This is a well-sorted, extremely clean-for-the-mileage RS4, lightly modified with OEM+ sensibilities. It has a clean carfax, and is located in Austin, TX (though not originally a TX car).
update 8/05/2020: car is *SOLD* to Mfiliault
The current asking price is $27.5k.
I've seen a lot of RS4s with similar mileage go for the low to mid 20's, and none look anywhere near as good inside or out. The car is paid off, and I am in no rush to sell.
With that out of the way, here's the important stuff:
Modifications
- OEM Titanium package components (front grille, window trim, trunk trim, mirrors) retrofitted by a previous owner (Ti pkg only available in 2008)
- Stasis/Ohlins Motorsports Coilovers with Swift 14kg/22kg springs and PSI rear weight jacks
- Milltek non-resonated, valved exhaust w/black tips (refinished)
- OEM downpipes w/pre-cats removed (aka piggies)
- Blacked out headlight trim, new lens covers, ZKW-R clear projector lenses, refreshed wiring, clear corners (109k)
- JHM short shifter, intake manifold spacers
- 034 density line motor mounts
- ECS rear diff carrier inserts
- Apikol rear diff mount (red)
- Fresh RS decals on front brake calipers
- RS7 rear caliper covers
- B6 armrest (no phone mount)
- Silver trimmed window/mirror switches (8P S3)
- Custom silver trimmed headlight switch
- AFE dry flow air filter (110k)
- Cupra R front lip
- Custom blue carbon kevlar belt trim (oCarbon)
- Rewrapped TT-RS steering wheel and e-brake handle in Nappa air leather with blue contrast stitching (Drozd Upholstery)
- Rewrapped shift knob and new shift boot in Nappa air leather (Drozd Upholstery)
- Custom 8” touchscreen head unit with Android Auto/Apple Carplay
(though planning to remove this and reinstall the stock RNS-E head unit)
Maintenance
Detailed Maintenance Log
Engine
- Carbon clean, deflapped intake manifold, new injectors, valley pan gasket, oil filter housing gasket, valve cover gaskets, spark plugs, ignition coils (111k)
- Coolant flush, new expansion tank (117k)
- Refinished engine covers
- Installed 034 Density engine mounts (112k)
- Replaced throttle body (111k)
- Replaced MAF (114k)
- Replaced fuel filter (117k)
- Replaced front O2 sensors (117k)
- Replaced suction jet pump (119k)
- Replaced ECU relays (644) (119k)
Drivetrain
- New front axles (Raxles/rebuilt OEM, 110k)
- Replaced clutch disc, flywheel , pressure plate, release bearing, clutch slave (OEM), USP metal slave line (117k)
- Transmission/rear diff flushed/filled with Ravenol fluids (118k)
- Replaced front wheel bearings (118k)
Suspension
- Stasis Motorsports Coilovers rebuilt and revalved Mar 2020 by RE Suspension
- Meyle HD front control arm kit w/red poly bushings (119.5k)
- 034 rear sway bar w/new OEM endlinks (115k)
- Alignment with new rear hardware (123k)
Brakes
- Replaced front rotors (Brembo), pads (Centric posi-quiet) (114k)
- Replaced master cylinder (114k)
- Replaced brake vacuum pump (119k)
Interior
- Replaced all soft-touch surfaces, buttons, switches
- Replaced driver/pass lower A/B pillar trim pieces
- New OEM center console, e-brake handle trim
- Replaced OEM bluetooth module w/later revision (111k)
Exterior
- New OEM windshield (120k)
- Replaced windshield cowl, trim, wiper arms (120k)
- Paint correction & ceramic coat (Feb 2020)
- Replaced front/rear rings
Other
- Replaced AC compressor, dryer, orifice (112k)
- Refinished side mirrors (Ti), pass sideskirt, driver front door sill, replaced driver front door blade (Feb 2018)
- Replaced hood release cable, handle, and hood latch (110k)
- Michelin Pilot Sport 4s 265/35/19 (114k)
- Liqui-Moly 10w60 every 5K
- Engine burns 1qt every 1k mi or so
- Brand new OEM floor mats
Disclosures
- Front bumper
- small bit of corner missing from pass side where it meets the fender
- Was resprayed at some point and clear bra installed (removed 2/2020)
- Rear bumper
- Few scuffs/scrapes across back
- Few scuffs/scrapes at bottom edges near wheels
- Few scuffs/scrapes on diffuser from test-fitting an aftermarket piece
- Rear bumper/trunk trim was painted by PO (part of TI conversion) and some paint starting to wear at edge of strip where it meets the bumper (I'll touch this up with Dr. Colorchip)
- Driver side skirt
- Few light scratches which would probably be removed with more aggressive paint correction
- Pass rear quarter panel
- Some waviness from prior PDR work just below gas cap area, only visible in certain light/angle. My PDR guy said he could make it look better but probably not fix it 100%, and I just never got around to having it done
- Exhaust
- Milltek exhaust saw some northeast winters and shows it
- Cracks formed where pipes go in/out of mufflers, were rewelded
- Has a small leak still if you really listen for it
- Suspension
- Front pass suspension making some noise when turning
- Will have this addressed prior to sale
- Engine
- Consumes ~1qt of oil every ~1k miles, which is average for an RS4
- Cam girdle gaskets are starting to weep slightly, and may need to be replaced a few years down the road
- Engine isn't perfectly smooth before up to temp (not uncommon with de-flapped cars AIUI)
- Trunk
- PO removed SAT radio module and enclosure/storage unit on left side of trunk
Tuning
- ECUs are currently stock (replaced May 2020)
- VIN is licensed for APR and UM tunes
Google Photos gallery
I'll be adding more photos, a better cold-start video, and a full walk around video soon
thanks for your time,
Matt
512.981.6636
