Results 1 to 14 of 14
    Veteran Member Three Rings Jason11213's Avatar
    Feb 20 2020
    NC
    Ross Tech fault codes
    Anyone know what the fault codes 4695, 4698 and 4699 (Function restriction due to faults in other modules) could mean? Pretty vague and there were no other fault codes. I just did my first scan with VCDS and this is the only item that popped up. I don’t have any issues, CELs and just want to make sure everything is okay before I start logging 3rd gear pulls. I do have a stage 2+ tune with K04 turbo.
    ‘15 A4 6MT - Ward Performance Tuning - CTS TR 1070-X - Snow Performance Stage 2.5
    Jan 03 2013
    Baltimore
    Ross-tech.com and find the wiki with all the codes.
    Sent from my Pixel 3 using Audizine mobile app
    Feb 15 2016
    Cambridge,Ontario
    I had a a ton of codes after my tune. Delete them.and start fresh
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    There are no "ross tech fault codes" There are Audi DTC codes and generic OBD codes (like Pxxxx and Cxxxx).
    Post the complete autoscan log so we're not having to random guess at information you already have in hand.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I believe elscotto was referring to the Ross Tech listing of the VAG specific codes. Clicky click®
    Feb 20 2020
    NC
    Quote Originally Posted by Smac770 View Post
    Here’s the complete auto scan. I checked out Ross techs wiki and didn’t see these fault codes listed.
    Thursday,23,July,2020,20:50:08:32975
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
    Data version: 20200331 DS317.0
    www.Ross-Tech.com
    VIN: WAUHFAFL2FN016900 License Plate:
    Chassis Type: FL-AU48 (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F 62
    6C 72
    VIN: WAUHFAFL2FN016900 Mileage: 78510km-48783miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (MY15-CAED) Labels:. 06H-907-115-CDN.clb
    Part No SW: 8K5 907 115 M HW: 8K2 907 115 L
    Component: 2.0l R4/4V TF H09 0005
    Revision: ECH09---
    Coding: 4A190013242600062000
    Shop #: WSC 54851 003 1048576
    ASAM Dataset: EV_ECM20TFS0118K5907115M 001006
    ROD: EV_ECM20TFS0118K5907115M.rod
    VCID: 3C21310ED6E3AB1B4F3-8068
    3 Faults Found:
    4695 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
    Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
    Component: ESP8 quattro H09 0020
    Revision: -------- Serial number: --------------
    Coding: 071D1801
    Shop #: WSC 02391 785 00200
    VCID: 094F98DAC9314EB3045-805C
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 KM HW: 8K0 907 064 KM
    Component: BCM2 2.0 H15 0711
    Revision: 00002001
    Coding: 0F814040000000000000
    VCID: 055794EAE5292AD360D-8050
    Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Component: J764 ELV MLB H40 0046
    Serial number: 3214000106028013
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
    Component: KLIMA 3 ZONEN H04 0122
    Revision: C1000000 Serial number: 01240920140236
    Coding: 6400208000
    VCID: 77ABEE22AFC54843621-8022
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
    Component: BCM1 1.0 H16 0103
    Revision: 08016001 Serial number: 00000903815502
    Coding: 26000091863CAFE00400488300003D0D0F9C9308A209022100 0008004000030100000030000000
    VCID: 78A9ED1EA2DB473B6BB-802C
    Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B Labels: 1KX-955-119.CLB
    Component: MITSUBA010814 H18 0461
    Serial number: 1407300601112
    Coding: 004577
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 23236482
    Coding: 02005D
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Serial number: 00000000000409145095
    Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
    Component: USHL4.2 H30 0030
    Serial number: 00000000095Z009C2315
    Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: CD18CC47000000000001
    Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
    Part No SW: 8K0 959 655 Q HW: 8K0 959 655 Q
    Component: AirbagVW-AU10 H51 0812
    Serial number: 003NDD12FA5%
    Coding: 303844354730383131304A55304C384B3053
    Shop #: WSC 57875 001 1048576
    ASAM Dataset: EV_AirbaECUVWAUDI010 003114
    ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
    VCID: 4BC362D2834D1CA3F69-801E
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
    Component: BF-Gewichtss. H02 0040
    Serial number: 5810000R140000M6QK
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME490A2815C
    Crash sensor for side airbag: front passenger side:
    Serial number: 6344MSME494D0803F
    Crash sensor for side airbag: rear: driver side:
    Serial number: 6352QSME63450F46K
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 6362QSME63451458E
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME7D455350+
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME2E48177AA
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
    Component: Lenks.Modul H03 0003
    Revision: C0062331 Serial number: 90862NIT001L5
    Coding: 000016
    VCID: 48C95DDE92BBF7BBDBB-801C
    Component: E221 - MFL H03 0004
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 983 F HW: 8K0 920 983 F
    Component: KOMBIINSTR. H35 0564
    Revision: 00200000 Serial number: ZAA7C6P9F
    Coding: 8BB409000301D705020000
    VCID: 38292D1EE25B873BABB-806C
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
    Component: GW-BEM 5CAN-M H11 0060
    Revision: 1Z120030 Serial number: 3041Z149170006
    Coding: 80C303FF00
    VCID: 4CC161CE86C31B9BFF3-8018
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    Serial number: 6604204503
    Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
    Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
    Component: MEM-FS H06 0077
    Revision: AA000000 Serial number: 00000115822104
    Coding: 00581B00000000000000
    VCID: 3B233212D36DAC23469-806E
    Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
    Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
    Component: SWA Master H05 0071
    Serial number: 0346140836
