I have a 2004 Audi a6 2.7t, with 161k miles on it, I've done all the routine maintenence on it since I got it and it has been great so far.
Recently: I went out in the morning to start my car, and it would just crank and not turn over. Spraying Starter fluid into the airbox starts the car right up and I'm pretty much good for the day as long as I start it up here and there.
I have ordered: VOD Fuel Pump, and Bosch Fuel Filter which come in next Weds from ECS tuning.
I believe I have the stock original fuel pump in there as well as my fuel filter is most likely the original.
I have no problems with the car when I start it with starter fluid it runs at fuel power and normally, I also do not have any error lights or check engine lights, there is seemingly nothing wrong with my car once I get it going.
Now, I would like to ask if I'm on the right path with the fuel pump and fuel filter replacement.
There isn't any long term damage if I use a little spray of starter fluid temporarily to get me going until next Weds when I'm going to install the new parts?
Any help would be most appreciated .
Thank you,
Anthony
