Picked up the car for $2000 with quite a few mods already(SRM K24 RS6 Turbos, SRM Side mount ICs, 034 Motorsports 85mm Maf housing, XSPower inlets & BiPipes, EvoMS Billet Diverter Valves, walbro 400 fuel pump, hotchkis swaybars F&R, Stop tech BBK and Volk LE-37 wheels. This car was as a steal!) And the best part is is is a 6 speed manual.
The bad things were the car was super slow, it has 200,000 miles on it, and it was throwing misfire codes, and the rear suspension would sag after it sat overnight(typical allroad airbag problems). One other thing I didn't like was the nasty brown/tan interior
Current mod list:
Engine:
-034 Motorsports TBB
-OEM BW RS4 K04 turbos
-SRM Side Mount intercoolers
-SRM Inlets
-EvoMS Billet Diverter Valves
-EV14 850cc injectors
-Walbro 450 fuel pump & XS Power drop in adapter
-Billy Boat Catback Exhaust
-XS Power Catless Down Pipes
-XS Power Charge Pipes
-034 Motorsport 85mm MAF housing
-K&N Drop in Filter
-Bosch 3 bar MAP sensor & Adapter
Interior:
-Black interior swap(Prefacelift, so no more soft touch crap)
-Custom Guage Cluster Faces
-Color MFD Cluster Display
-B5 S4 3 Spoke Sport Steering wheel
-B8 S4 Alcantera/Leather Front Seats
-Pioneer double din
-Brushed aluminum wrapped wood trim(Avery 812-X)
Brakes:
-Porsche Cayanne 18z Calipers
-Brembo Drilled Rotors 350x32mm (Brembo part number: 09A95821)
-Stop Tech Stainless steel brake lines
Drivetrain:
-Ringer Racing Stage 4+ Clutch kit
-Aasco steel single mass light weight flywheel.
-Metal Clutch Slave upgrade
Suspension:
-A6 Bilstein Coilovers
-Hotchkis swaybars F&R
Wheels & Tires:
-VMR 702 19x9.5+22
-Michelin Pilot Sport 4S in 255-35-19
