Originally Posted by
6shift
To be honest, I hadn't heard of JXB before but the video makes a very compelling argument for it. How much of the reduced slop in gear is from the clamp vs the plate? I wouldn't think the plate would have much influence on 3rd and 4th gear slop but its remarkably better than JHM and OEM.
Makes sense you haven’t heard of it, because I just started the company 6 months ago :)
The big slop reducer is the plate and its bushings. The bushings take care of the wiggle when you’re in gear and stops some flex under higher loads. The plate stops the rest of the flex under high load.
The clamp is a cheap way to accomplish the same thing as the other short throw shifters. It doesn’t remove slop; simply reduces throw length more than the JHM and as much as the ECS and Eurocodes.
The plate is compatible with my clamp and any aftermarket shifter. So if you wanted the absolute perfect shifter setup, my recommendation would be JHM shifter + JXB plate + JHM linkage. That’s a lot of coin though, so in my biased but very scientific opinion, the best bang for your buck is to go JXB plate plus clamp and have everything a stand-alone short throw gives you with much less slop for a bit less cost.
