Apologies if this is another post that’s been beaten to death. If necessary I’ll repost where indicated.
Looking to replace all four corners of the wife’s A3 in the coming days and I’m reaching out to you all for some basic information.
I’m about to pull the trigger on the following parts from a local parts distributor here in Ontario.
Front:
Zimmerman 312x25
TRW pads
Rear:
Zimmerman 272x10
TRW pads
Caliper bolts
Front x 4
Rear x 4
515CAD with taxes and delivered.
I’ll be using Carista to retract or set the service position of the rear ebrake.
I have a couple of questions prior to performing the work:
1. Are the front and rear caliper bolts a one time use item? I found some information online but it does not specify the vehicle model etc:
“Front brake carrier to wheel bearing housing is 196NM, always renew if removed.”
“Rear brake carrier to wheel bearing housing is
100NM + 90, always renew.”
I’ve searched online with mixed results, some say to replace and others say not required and to reuse them.
2. What is the difficulty level for the rear brake rotors and pads replacement? I’ve been told they are a complete pain in the ass given how everything is so jammed pack back there.
Given the crap winters here in Ontario it would make sense to replace the rear bolts given the hex bolt design and the accumulation of rust etc.
If the caliper bolts are required then so be it but I also don’t want to be spending money on items I don’t need. The bolts are roughly 5CAD each vs 9CAD at the local VW shop.
As usual I appreciate any feedback.
Please be safe out there given the current pandemic.
Thanks
