Results 1 to 16 of 16
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    Any good Daytona Grey Pearl touch up paint???
    I got a nice scratch on the side of my car and got Daytona Grey Pearl touch up paint from Automotive Touch Up, but it seems really light compared to the actual paint. Definitely lighter than the stock paint, not great. Has anyone gotten Daytona Grey Pearl touch up that matches the color of the car, and is not too light?
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
    Veteran Member Three Rings GasMan's Avatar
    Jan 13 2019
    Michigan
    I had a local body shop mix me up a pint of paint for some touch up work and it's pretty damn flawless. Wasn't that expensive either, maybe try that?
    2016 RS7 - Gone to car heaven
    2023 Taycan GTS
    Mar 10 2014
    Philly Area, PA
    Quote Originally Posted by GasMan View Post
    Not a bad idea.... local place that did my S4 bumper that was hit, estoril blue, was perfect match
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by PSUGOLD View Post
    The dealer has touch up pens, I didn’t think they were over priced.
    Mar 10 2014
    Philly Area, PA
    Quote Originally Posted by Ford Prefect View Post
    They touched up a couple little dings before I bought the car (used) and the color was very light too on those little areas. Odd all the touch up paint I have seen in this color is at least a shade too damn light.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    I believe pearl is hard to touch-up because it is a process more than just a single paint. Glacier has a similar issue...hard to touch-up.
    That looks pretty deep too... might warrant a professional.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    I’ve had good luck in the past with Dr. Color Chip on BMW, Honda and Audi. YMMV
    Mar 10 2014
    Philly Area, PA
    Quote Originally Posted by gk1 View Post
    May have to...was pretty deep, nicked the rubber pulling into my garage and there was a loose nail coming out and BAM...perfect placement....
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    I've also used Dr. Color chip and had good results.
    Jan 31 2020
    NW Connecticut
    Hello there,
    I'm living this nightmare with my Daytona grey as well.
    I have Dr. Colorchip and paint match color is excellent. However, the process as they describe to dab, smear, wipe doesn't work for me at all. I watched ton of videos and read dozens of forums and basically I remove all the filling I did at the wipe stage.
    I attached 3 pictures.
    The one you see my reflection with a phone, it's before any work.
    The one that is somewhat dark is after roughly 10 to 12 layers of Dr. Colorchip (dab, smear, wipe x12). It basically looked the same.
    The 3rd that looks like bird poop is AutomotiveTouchUp. Completely off color.
    I finally took one of those tiny micro applicator sticks, and wet just a very top of the fibers on the brush. Just enough that they changed color and dabbed it on top of the "bird poop spot". It looks very good but still need to see how it'll hold a polishing stage I'm working on this week (I'm in the process of applying ceramic coating).
    Sent from my SM-G965U using Tapatalk
    Jan 31 2020
    NW Connecticut
    Quote Originally Posted by DoItAllGarage View Post
    Any tips of how you applied it?
    I remove all the filling when I "wipe off".
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by jakubx80 View Post
    Dr. Colorchip is by no means perfect. It's "good enough" for the most part. Especially on dark cars with light primer underneath or plastic painted areas of white cars with black underneath.
    It sounds like maybe you are wiping too hard with the sealer/activator. You go gently...think layer by layer until you remove the smeared paint from the good pain surface then leave it. If you are doing it right it takes a while to get the Dr. Colorchip off of the surrounding area. It will not wipe off quickly if done right.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Established Member Two Rings bryanb8's Avatar
    Apr 10 2018
    NorCal
    I ordered the OEM Glacier White for my last S5 and it was great. Here's Daytona Grey https://www.ebay.com/itm/Audi-VW-Day...YAAOSwJ7RYWuQG
    Current: 2018 S6 Prestige - Glacier White Metallic/Black, S tronic, Valcona Leather, Bang & Olufsen, S Sport Package, Driver Assistance Package, 20" Black Optic Package, Carbon Atlas Inlays, Audi Beam Rings
    Former: 2014 S5 Premium Plus - Glacier White Metallic/Black, S tronic, Nappa Leather, Sports Differential, B&O, Carbon Atlas, Side Assist, MMI Nav Plus Package, 19" 5 seg Peelers, SC badges, all weather package
    Mar 10 2014
    Philly Area, PA
    I fixed it to make it MUCH better... I bought a bottle Duplicolor metallic black touch up paint at a local auto shop, mixed a few drops with the Daytona Grey. Basically I put some grey in a cup, a few drops of black, mixed, and tested a tiny area that was already touched up. Match is MUCH closer, can still see it a little if you look closer, but MUCH better if you do a quick glance. It was very obvious before as you saw in the initial photo, here is one i just took. I didn't clearcoat or polish yet, but MUCH better.
    Mar 30 2018
    long island
    kind of late to help with your problem, but I've used paintscratch for touch up supplies on my Daytona gray pearl. they color was spot on.
    I used a fine-line paint pen to do the touch up for a couple rock chips.
    https://www.amazon.com/Gold-Label-De.../dp/B07N95TXM8
    I used the pre-packaged color and clear spray cans from paintscratch to color match my reflectors.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Active Member One Ring AutomaTom's Avatar
    Oct 28 2019
    East Coast, USA
    @PSUGOLD and daytona rs7
    Both of you are legends. I have a small line of rock chips on my front right bumper/diffuser and this should do the trick. I have Oolong Grey Pearl so kinda in the same boat. Cheers!
    PS: That looks good PSUGOLD.
    2016 Oolong Grey A6 3.0T Quattro S Line
