Results 1 to 7 of 7
    Junior Member One Ring
    Nov 13 2016
    New England
    Exact lugnut size and spacer size for my 426 Cross Vision wheels!
    Good evening! I really need the exact lugnut and spacer size for these wheels please! 17 x 7.5 are my rims. Thank you so much, guys!
    https://www.visionwheel.com/wheel/23...ss?finishID=12
    Mar 24 2013
    Oakdale, CT
    I can tell by your post that you don’t really know what you’re asking for. You need a 5x112 bolt pattern with a 57.1mm hub bore. If you’re buying a 17x7.5 wheel, an offset in the ET30-35 range would work well. There are a lot of variables that come into play with wheel selection so the offsets I gave are just a general suggestion. You could likely run lower and definitely higher depending on what look you’re going for. OEM wheels use a ball seat lug bolt. Most aftermarket wheels use a cone seat lug bolt. Verify with the vendor which type you need.
    -Adam
    Nov 13 2016
    New England
    Well excuse me. I was told by a tire shop. The factory Audi lug nuts on the 2008 A4 Quattro aren't suppose to be on these vision rims but they are. Okay i'll just verify with Vision wheels because anytime i hit 65 MPH on the highway my car starts shaking. Not crazy.
    Mar 24 2013
    Oakdale, CT
    Like I said you probably need a cone seat lug bolt instead of the stock ball seat bolts.
    -Adam
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    What Adam said plus make sure your center bore is 57.1mm either naturally or with hub rings
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Nov 13 2016
    New England
    Thank you guys.
    May 20 2017
    New Hampshire
    So, what did you find out?
    Did you make sure your hub bore was correct? Did you verify what seat you’re suppose to use?
