OEM taillights have the same quality and function as genuine taillights from Audi but without the markup that Audi imposes which allows for lower pricing...
- OEM Equipment and Function
- Proper Rest of World Functionality
- Discrete Orange Turn Signals for Added Safety
- No Ugly Standard Blinking Brake Light with Turn Signals
- Missing Rear Fog Light can be Activated with Switch and Wiring
- Packages Available for All Models (Coupe, Cabriolet and Sportback)
- Exclusive Packages for North American Models
- No Problematic Coding Dongles or Replacement BCM2 Modules
- Wiring is Required for Installation - Wiring Components Included
- VCP (Vag Can Pro) is required for setting proper functionality
- VCP (Vag Can Pro) is available at a discount as an option to add to package
Also available are the dark and clear blackline taillights as well:
TAILLIGHT PACKAGES | A5, S5, RS5 LED BLACKLINE (OEM) - $999.00 set
Information:
Original equipment manufacturer (OEM) European LED taillights with discrete sweeping turn signal functionality. All functions are separated allowing for the orange turn signal to sweep on it's own. Taillights are combined with the needed wiring components to allow for a seamless installation for North American models. Instructions are included for wiring installation to each outer taillight and inner taillight if the fog light function is requested along with headlight switch installation instructions as well. VCP (Vag Can Pro) is required for proper functionality and step by step instructions are included to set the proper parameters, plus VCP is available to purchase at a discount with the taillight package. Step-by-step instructions on how to use VCP to set the proper parameters are also included.
Questions:
If you have any questions or other needs please post here, PM or email: [email protected]
Thank you,