    Coding: 010211
    ASAM Dataset: EV_LaneChangAssis 001020
    ROD: EV_LaneChangAssis_AU21.rod
    VCID: 3FDB4602C7F5B0036A1-806A
    Lane Change Assistant 2:
    Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
    Component: SWA Slave H05 0071
    Serial number: 0346253151
    Coding: 010211
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
    Component: TSG FA H09 0305
    Coding: 011C13204E00410001
    VCID: 56F583A6480F514B597-8002
    Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
    Part No SW: 8K0 909 144 J HW: 8K0 909 144 B
    Component: RCEPS H41 0509
    Revision: 00001000 Serial number: 0013981917
    Coding: 100000010001
    ASAM Dataset: EV_RCEPSAU48X 008016
    ROD: EV_RCEPSAU48X_008.rod
    VCID: 38292D1EE2DB873BABB-806C
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0348094085
    Coding: 0106023A00FA404580B0013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
    Component: GTO BF H01 0080
    Serial number: 00000000000000890060
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
    Component: J245 PS050 H08 0043
    Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
    Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
    Component: DSP Prem H05 0030
    Revision: 00005001 Serial number: 94813034814206
    VCID: 2D070C4A1D193293C8D-8078
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
    Component: TSG BF H09 0305
    VCID: 55F784AA55095A5350D-8000
    Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
    Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
    Component: EPB-4 H02 0005
    Revision: -------- Serial number: 10000000432981
    ASAM Dataset: EV_ParkiBrake 001028
    ROD: EV_ParkiBrake_AU48.rod
    VCID: 3A2D3716DCD7952B5DF-806E
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 082 G HW: 4G0 035 082
    Component: Radio U SIRIU H60 0133
    Revision: AB001007 Serial number: 156IE0E8069869
    Coding: 020007010000000001
    VCID: 2411E96E4ED3F3DB173-8070
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 8R1 035 746 F HW: 8R1 035 746 D
    Component: H-BNT-NA H41 0812
    Revision: -------- Serial number: 204IZ0E7680522
    Coding: 0F0200000006A1EF55028B5E00000403140000000000000000
    VCID: 3A2D3716DC57952B5DF-806E
    Subsystem 1 - Part No: 8R0 060 884 CA
    Component: NAR 2014 1002
    Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
    Component: DU7 High H42 0104
    Serial number: A130IY0E3139087
    Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
    Component: E0380 Bedient H02 0030
    Serial number: 00000001992083
    Subsystem 4 - Part No: 8R0 060 961 G
    Component: CD-Database 5950
    Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
    Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
    Component: TSG HL H08 0305
    Coding: 010C13204000210001
    VCID: 59EF889A39117E33745-800C
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
    Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
    Component: J772__Rearview 0040
    Revision: --H09--- Serial number: 525PA8-J49906F
    Coding: 1000006
    VCID: 38292D1EEE5B873BABB-806C
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
    Component: TSG HR H08 0305
    End----------(Elapsed Time: 01:49, VBatt start/end: 12.2V/12.2V)-----------
    Dec 28 2006
    Western Maryland
    From my understanding the U1113 00 codes occur whenever there is a communication issue between modules.
    Yours are now "Intermittent - Not Confirmed - Tested Since Memory Clear" which indicates that whatever caused the communication error is no longer present.
    Have you tried resetting all codes to see if they return?
    Jan 03 2013
    Baltimore
    Yes, that's what I meant. Sorry...beers at time of reply.
    Jul 16 2018
    Atlanta
    As old guy said, all three Audi codes boil down to the same OBD generic code, U1113, comms fault. So the message is saying "I'd love to be fully operational, but I'm missing information I need from some other module" Could be an actual comms failure, or a problem in the data source module that prevents the module supplying the expected data. But as you see in your scan, everything seems to be fine everywhere. So just clear codes and see how it goes.
    Sometimes you have to clear DTCs in two waves when the DTCs are based on another module's DTC. For example, I pulled the door harness plug while the ignition was on. Lights and codes galore. So I cleared DTCs but parking brake module still had a "fault in ABS module" DTC set, though the other module no longer had a DTC set. So clear it again and now it was all clear.
    As for what specifically do the Audi codes 04695 vs 04698 vs 04699 imply? Good luck finding that out. Here we see an example from a C6 A6:
    4695-U1113 Function restriction due to received malfunction value - short to ground.
    4699-U1113 Function restriction due to received malfunction value - open circuit.
    But who knows where that text interpretation of the DTC values came from, and if they are relevant to a B8.
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    if you don't have a counterfeit interface Uwe usually replies to post on the Ross Tech forums within a couple hours.
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by bb-tt View Post
    Ah yes..... Uwe... The Ross Tech Benevolent Dictator ;-)
    Apr 10 2019
    The real dictator is Jack@European_Parts . Uwe seems to be always helpful.
    Feb 20 2020
    NC
    Thank you for the help everyone. I cleared the codes and will wait to see if they pop back up. Since they were such generic fault codes I wasn’t too worried but will post on Ross Tech’s forum if they come up again.
    Feb 15 2016
    Cambridge,Ontario
    as i said earlier these codes come up when it is being force fed a tune ( Hence the comm errors ) ... a good tuner clears them all before returning the car to you.... i had zero codes... got my tune, got it back and scanned, had all these codes, cleared them out and car has been fine for a year,
    1976 Yamaha XS 360
