I had heard a slight whistling that would change pitch under boost (sounded like a/c refridgerant moving in a home air handler). Ended up doing this:
Replaced with latest AH. I found a decent amount of oil in the connector from the PCV/Combi to the Pre-turbo hose. Upon test drive, no longer had the slight whistling and low end power (butt dyno, possible confirmation bias) below 2500rpm had increased.
I hadn't seen this shared, so:
Just need a T30, some cleaner+rag for the gasket surface, maybe a magnet, and a torque wrench. Takes about 20min max. For anyone that is DIY, make sure to remove all the screws before you remove the PCV. Accidentally dropping them in the engine would be a nightmare. Hose connectors are quite easy, just take your time with them. I re-oiled the o-rings to make installation easier.
