 22 2016
    N/A
    Only did one drive so far but yeah seems normal. Will update if not.
    Nov 25 2021
    2006 Porsche Cayman S, 1988 Porsche 928S4
    Southern California
    Can you share what you needed to do to code for the replacement camera?
    I have a 2012 A7 with the same problem, and I’ve found a used camera (same part number, from a wrecked 2012 A7). Before I shell out the $300 for the replacement camera, I’d like to get a sense of what I’m in for with coding the car to recognize the replacement. I have VCDS.
