Results 1 to 7 of 7
    Jan 17 2018
    Slovakia
    S6 - intake manifold flaps stuck
    hellou,
    I've got fault codes for my Audi S6 facelift - intake manifold flap stuck for bank 1 and 2. Is it problem with swirl flaps or solenoid that controls flaps or vacuum actuator or pressure leak?
    Also on dashboard is fault that I cannot exceed 4000 rpm. First time it happend about 10days ago, I changed battery (was almost dead) after that it was ok for 2 days, but then again "max 4000rpm". Now 1 from 5 times I drive the car there is no fault (sometimes I can drive without any issues, but a lot of times fault code).
    10152 - Intake Manifold Flap; Bank 2
    P2005 00 [096] - Stuck Open
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143835 km
    Date: 2020.07.16
    Time: 22:17:09
    Engine speed: 1085.00 /min
    Normed load value: 7.5 %
    Vehicle speed: 15 km/h
    Coolant temperature: 102 °C
    Intake air temperature: 58 °C
    Ambient air pressure: 960 mbar
    Voltage terminal 30: 14.112 V
    Unlearning counter according OBD: 35
    Engine status: COENG_RUNNING
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    10153 - Intake Manifold Flap; Bank 2
    P2007 00 [101] - Stuck Closed
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 143881 km
    Date: 2020.07.17
    Time: 07:06:12
    Engine speed: 1653.50 /min
    Normed load value: 34.9 %
    Vehicle speed: 24 km/h
    Coolant temperature: 100 °C
    Intake air temperature: 42 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 14.017 V
    Unlearning counter according OBD: 40
    8993 - Intake Manifold Flap; Bank 2
    P2007 00 [096] - Stuck Closed
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143780 km
    Date: 2020.07.16
    Time: 14:59:33
    Engine speed: 651.00 /min
    Normed load value: 6.7 %
    Vehicle speed: 0 km/h
    Coolant temperature: 104 °C
    Intake air temperature: 56 °C
    Voltage terminal 30: 14.041 V
    Unlearning counter according OBD: 34
    2978 - Intake Manifold Flap; Bank 1
    P2006 00 [096] - Stuck Closed
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143780 km
    Date: 2020.07.16
    Time: 14:59:33
    10151 - Intake Manifold Flap; Bank 1
    P2006 00 [101] - Stuck Closed
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 143835 km
    Date: 2020.07.16
    Time: 22:17:09
    Veteran Member Three Rings 3g_bishi's Avatar
    Mar 03 2016
    07 a6. 13 A7, 13A6, 08 A8LW12, 16A3, 15RS7
    DFW
    N316 actuator is failing. Not an easy fix. Might can do it if you find a way to lower the engine 2-3 inches with out completely removing it. I have done it. Basically loosen up the fram, have an engine hoist holding the engine from lift points, loosen up the frame completely and carefully lower the hoist. Remember you have hoses and wires connected so you can’t go to far.
    The book says remove engine
    Jan 17 2018
    Slovakia
    so you had the same problem or you had to only lower the engine for other issue? :)
    Mar 03 2016
    DFW
    I rebuilt An rs7 for last month and had that issue. I also have an rs7 (personal car) that I dropped the engine. So I am familiar with the many different ways of taking it out or lowering it
    Jan 17 2018
    Slovakia
    I took car to the audi dealer to solve it and he did
    It was problem only with solenoid valve (broken insert), they replace it with new part (06H906283B) and also, just for sure, replaced vacuum hoses (079131055DE).
    Veteran Member Four Rings digdah's Avatar
    Dec 11 2017
    DFW
    Quote Originally Posted by ferooo View Post
    Interseting. How much did this cost if I may ask and how many hours of labor?
    Jan 20 2023
    miami
    2013 audi C7 S7 RS7 S6 RS6 4.0 P2006 P2007 intake manifold runner codes.
    This can be useful, admin can move it the correct forum if wanted.
    Long story short.
    Bought 2013 S7 that was involved in light front end accident. Throwing intake manifold runner codes on both banks P2006 P2207 seemed suspicious as it would be unusual for both manifolds to go bad at 80000k.
    Checked all the solenoids and vacuum lines - all good. When manually applied vacuum - runners seem to open and close as it should ( checked each window with the good light and a mirror). Everything seemed to work as it should but codes were still there.
    Ended up lowering the engine and removed both intake manifolds.
    And found out that both manifolds had broken plastic pieces stuck ON THE INSIDE under the flaps ( and could not be seen with the mirror) which restricted the movement of the flaps.
    Those pieces appear to be a part of the front intake that was damaged in the accident and apparently the pieces were sucked in.
    So if you have a car that was involved in the front end collision popping these codes - good chance you have the same issue I had.
    Get a good quality pin camera and check for broken plastic pieces stuck under the flaps before you remove the manifolds.
    Hope this helps some one))
