Results 1 to 14 of 14
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Scratched front parking camera lens
    So it looks like my front parking camera lens is scratched from high speed encounters with either road debris or insects. I regret not taking time early on to find a suitable protection film for this one part. Unfortunately you can see the scratches on the image on screen. It is more of a nuisance than an actual problem since you can still see everything you need to see to park or avoid obstacles, but still.
    Has anyone had any luck polishing scratches out of it and if so what product or process was used successfully?
    FWIW I've determined it appears to be a glass lens and not plastic like I initially thought.
    Thanks
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    A quick Google search points a lot to using toothpaste and some elbow grease. I have never tried it tough.
    Aug 24 2014
    Newport Beach, CA
    I would polish it by hand, and start with a mild polish and microfiber towel first to see how the lens responds. You can always get more aggressive polish including glass specific polish if a mild polish doesn't improve the clarity.
    2024 M3 Comp xDrive
    Established Member Two Rings bryanb8's Avatar
    Apr 10 2018
    NorCal
    Very sorry to hear that. I've heard of it happening a few times. This does bode the question. I there something out there (or does anyone make) something that will custom fit over the front camera? Something like an eye contact shaped lens cover ish. Maybe a precut PPF piece. Yes, you could cut your own, but wondering of simple stick on.
    Current: 2018 S6 Prestige - Glacier White Metallic/Black, S tronic, Valcona Leather, Bang & Olufsen, S Sport Package, Driver Assistance Package, 20" Black Optic Package, Carbon Atlas Inlays, Audi Beam Rings
    Former: 2014 S5 Premium Plus - Glacier White Metallic/Black, S tronic, Nappa Leather, Sports Differential, B&O, Carbon Atlas, Side Assist, MMI Nav Plus Package, 19" 5 seg Peelers, SC badges, all weather package
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by bryanb8 View Post
    Yeah, Id love to know as well.
    18 S6
    Junior Member One Ring
    Jan 27 2020
    South Central MA
    If you wax it, it might fill in the scratch enough to make it not noticeable anymore.
    Aug 06 2014
    NJ->CO
    Yeah I tried waxing, and no luck. I also wanted the "contact lens" type of protection, but I fear it does not exist.
    I am about to try glass polish, but just wanted to see if anyone had any luck with a specific product. I had planned to use polywatch when I thought it was plastic, but after finding out it is glass I'm not quite sure what I want to us as their glass polish produt is not as well reviewed as the plastic polish.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    May 29 2018
    Dubai
    I've tried cutting compound, followed by polish using an electric polisher. No joy!
    I also tried with a headlight restoration kit (3M). Again, no improvement at all.
    I just gave up.
    Sent from my HD1913 using Tapatalk
    Nov 27 2018
    Valparaiso, IN
    Once you get it fixed to your satisfaction maybe try making your own protector. I was thinking maybe you could get cellphone screen protector and carefully cut the needed round sized "patch" for the camera.
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    I had some scratches on my suv windshield from something embedded in the sponge/squeegee at the gas station. Was able to get it reduced with a glass polish from griots garage. It was improved so I didn't go to anything more aggressive. There are a lot of products out there. Maybe some of the car detail guys can chime in.
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Mine is a bit screwed. I assume that the outside is glass or sapphire. I didn't try to fix it yet, but I do like to restore and repair watches. I fixed, well improved a sapphire watch crystal a lot. How? Dremel, felt pad and diamond paste.
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by WatchMeSpend View Post
    Yeah something like that was what i was thinking maybe. Do you have a recommendation on a paste to use? I saw one video where they used jewelers yellow rouge on a watch crystal. Would that be similar?
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Mar 19 2019
    Toronto/Ontario
    Quote Originally Posted by gk1 View Post
    I wouldn't recommend jewelers polishing compound. Why? Because I tried it first before I bought the diamond paste. I have the full set of Dialux polishing compounds at my disposal, so I had them all to try. I ended up buying the 7 piece diamond lapping paste from Kent Supplies on Amazon. The other stuff would have taken decades to work if it even worked at all.
    The Dialux could have worked on a simple mineral crystal or something like Hesalite, but the sapphire crystal on the Bulova I was refinishing was sapphire.
    If anybody is interested in getting scratches off their clear displays and I suspect piano black plastic purchase "Polywatch".
    Junior Member Two Rings
    May 09 2017
    Minneapolis, MN
    I tried a dremel and some jeweler's rouge and my front lens still looks like crap. It looks like it's got water on it. I'd love to replace it and if I do find a way, i'm going to have it coated with PPF.
