Results 1 to 40 of 45
    Jul 13 2020
    Milton, FL
    2016 A6 3.0T APR Dual Pulley Dyno - Before/After
    I had some work done today on my 2016 A6 3.0T. I'm actually a little disappointed in the numbers, but it is what it is. I took the car to my local APR authorized shop. We did a baseline dyno before any modifications. The car put down 262awhp. I thought that was a little on the low side, but figured it might be because its the middle of summer in Florida and its pretty hot/humid. The shop then installed the following...
    ECS Intake
    JHM Heat Exchanger
    APR Dual Pulley
    Stage 2 APR Tune
    The car then dyno'd 344hp. So it picked up right at 82awhp. If my 262whp baseline equates to 333hp at the crank, I'm figuring about 20% drivetrain loss. So the 344awhp puts it about 420hp at the crank. I think that's lower than it should be. Even with as hot as it was.
    Senior Member Two Rings PeytonBrandt's Avatar
    Jun 10 2019
    Neenah, WI
    I’ve heard people say it can take time for the tune to adapt. Maybe try driving it around for a couple days, and then try the dyno again?
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    That’s interesting because I just dynoed my car maybe a month or so ago. I’m just stage 1 apr and intake. Manual b8 S4 and hit 331 awhp consistently.
    Veteran Member Three Rings jcoleman_11's Avatar
    Apr 21 2016
    Toronto, ON
    I mean, those aren’t terrible numbers. I assume you’re on pump gas? 91, 93?
    Jul 13 2020
    Milton, FL
    93. They aren’t terrible. I wasn’t expecting the 390awhp that APR claims...but I was expecting 365-375awhp. The shop forgot to order the colder spark plugs so that was with stock spec plugs. Maybe after I install the recommended plugs it will make a difference as well.
    Feb 10 2019
    New York
    I wouldn’t get too hung up on dyno numbers being low, can always try a different dyno (mustang, dynojet). Adaptation takes time... when I went stage 2 I was around 370whp, then ran on the same dyno a month later in hotter conditions and put down over 390.
    2016 A6 / 3.0T | APR Stage 2+ DP, TB, Intercooler | P3U TCU | W/M injection | Jokerz Port | AWE Intake/Exhaust | JHM Downpipes/Race Cats | H&R Springs | Ferrada FR8 on Michelin PS4s | StopTech Brakes | 034 Mounts | and way too many other things…
    Jul 13 2020
    Milton, FL
    Quote Originally Posted by BobbyWatts View Post
    That’s encouraging.
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    two of the same cars same dyno, same day can put down different numbers. keep that in mind as well
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by paul-g View Post
    Also note that the tune was just installed with no time to adapt. It’s possible your gas was lower in octane than necessary to get the timing advance necessary to hit the best numbers, and, as you said, the plugs hadn’t been replaced. Those “issues” can contribute to lower awhp numbers and the ECU gives instructions based on what it sees..
    I’d bet you butt dyno really feels the extra power on the street in normal driving? Passing, on ramps, etc are more fun?
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    How come in a lot of people's dyno videos after stage 2 I can hear the blower whine, but not in this video? As a stage 2 owner I think that when there is little to no whine, the boost bypass seems to be opening. I see a lot of people say the car is pulling timing, but I don't think so. I have no aftermarket heat exchanger yet and if I drive and floor the car when it is cool outside, after a cruise on the highway, or when the car is barely warmed up, I hear the whine no problem and I still have the factory intake and everything that goes with it.
    Anybody have any boost gauge videos of what it looks like when the engine gets hot?
    Apr 21 2016
    Toronto, ON
    Cause that dyno is louder than anything else in that video. You can’t even hear the exhaust. You can’t hear shit except the rollers.
    Jul 13 2020
    Milton, FL
    Yeah. The dyno rollers were ridiculously loud. The Supercharger whine is very evident when driving the car now, even at only partial throttle.
    Mar 19 2019
    Toronto/Ontario
    Quote Originally Posted by academytim View Post
    So what does your butt dyno say?
