Reviving this thread. A hot summer is coming, here's what happened with the valve core.
I tried to use the tool that maintains pressure while removing the core, but the either the threads on the core, or on port were damaged and the core wouldn't come out. It would thread out a bit, but then bind.
Pulled the core out by forcing it to turn using a pipe wrench. So once it was out I needed to look for the right sized core. I've attached an image of the rough measurements, but amazon showed the dimensions of a core that looks the most similar. It'll take a month to get here, but afterwards hopefully it'll be the last time I'll need to do this.
Thanks for reading!
IMG_20210516_113650.jpgIMG_20210516_113833.jpgIMG_20210516_113944.jpgScreenshot_20210517_083115.jpg
