Originally Posted by
dalmation53
After chasing down misfires in my own car you need to pay attention to what cylinders are misfiring.
If only one cylinder is misfiring it is most likely something mechanical on that one cylinder (ie plug, coil, injector) moving those parts around to other cylinders should move the misfire with it to a different cylinder.
If all 4 cylinders are misfiring then you need to look at what’s common between all cylinders (ie timing, fuel delivery)
For example if your low pressure in tank fuel pump was dying and failing to prime and supply enough pressure to the hpfp than the rail pressure will be low for all 4 cylinders and they should all misfire randomly
The fact that this is on cold start would point me to the lpfp. Almost sounds like the prime is weak and losing pressure when it sits over night or an extended length of time and fuel leaks back into the tank.
Look at your hpfp actual vs request since we can only watch lpfp request (no low pressure fuel sensor). Can also trying to install a fuel gauge between metal hard fuel line and the hpfp and see its flowing
