Results 1 to 9 of 9
    Apr 15 2009
    PA
    **SOLD** CETE Active Valve Control module for S6
    ***SOLD***
    Exhaust valve controller for C7 platform. Per EuroPrice, fits: '11+ A6, S6, RS6, A7, S7, RS7 (Exhaust Valved Models).
    I had this installed on my 2014 S6 for two months before I traded it in. It was paired with an APR exhaust and did an excellent job controlling the exhaust valves via Drive Select -- loud in Dynamic, quiet in Comfort. This is the non-programmable version that responds to the ESP button -- double-tap the button to instantly close or open the valves. Gives you on-demand control of exhaust noise levels even without switching drive select modes. (The programmable version DOES NOT respond to the ESP button, which is why I chose this version).
    See additional details on Europrice website here.
    $475 with free shipping (compare with $579 with shipping from Europrice)
    2019 Audi RS5.
    Senior Member Three Rings NAYCHURKAL's Avatar
    Apr 15 2008
    18 Dodge Durango SRT
    North NJ
    Pm sent
    Account Terminated Two Rings
    Aug 05 2014
    Panther Black SQ5
    Northern VA
    Did you install and uninstall this yourself? Wondering where this plugs in to in the trunk and where the wire goes down from the trunk to the plug on the muffler.
    Apr 15 2009
    PA
    Quote Originally Posted by J71 View Post
    I did install it myself... only takes a few minutes. PM me your email address and I'll send you PDF instructions.
    Summary: Look on the right side of your trunk, there is a compartment with a mesh basket. Remove it and the compartment cover comes off (no tools required). All the wiring is just behind it. The CETE module connects to the CAN harness in that area -- pins slide right into the connector. There is a body grommet deep in that well -- you can see it with a flashlight. I had a bit of insulation in there that pulls right out. You remove the grommet and CETE module harness has inline grommet that replaces it. Connect to the right OE valve with inline connector. You then run the remaining harness wire across the trunk through the spare tire well, and out the grommet in a similar position on the left side. Connect to the OE valve on the left side and you are done.
    - - - Updated - - -
    Quote Originally Posted by NAYCHURKAL View Post
    Pm sent
    PM replied. Let me know and I'll ship it today.
    2019 Audi RS5.
    Jan 31 2009
    2016 RS7-P
    Love this module, use it all the time to quiet down in the neighborhood or early morning start up (I'm usually always driving in Dynamic). Put car to on without starting it, double tap the ESP button and it will close the valves if you want a quieter start up.
    Established Member Two Rings LQQKOUT's Avatar
    Oct 09 2019
    Omaha, NE
    Sent your a PM
    Sent from my HD1925 using Audizine mobile app
    Apr 15 2009
    PA
    Sold.
    2019 Audi RS5.
    Dec 29 2015
    ATL
    Shameless hi-jack now that this is sold, see my post. I have one too...
    Apr 15 2009
    PA
    Quote Originally Posted by LilRobb View Post
    GLWS! and shameless bump from OP
    2019 Audi RS5.
