I swapped in some C7 A6 6 piston front calipers and ECS brake lines and after bleeding first with a Motive pressure bleeder, then with the pedal method, I still have a mushy pedal.
I think I messed up when doing the pedal method and let the reservior get too low, introducing more air into the system. (UGH!)
I've been bleeding with the pedal method, both with the car on and off. When the car is running, I was getting air out of the lines every time I cracked them open. Tiny little bubbles that are barely visible, but I can hear the bubbles "woosh" when I crack open the bleeder.
I eventually got it to where no air was coming out of the bleeders, but my pedal still feels like mush.
Research is showing me that I should do the ABS pump bleed procedure in Vag-Com.
Questions:
After I do the ABS pump bleed, what is the correct caliper bleed sequence? I've been doing Rear Right, Rear Left, Front Right, Front Left.
Can I hook up my Motive pressure bleeder AND do the ABS pump procedure?
Can I also hook it up for doing the pedal pump method to ensure that my master cylinder stays full and I don't have to keep refilling it?
My new front calipers have 2 bleed screws. I've been alternating opening them and getting air out of each one in alternation. Good idea to continue that?
What else do I need to do?
I've read a dozen threads that all have different suggestions, many of which are for different Audi / VW models and years, so I'm confused at this point. All help is welcome!
Thanks,
LH
