I got my H&R springs in yesterday and I started the install process today. I watched a couple videos and one of them mention the upper control arm pinch bolt might be hard to remove, but I had no idea just how hard. I don't think there's a whole lot of rust because I can turn the bolt both directions with a 3/8 ratchet. I hammered the bolt until the nut end was flush with the aluminum knuckle or whatever its called. I've tried to get a punch (a small old 1/4 extension because I don't have an actual punch) but I can't get it to slide into the knuckle at all. I've drenched it in PB like 6 times today just hoping it'll help it budge. I'm not sure if the knuckle had threads but now it definitely doesn't. My current idea is to go out and buy an impact, and have a friend try to punch it out or pull on the head while I turn. Anyone have ideas to get it out since I don't think mine is the normal corrosion, but just stuck.