    Jul 13 2020
    Milton, FL
    Quote Originally Posted by WatchMeSpend View Post
    There is no doubt that it picked up power. 262 to 344 awhp is around a 30% increase in power...and its noticeable. The power is also definitely much stronger lower in the rpm range. I’ve done a couple of launch controlled 0-90s and it plants you in the seat fairly well. Having had several cars in the past that I’ve run 1/4 mile times ranging from high 11s to low 13s...if I had to guess, it would run low 12s. There’s no question that it picked up power...I guess I’m just questioning if it picked up enough over a basic Stage 1 to be worth all the extra cost. I’ll see how it feels after a couple weeks of driving and after I swap the plugs out. If it feels significantly stronger I might go back and dyno again. If not I’ll wait until the weather gets colder and go dyno again then. I’m also on the fence of whether or not to add a TCU tune.
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    TCU tune will definitely help in regards to acceleration times, wakes up the car really well.
    Sent from my Pixel XL using Tapatalk
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Jul 13 2020
    Milton, FL
    Quote Originally Posted by Dutch_A6 View Post
    What is the general consensus on the best TCU tune for an APR stage 2 car? I contacted Chris at EPL to get pricing. I’ve seen a few others listed.
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Melen TCU had gotten rave reviews, I've got EPL, John Rapkoch also does them.
    Zito ZF01 wheels
    EPL stage 2 tune
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Jul 13 2020
    Milton, FL
    https://www.audizine.com/forum/showt...n-ZF8-TCU-tune
    ^^^That thread sold me on the Melen TCU tune. Apparently night and day difference between it and even the EPL TCU tune. I reached out to him on Instagram and started the process. Thanks for the advice.
    Veteran Member Three Rings Patrick Matte's Avatar
    Jun 12 2018
    old car's: Porsche 911 86 3.6 varioram plus G50, elephant racing track suspension, 996 turbo brakes
    Beloeil , Canada
    Melen all the way
    -Audi A6 2012 3.0T-
    IE Stage 1 93 Oct- Melen TCU : 11.72
    IE Stage 2 dual E40 : 11.05
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Welcome, if I ever decide to spend the money for a second tune in definitely going to go with Melen. Right now tho I've got to many more wants/needs I have to address first.
    Zito ZF01 wheels
    EPL stage 2 tune
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Apr 14 2016
    Austin Texas
    You absolutely need the tcu tune to see all the power, if nothing else the car is still pulling hard up past 7k.
    Sent from my SM-G977U using Audizine mobile app
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Who doesn’t love the smell of a good Dino run in the morning....;)
    Mar 19 2019
    Toronto/Ontario
    Don't know the difference between certain brand of dynos. Was expecting something more like this:
    https://www.youtube.com/watch?time_c...ature=emb_logo
    Jul 13 2020
    Milton, FL
    Melen TCU Tune loaded. Won’t get a chance to test it out until tomorrow. My spark plugs delivered as well so those will be installed in the morning. Been driving it a week now. Hard to tell if any adaption has taken place but the car does feel strong.
    2016 S8+. DS1 Custom Tune by Racebox, Boost Creations Intake, Autotech HPFP Plungers, LPFP Lines, Flex Sensor, btres, berk TCU. 1/4 mile 10.37 @ 134. 0-60 in 2.69
    2016 A6 3.0T Prestige, APR Stage 2 Dual Pulley, ECS Intake, JHM Heat Exchanger, Melen TCU Tune. 1/4 mile 11.37 @ 120.29, 0-60 in 3.36
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    ^^^ you’re going to be very happy with the TCU! Especially launch control
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    May 05 2018
    South Florida
    Log the car and see what your IAT’s are getting to by the end of the pull. You might be pulling timing.
    Mar 19 2019
    Toronto/Ontario
    Quote Originally Posted by killer_s4 View Post
    Does it actually pull timing or bypass boost instead? The more boost the car makes the louder the whine. When my car, with no aftermarket HX gets hot, I can't hear the whine at all (stock intake). After a short run on the highway, the car cools off and the whine comes back for a few hits. Thoughts?
