Results 1 to 11 of 11
    Junior Member One Ring
    Feb 09 2020
    Dallas TX
    285/30/20 tires vs 275/30/20
    Has anyone elected to run 285/30/20 tires on the RS5 vs 275/30/20? What are your thoughts, has it improved the ride comfort and how do they look once mounted? I am just curious what others have done if you keep the stock wheels .
    Senior Member Two Rings ffearless's Avatar
    May 22 2017
    2007 Tundra, 2017 RDX
    Quincy, WA
    I have been running 285/30/20 Pilot S4s for 3 years. Their traction is really great in the wet and dry. The 285s look aggressive.
    2014 Estoril Blue RS5, loaded, 034 Motorsport X-Brace and rear anti sway bar, CR-15 strut tower brace, Ecstuning transmission and differential inserts, carbon fiber mirror housings, LED backup lights, VAG COMM mods, mid-resonator delete, true dual exhaust
    Established Member Two Rings tattallah's Avatar
    Jun 05 2018
    Los Angeles, CA
    @JaySline I'm in the same boat. I just purchased new wheels, AG M580 20x10 for my 14 RS5 and I am leaning towards Michelin PS4S 285/30 because I don't want the stretched look on a 10" wide wheel.
    @ffearless What size wheels do you have? What is the offset front and rear? Are you running any spacers with the wheels?
    SOLD 2014 Audi RS5 | Ibis White/Black-Rock Gray | B&O | Maxton Front Splitter/Side Diffuser | ECS X-Pipe | CR-15 Upper Strut Tower Brace | 3M & LLumar Ceramic Tint | HAWK HPS 5.0
    May 22 2017
    Quincy, WA
    They are 20 x 10 et25. I'm not running spacers. I have adjustable upper control arms and the top of my tires are pushed out. I have no room to move out more without rubbing.
    Jun 05 2018
    Los Angeles, CA
    Quote Originally Posted by ffearless View Post
    Interesting. I order a set of AG M580 wheels, 20x10 with ET22 front and ET26 rear. The front ET22 was required to clear the calipers and will push the wheels 3mm out more than yours, but I don't have adjustable upper control arms. With the front ET22 and the 285/30 I hope the tire is not pushed out farther than the fender.
    This is a pic of an RS5 with the AG M580 and ET22.
    May 22 2017
    Quincy, WA
    You will be close but should be fine.
    Feb 09 2020
    Dallas TX
    The AG M580 wheels look sharp.
    Feb 09 2020
    Dallas TX
    Quote Originally Posted by tattallah View Post
    Are the Avant Garde Wheels machined to the center bore of the RS5? Meaning no use of hub centric rings to mount the wheels?
    Established Member Two Rings PLAYRZ's Avatar
    Oct 22 2014
    RS5 Coupe (B8.5), TT Coupe (FV)
    Australia
    For reference, I'm running the PS4S in a 285/30/20 on a 20x10 ET25 lowered on KW HAS. Moving from a 275 to 285 required me to remove the top clip/screw holding the inner guard lining as it was just touching over certain road conditions. It's perfect now and no adverse impact (noises, rattles, etc) from removing the clip.
    KW | Capristo | BC Forged | 3M | ECS | K&N | SPC | 034 Motorsport
    Jun 05 2018
    Los Angeles, CA
    Quote Originally Posted by JaySline View Post
    I called AG to ask about the M580 and centric hub. For the RS5 and these specific wheels, a hub centric ring is not needed. The wheels are hub centric with the correct bore size for the RS5 at 66.6mm.
    Jun 05 2018
    Los Angeles, CA
    I don't want to hijack this thread from the OP and make it about my RS5. I have another thread running on AZ https://www.audizine.com/forum/showt...eering-Problem where I was addressing a steering problem and will be posting pics once the wheels are on the car.
