    Active Member One Ring AK034S4's Avatar
    Sep 03 2018
    Range Rover sport, Land Rover disco, Smartcar
    Fairbanks
    Lightbulb 80mm hemi throttle body adapter plate and harness adapter?
    I came upon an almost free, almost new 80mm hemi throttle body but I'm having trouble sourcing the needed adapters and wiring harness.
    Suggestions? Who makes the plenum adapter and harness for an 80mm hemi?
    I already have the needed software as I'm 034 dual pulley and have the throttle body files. I had heard iabed industries but it seems like they have kits for the 75 and 82 mm throttle bodies and I don't seem to be able to access their main web page/catalog all week?
    Thank you in advance!
    Mar 03 2017
    2019 SQ5, 2001 S4 K04, 1990 Coupe Quattro S2 clone
    Saugerties, NY
    iabed
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Quote Originally Posted by emrewawa View Post
    iabed
    I don’t believe that iAbed sells anything for the 80mm Dodge TB.
    Feb 16 2019
    miami, fl
    iabed
    iabed is for the porsche throttle bodies that just need an adapter plate
    for the hemi tb you need an ultracharger or integrated engineering "boost noodle" that will bring the hemi tb out and away from the audi oem mounting point so that it will fit, and your intake tube will likely need to be shortened to compensate.
    you could call them and see if they will sell just the adapter plate/tube thing, but they might not. afterall why sell a $200 part when you can sell a $1000 package....
    https://performancebyie.com/products...de-audi-30t-b8
    if you do your research you should be able to find what the oem female connector for audi throttle body wire is and the male connector for a hemi tb and get the pins wire and a crimp tool and put it together. you also have to have a tune for that throttle body, ie, 034, and apr make them, not sure who else, cause the hemi tb does not read or react at all the same as a VAG tb. iabed sells an active cable that converts the porche tb signals to audi so that they are interchangeable regardless of tune. that can't (or at least hasn't) be done with the hemi tb. i guess all things are possible but again why go that route when a simpler adapter plate lets you use a porsche 82mm tb.
    also, you can lose hp going to the 82mm size tb compared to 75mm tb unless that is the chokepoint, which is why i went 75mm.
    ie, unless you are running a ported blower don't go 80mm tb
    Feb 03 2019
    Ohio
    Haha. Boost noodle.