    May 05 2018
    South Florida
    It can do both depending on how bad it is
    Mar 19 2019
    Toronto/Ontario
    Someone has a video with a gauge reading IAT while they are flooring it and the temps go up like crazy. Can't seem to find it on YT. I think it was from an S4 and it had the gauge in the vent.
    Jul 13 2020
    Milton, FL
    I’ll try to do that at some point. Im noticing in the dyno chart that it registers peak HP at like 5200rpm and then practically falls off a cliff after that. I would think with the JHM heat exchanger that it shouldn’t be an IAT issue unless they didnt bleed it properly and there was air in the system. I will say that the few pulls I’ve done in the last week i definitely don’t feel a drop in horsepower past 5200 rpm like the dyno sheet shows. It pulls strong all the way to redline...which is now around 7k thanks to the Melen tune. It also launches so incredibly hard now with the increased launch rpm.
    Dec 02 2011
    well it's been 10 days has the car "learned" like people were saying and getting better?
    Dec 18 2012
    Framingham MA
    What did you set your launch at? Mine is at 2800, wondering if I should move it higher?
    Jul 13 2020
    Milton, FL
    Could be placebo but the car does feel a little stronger. I don’t go around banging off the redline so it’s hard to say. Now looking at the dyno chart and seeing where it’s showing to have made peak HP before dropping off...I do think it was pulling timing. Shop might not have fully bled the system when installing the heat exchanger. Now I’m researching the best way to fully bleed that system even though i haven’t noticed any power drop at high rpm when driving it on the street.
    Quote Originally Posted by ANMS4 View Post
    Mine is set to 2600. Now you have me wondering if I need to request it to be higher.
    Senior Member Two Rings E-SWIFT's Avatar
    May 07 2009
    TDI-Passat, M109
    philadelphia
    How do you contact or order the Melen TCU ?
    2014 A7 Garnet Red Pearl.
    Stop-tech slotted/drilled rotors F/R w/EBC ceramic Pads.
    I.E. Stage 2, Dual Pulley, JHM 187 mm Crank Pulley, Euro-code inserts
    RKX intake w/K&N filter. Eurocode Sway Bar Kit -F/R.,
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Quote Originally Posted by E-SWIFT View Post
    His Instagram is melen_tcu you can message him on there.
    Zito ZF01 wheels
    EPL stage 2 tune
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Jul 13 2020
    Milton, FL
    Yep. Just message him on Instagram and he will send you a link to what you need. Process is pretty painless. You won’t be disappointed
    Dec 18 2012
    Framingham MA
    ^^ The service you will receive is A+++ he awesome to work with
    Jul 13 2020
    Milton, FL
    Quick update. Took the car out tonight with my new Dragy. I’m pretty happy with the result considering it’s still summer down here in Florida and it’s pretty hot and humid. Car did 0-60 in 3.98s and 1/4 in 12.2 @ 113. I talked to the shop and they confirmed that they fully bled the system...however I honestly think the car got heat soaked sitting on the dyno in the 95 degree heat. I think the car might be able to crack the high 11s once it cools off and the humidity goes down.
    Mar 19 2019
    Toronto/Ontario
    I have a factory heat exchanger. The last 2 weeks it has been 90-95 up here in Canada. Only if the car was driven for a few minutes and then floored did I hear the charger whine and get full boost (still have the factory intake/silencer. The temperature dropped for the last 4 days and it is around 70. I get charger whine all the time and the car is noticeably faster. I don't usually drive during the day as I have a work vehicle. I'm torn between getting stage 2 plus and then getting the HE next year or vice versa. Need the trans tune though.
    Anybody that I am on the phone with when I drop the hammer gets their speaking interrupted with me yelling "Whoo Hoo!!" Of course they hear the engine and end up laughing because they know I am enjoying the car.
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    My 2 cents is to do the HX and the pulley upgraded together, it'll be easier that way but I went through all this piece meal and for the HX over a year before I did the dual pulley.
    Zito ZF01 wheels
    EPL stage 2 tune
    Roc Euro intake
    AWE touring exhaust
    APR CPS
