Results 1 to 11 of 11
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    CEL Fun - 16618 / P0234 (Boost Pressure Regulation)
    Car Background:
    2004 Audi A4 1.8T with nearly 220K Miles. Mods listed below in signature.
    Hello Everyone,
    I recently threw a CEL a few days ago on my B6:
    CEL Code:
    16618 - Boost Pressure Regulation
    P0234 - 001 - Limit Exceeded (Overboost Condition) - MIL ON
    Readiness: 0000 0000
    Ross-Tech Link:
    http://wiki.ross-tech.com/wiki/index...8/P0234/000564
    Question:
    As I start going through the list of possible root-cause issues listed on the Ross-Tech website, I thought I would post and ask if anyone else has any recommendations on what to check for that may explain why this CEL was triggered?
    Thanks in advance to everyone for your time and help, it is greatly appreciated!
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Veteran Member Three Rings fabric8's Avatar
    May 14 2013
    US
    An over boost condition could be caused by the N75 which regulates the wastgate.
    Sent from my SM-G950U using Tapatalk
    HIS - 2016 Golf R 6MT
    HERS - 2002 B6 A4 1.8TQM Avant | Motoza Stg.1.5 | OEM A6 4.2 17" forged fat fives
    Apr 17 2016
    kc
    Or a leaky line to from n75/WG or just a bad WG itself😂
    Veteran Member Four Rings Hightekflytech's Avatar
    Sep 24 2013
    I.E. Cali
    Quote Originally Posted by hightime80 View Post
    +1 to all this
    When I had that code, it ultimately was a leaky line to the wastegate and a bad n75
    Jan 24 2010
    Paramus,NJ USA
    Check the n75 also check all the lines coming to it and from it. I have seen the lines split over time from being heat cycled.
    Ziddy Autowerks
    Feb 12 2004
    Austin, Texas
    Hey Everyone,
    Just as a mini-update, I was able to finally perform an output test and see if the N75 was functioning properly. I ran through the steps and got the usual clicking as expected. The turbo is a rebuilt K03s using the GPopShop turbo rebuilt kit, performed in 2018. I know some of you recommended looking at the wastegate. Is there an easy way to visibly tell if it is bad / needs adjustment while still being on the car?
    Thanks again everyone for your time and assistance so far. It is greatly appreciated! =)
    Feb 12 2004
    Austin, Texas
    Quote Originally Posted by Hightekflytech View Post
    +1 to all this
    Was there an easy way you were able to determine this was the issue? TIA.
    Sep 24 2013
    I.E. Cali
    Quote Originally Posted by A4orce84 View Post
    Hey Everyone,
    Not necessarily iirc. You would have to inspect the line going to the wastegate for small rips or holes in the vacuum tube. That and pressurize the line going to it with a mityvac or regulated compressor to 5 psi to see if the flap on the wastegate opens
    Feb 12 2004
    Austin, Texas
    But to test the wastegate like you are saying, you need to detach the exhaust or pull the turbo from the car, correct? Similar to how they do it in this video:
    https://www.youtube.com/watch?v=Ocqmg6R99qo
    Also, even though my N75 was 'clicking' correctly, is that all is needed to determine it is working correctly?
    To also add a bit more detail to my issue:
    The car tends to be in the 5-10PSi range most of the time. Sometimes, it will boost back to normal levels, ~20PSI since I am chipped, but only for a few seconds and then I'm back down in 5-10PSI land (slightly better than limp mode).
    Thanks everyone for your comments and assistance so far!
    Feb 12 2004
    Austin, Texas
    Mid-Week bump! Any feedback would be greatly appreciated.
    Feb 12 2004
    Austin, Texas
    Hey Everyone,
    Just to close the loop on this (for anyone looking at this post in the future!), as some of you indicated the root-cause of the issue ended up being a bad vacuum line going to the wastegate. Got a fresh vacuum line installed and the CEL is gone and all power has returned. Definitely better than a bad wastegate that I was mentally preparing to spend a few $$$ on.
    Thanks again to everyone for your time and help, it is greatly appreciated!
