Originally Posted by
old guy
If that stutter start was indeed with cold coolant I suspect your CTS may be reading incorrectly. I will continue to watch mine closely to see at what temperature the start up protocol goes from a cold start settings to a warm start settings and we can compare.
Ill keep trying over the next few days. I have a feeling it isnt my HPFP and ill send that back if its something else, but you can see the timing difference. That stuttering start was indeed cold coolant. With the timing being that different youre right the ECU might be thinking the car is already warm and fumbles on start because the coolant temp sensor is stuck. If it was the HPFP the timing would still match.
I cant seem to find one on fcpeuro for some reason.
https://www.fcpeuro.com/products/vw-...-vw-06a919501a
I think thats correct even tho the site says it doesnt fit my car... Just ordered one screw it. The timing is a huge difference and make me thing this is the issue.
I went out there a couple hours ago and the coolant temp read 106.6... I just went out a few minutes ago to test it and it said 107... thats about 4 hours of cooling... suspect?
