Results 1 to 14 of 14
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    help removing air freshener smell from car, already tried ozone, vinegar, baking soda
    Having the hardest time to get rid of the air freshener smell out of a car i just purchased.
    They had an air freshener in the center armrest area and also in the driver door pocket.
    I have used an ozone machine, didnt take any smell away. Have tried to steam it out with a steamer. Have tried to spray with iso propyl alcohol. Have tried to spray with vinegar. Have used baking soda letting it sit also with vinegar.
    Any other ideas what to do? i cant smell any other part of the car that has air freshener, the arm rest and the door pocket are super strong smelling. I dont want to mask the smell with some other fragrance, want to get rid of it.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Established Member Two Rings dmsquattro's Avatar
    Feb 08 2017
    RS5
    New York
    As a last resort, I would fill those areas with whole coffee beans. You'll be surprised how much odor they absorb. Hope you like the smell of coffee...
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by dmsquattro View Post
    ha, well i hate coffee, so that wont work for me either. Yea this one is kicking my a$$, not sure what to do. I have never had such a hard time removing a smell before. My other cars previous owner had worn perfumes and i was able to get those out fairly easy. Its like this Audi plastic sucked all the sent in and embedded it. The center console is lined with like a felt, that seemed to get the sent out, but the plastic still has a majority of it in there.
    Veteran Member Four Rings 2by2handsofblue's Avatar
    Jun 02 2019
    RIP my 98 saturn sc1 5sp that had 294k miles on it.
    serenity valley
    Maybe take it to a detailer
    we are the borg! resistance is futile.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    change the air filter but before you put a new on in there, cycle through the ozone for another 2hr run. It's important when you ozone a vehicle that the machine stay OUTSIDE the car or it won't ever reach peak Shock levels to kill the odors. Ozone machines need fresh O2 to product O3 or else it will plateau way too early.
    Crude example but it's a set up that works. I've since trimmed the old couch cushion :)
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Jun 02 2019
    serenity valley
    Quote Originally Posted by pdqgp View Post
    When u do this method, does the car have to be running for 2hrs too? Well I would assume so.
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by 2by2handsofblue View Post
    Not the full 2hrs. I usually let it run for 30 minutes or so. The reason the door is up in this pic is I have an exhaust hose attached and running out of the interior of the garage.
    Jun 02 2019
    serenity valley
    So I came across this product on fpc euro. It's not cheap. Maybe u can buy your own pump. But liquid moly sells the ac cleaner that goes with this hand held pump.
    https://www.fcpeuro.com/products/air...ui-moly-lm4090
    Or you can try this product as well. You will need to drill a hole some where around your ac blower.
    https://youtu.be/_abZHzafnLM
    I myself might want to go with the product from liquid moly. But spray cleaner is way over priced. I wonder if u can use a off brand sprayer for much less.
    Heres another option.
    https://youtu.be/_QWbFimZ_Gs
    Feb 13 2004
    S Ã C, CÃ*
    Well gave this a shot, have the car connected to a battery charger with the ac fans on high. Forgot at first to press the recirc button.
    Sent from my iPhone using Tapatalk Pro
    Jun 02 2019
    serenity valley
    Quote Originally Posted by infinkc View Post
    How did it work?
    Feb 13 2004
    S Ã C, CÃ*
    How did it work?
    its still going :) will know later tonight after i let it air out more.
    Jun 02 2019
    serenity valley
    I'm curious how well it will work.
    Feb 13 2004
    S Ã C, CÃ*
    Well, it seemed to work, but i drove the car after and when i parked it, the smell came back! I had the fans running in the cabin also. This was some crazy air freshener they used! It was my friends car, so he wasnt trying to mask anything, just liked the smell of it. Me on the other hand is way too much sent for me. Giving it one last shot today, have the car outside with it running now fan on full blast. Will let this go for a few hours.
    The sent is like embedded in the plastic on the door panel, i may just land up buying another door panel, lol.
    Jun 02 2019
    serenity valley
    Oh that's terrible.
