Results 1 to 28 of 28
    Senior Member Four Rings
    Mar 05 2020
    NewYork
    Good injectors for 2.0t? I see cheap set of 4 for $50 and other sets cast $150...
    2011 2.0T CAEB engine.
    Since I am rebuilding my motor soon im thinking of replacing the injectors since there is a TSB on them. I been searching on here and google for a decent price on a name brand but the prices range fro $50 to $200....
    I will be adding the k04 and a tune soon after the rebuild, does anyone have any good suggestions or experiences without me spending $200?
    I drive a 2011 Audi A5
    Veteran Member Four Rings Traptalk's Avatar
    Oct 14 2018
    Buffalo, NY
    bosch is the oem supplier
    b8 non flex fuel cars latest injector revision is AB
    06H906036AB
    they should be around 50-60$ per injector, obviously the VW/Audi branded bosch injectors will cost more
    tip : fcpeuro.com has lifetime warranty on all parts
    ig: @wastegate_warriors
    i like meth
    Mar 05 2020
    NewYork
    Quote Originally Posted by Traptalk View Post
    06H906036AB
    My car doesnt have flex fuel that I am aware of. Yea Bosch injectors are over $200. That is a little crazy! I bought 8 Bosch injectors for my Dodge ram for $75, that shows that name is why the price is so high lol.
    https://www.fuelfreedom.org/our-work...101/check-car/
    That link says it isnt flex fuel.
    Oct 14 2018
    Buffalo, NY
    Quote Originally Posted by NitroViper View Post
    there is multiple styles of injectors bosch makes, direct injection would probably cost more vs port injection.
    fcp has them for 47$ each and youd literally never have to buy another injector again if one fails
    i like meth
    Mar 05 2020
    NewYork
    Im wondering about the ebay ones for $60 for all 4 with lifetime warranty's.. If anyone has ever tried them or tested their output compared to stocks. I understand Bosch is the best and the most expensive but I was asking about a cheaper solution people have tried lol. Not everyone that ever owned this engine put bosch in at $200+ :p
    Oct 14 2018
    Buffalo, NY
    you're turning your car into more a performance build with a bigger turbo. It might work well stock but who knows when the rail pressure is increased. its a buy once, cry once scenairo to know youll get dependable results using hardware the tune was developed for.
    i have no problem spending a few extra to ensure good results when attempting to push the car well beyond factory levels, fuel delivery is super important and not really an area id cut corners, im not really the stingy/cut corners type tho either, when i replace a part i want to know i wont have to redo it again shortly.
    for me the time i spend doing the installs is worth more to me than whatever i usually spend on the part im installing
    edit : bosch in manufactured in turkey so the odds of buying from a ebay seller in china who can get them direct from the factory is very low, maybe a european seller may have that connection tho
    i like meth
    Mar 05 2020
    NewYork
    Haha thats funny but true lmao
    Mar 05 2020
    NewYork
    I dont need that o-ring kit do it? It adds and extra $30. The injectors would come with o-rings installed id think.
    maybe i can find a 4th of july sale somewhere
    Oct 14 2018
    Buffalo, NY
    honestly, this could be rather interesting
    you might be the first full ebay build if you stick with it, there will probably be some trial and error and hit/misses
    internals, turbo, fueling
    get a ebay suspension, intake, exhuast, and IC and would have a full ebay build
    be interesting to see how would compare to some members with all brand name equivalent parts in terms of power on a dyno and track slips, you are a a5 tho so track times may not be a fair comparison to us a4 guys
    i like meth
    Oct 14 2018
    Buffalo, NY
    new injectors come with both the fuel rail o ring and the combustion chamber seal, however, the 3 prong clips are not inlcuded with new injectors and are easily broken, can just reuse the metal clips that rest over the injector
    edit: can try searching by the bosch parrt number the "62819" i think it is vs using the audi part number. May lead you to some cheaper options
    i like meth
    Mar 05 2020
    NewYork
    rockauto has these for $37 each but they arent the latest? I dont want to end up with issues. Ill probably end up ordering the 06H906036AB im just a cheap a$$.
    BOSCH 62855 {#06H906036P, 06H906036S} High-pressure injector, GDI Info
    https://www.rockauto.com/en/moreinfo...=2157&jsn=2157
    Oct 14 2018
    Buffalo, NY
    appears to be an alternate number bosch uses and is the same equivalent part according to fcpeuro
    https://www.fcpeuro.com/products/aud...sch-06h906036p
    i like meth
    Mar 05 2020
    NewYork
    So they are the same dang thing? That saves $30
    Im gunna keep searching. Im such a cheap a$$! the thing is when you save $20 here, $30 there, $20 here on many parts it adds up fast!
