Originally Posted by
wwhan
Also EPL tunes DO NOT reset the Flash counter, which means every time the ECU is Flashed with a EPL tune update, the Flash counter increments by one.
Not entirely accurate.
First, Ill start by saying weather its a piggie back or a flash... if you modify your car you should be prepared to pay for repairs out of pocket. We've never advertised flashing to stock as a way to circumvent being flagged.
When you flash your car to STOCK with our system, in many cases the flash counter will increment (but not always). As someone stated above is this is the "catch 22" and will likely be an accurate statement for most/many/all of my competitors once they offer port flash (we are still the only one offering this option to date).
When you flash your car from EPL to EPL (updates, map switching) it most likely will NOT increment the flash counter(almost defiantly wont after running the v1.2 update). This was not the case on many tunes our earlier adopters were on, but changes have since been made.
We have several document case of s4/s5's going in for warranty repair or recalls and NOT being TD1'd with a stock ecu after being tuned. We have confirmed many of these cars were actually plugged into and scanned by Audi with information unloaded. This is REAL data and repeatably proven.
Furthermore we have documentation that details SOME (and in fairness I wont say all) of what the criteria is for Audi to TD1 a car and interestingly flash counter isnt mentioned once! If you have facts/documents that suggest other wise I would love to read them.
I'm willing to be fairly transparent on this if anyone has questions.
