Results 1 to 4 of 4
    Established Member Two Rings jpjmustang's Avatar
    May 23 2013
    2014 Audi Q7 TDI - 2011 BMW 328I
    Missouri
    2010 - 2014 Q7 towing package
    Looking at purchasing a Q7 to tow - I would like to have the increased towing capacity
    If I purchase a Q7 without the towing package - ad would like to add it myself - what needs to be added
    I have seen a couple of places that its hitch - brake package/module and different cooling fans - Is this correct?
    If so - is there a place to buy the package?
    JPJM
    [B]JPJMustang[/B]
    2014 Audi Q7 TDI 3.0 Prem +
    2012 Audi A6 3.0T Prem +
    2011 BMW 328i
    2004 BMW X3
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Adding in an OEM tow package is very expensive, and just adding an aftermarket hitch will be a pain as all the electronics on the car will not know its there. The factory package adds in a bigger intercooler and fan for gassers, and a bigger fan for diesels, all the wiring up to the front for a trailer brake controller, 7 pin plug for the trailer out back as well as all the coding changes to several modules so once you plug in a trailer the car knows it.
    Save yourself the headache and buy one with the factory towing package, most have it anyway, also if you tow a lot air suspension is awesome, it will load level once you hook up the trailer.
    Please Drive Right
    May 23 2013
    Missouri
    Thanks for the input - do you have a engine recommendation?
    I have the 3.0 TFSI in the wife's A6 - like it so far
    [B]JPJMustang[/B]
    2011 BMW 328i
    2004 BMW X3
    Jun 02 2008
    I spent months looking for a TDI with the options I wanted then bought an 2014 S-Line Gas. Everyone says the TDI is the way to go if you are going to be towing regularly, but I have never towed with one myself. I test drove a 2010 TDI with the 6 speed and that low end torque is awesome, I'd imagine it's even better with the 8 speed if you are looking for a facelift model (2011+). Also in 2013 the TDI's got the second gen 3.0 TDI which has more power and better mileage.
    Please Drive Right