    Veteran Member Three Rings whats77inaname's Avatar
    Aug 09 2018
    Ż\_(ツ)_/Ż Tx
    Do you have a build thread? I'm interested in seeing how things fare long term.
    K04 | Work | Snow/USRT | IE | 034 | Eurocode | H&R | V1 | ECS | Alu Kruez | CR-15 | AfE | Audi | MCP | Misc
    Build
    Mar 05 2020
    NewYork
    Quote Originally Posted by whats77inaname View Post
    Nah, when the cars done ill post what I used and prices and links and updates but right now no because I want information easier to find in the future for users rather than having than comb though 80 pages of a build thread to find one bit of information.
    Aug 09 2018
    Ż\_(ツ)_/Ż Tx
    I can appreciate that. You could also devote the first page of a build thread to a parts list, then you edit it with the part, price, link, etc, broken down into categories as you go along. Might make it easier than having to keep track of parts and document everything at the very end.
    Mar 05 2020
    NewYork
    I will do that when the car is done. Another problem with a build thread is asking questions. You get answers much faster if the threads are separate and people years from now will find them much faster. Even tho some people like to complain in threads the answer is still much easier to find in the future when a post is dedicated to a certain subject. and not 50 in one thread that a search will never find.
    Feb 15 2016
    Cambridge,Ontario
    Interesting build... you will.have to call.it.
    " the cheapest shit I could find build"
    Will be interesting to see if it holds up compared to brand name parts
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Lol this guy is a cheap fuck...buys chinese turbo,buys chinese ebay parts, I'll see 10 threads a day once this is all done. having underboost codes, knocking on startup, then my engine blew up. deadddd
    Ivan
    Mar 05 2020
    NewYork
    Quote Originally Posted by dalmation53 View Post
    Dude dont you ever shut up? lol, always have to put your dumbass 2 cents in... you're the one that sent the ebay link to begin with dumbass. Keep your 15 year old comments to your dumbass self.
    I love getting PM's from members telling me what a jackass some of you are.. You are one of the most commented on lmao... Id post them but I actually have respect for some people here. If you knew what people PM me about you and 2 other members youd probably leave the forum haha.
    Oct 14 2018
    Buffalo, NY
    on a real note tho, you should probably seek out professional assistance before attempting to time the motor, especially if its you're first time working on a euro.
    that could cause some expensive head work if mistakes are made.
    i like meth
    Mar 05 2020
    NewYork
    I actually went to an IT school for mechanics, Ive built many motors over the years. Just because I try to save money doesn't mean I don't know what Im doing lol. Actually just finished taking an engine out of a 2014 CRV, putting a new transmission in and changing the headgasket for a dealer... they put in the cheapest parts as possible as well thats for sure.
    Ive built so many 3000GT VR4 engines I cant even tell ya.
    I bought the Bosch injectors tho from fcpeuro, they gave me 10% off for first time buyer.
    Feb 15 2016
    Cambridge,Ontario
    I actually was being serious. If he goes this route and it ends up being robust maybe we can all learn something.
    Personally I would not want to risk doing a job twice or having a cheap shit part destroy my build, but everyone's risk tolerance is different.
    1976 Yamaha XS 360
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    I think you will be good with this combo, at the very least you’ll never have to pay for injectors ever again.
    Depending on the status of your current coils you might want to pick up some from them as well.
    Feb 15 2016
    Cambridge,Ontario
    I can't remember if i told you about the b8.5 refresh thread but it is picture heavy and gives a good idea on the build.
    I rebuilt practically everything
    1976 Yamaha XS 360
    Mar 05 2020
    NewYork
    Quote Originally Posted by JLAllroad View Post
    Yea you cant complain with a lifetime warranty. I doubt they will ever fail tho.
    Oct 14 2018
    Buffalo, NY
    Apparently Fcp will take back used oils and filters under warranty too. Perfect option for people like nitro
    i like meth
    Feb 15 2016
    Cambridge,Ontario
    For some reason this car is very hard on coils and Injectors.
    Likey because the coils see heat bolted to.the engine and injectors are right in the combustion chamber.
    These things will fail. Especially if you are building beyond stock..
    Just be aware that this could happen
    1976 Yamaha XS 360
