Results 1 to 17 of 17
    Oct 02 2006
    Wadsworth,OH
    NEW Big Bore Cast Aluminum Turbo Inlet Pipe Audi B9 3.0T!
    Ditch that restrictive plastic turbo inlet pipe on your B9 S4/S5 3.0T and upgrade to our brand-new Big Bore Cast Aluminum Turbo Inlet Pipe for a 16.8% increase in airflow and improved performance. Our R&D team proudly developed this inlet as yet another incremental piece to the performance puzzle, making slight improvements over Audi’s already incredible design. Add an artfully crafted and meticulously designed upgrade fresh from our talented in-house team for an increase in your enjoyment behind the wheel.
    For your Audi B9 S4/S5 3.0T (2018+)
    Audi B9 S4/S5 3.0T Big Bore Cast Aluminum Turbo Inlet Pipe
    Jul 05 2018
    Chicago/IL
    Is it compatible with factory accordion intake pipe or do we need to replace those too?
    Aug 13 2008
    Reston, VA
    Willing to test this on RS5 if you want a Guinea pig
    Established Member Two Rings gpm24780's Avatar
    Mar 16 2019
    2017 Audi Q7
    ROYAL PALM BEACH
    This is a good upgrade. I purchased and installed it on my S5. My comment would be that the install is not as easy as indicated. The bottom hex/torx bolt is very difficult to remove unless you have the right wrench or right angle bit adapter to get in there with. The oil filter housing and inter-cooler piping make it very difficult to get any leverage and maneuver. I don't recommend this but I ended up cutting off the plastic piping using a multi-tool to have the room to remove the bottom bolt. Attaching it was not easy either. Just my experience and I hope it was easier for others. An install video from ECS may have helped make the process smoother for novices like myself. All-in-all a good part though and a noticeable difference in my opinion. Their is definitely more air-flow happening. You can feel it and I notice that it just feels smoother as it accelerates to red line. Like the car is breathing better. I installed the racingline filter replacement in the stock air box and noticed even more difference.
    Mar 16 2019
    2017 Audi Q7
    ROYAL PALM BEACH
    Hey ECS... quick question... is your ECS Inter-Cooler compatible with the B9 S5. According to your website, "It Does Not Fit." Is there a reason why if S4/S5 share same engine? Does it have anything to do with the frame up front? If it is compatible, I intend to purchase it.
    Veteran Member Four Rings z_wrecker's Avatar
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    Any plans to release this in black?
    2018 Alfa Romeo Giulia Quadrifoglio
    2014 Arctic White B.O. S5 Prestige manual w/ sports diff
    2002 Arctic Silver Metallic Boxster manual
    2018 Daytona Gray Q5
    2018 Daytona Gray B.O. S4 -Sold
    2009 Pearl White Ducati Monster 696 with Termi race kit, and a bunch of CF -Sold
    2008 Ibis White A4 s-line manual -Sold
    Senior Member Three Rings Valentino S5's Avatar
    May 26 2019
    Mexico City
    Just ordered mine !
    2019 S5 Coupe Mythos Black. EPL Stage 2 ECU+TCU. APR Intercooler. APR Ignition Coils. AWE AirGate Carbon Intake. Red Star Downpipe HJS 200cpsi. VPS Pre Muffler/Front Resonator Delete. ECS Big Bore Cast Aluminum Turbo Inlet Pipe and Silicon Turbo Inlet Hose. Pedal Commander Throttle Control System. 034 Motorsport Lowering Springs, Front Strut Brace & Transmission Mount.
    Jul 09 2020
    New York
    Does anyone have any tips on how to get the bottom screw out of the inlet? I was using a flex drive but I still wasn't able to get to it.
    Sent from my SM-G973U using Audizine mobile app
    Mar 16 2019
    2017 Audi Q7
    ROYAL PALM BEACH
    Very difficult to remove. I ended up using a multi took to cut the plastic inlet pipe off so I could get to the bottom screw. I figured, I'm not going back once i put the new inlet pipe on. I then used a pair of pliers to grip the torx bit and tighten slowly. It was a real pain in the @$$. I also unscrewed the top of the oil filter cap to allow for a little more room to work with. A local auto store more thank likely sells the torx key sets which I picked up cheap at an Ace hardware for $5. Wish I had it when I started the removal process. Would have been easier.
    Veteran Member Three Rings S4_Pedro's Avatar
    Sep 17 2012
    Union
    Any plans to release turbo muffler delete a lot of guys want to buy just that. I can send an email and confirm how many serious buyer I have.
    May 26 2019
    Mexico City
    Update:
    I took my S5 to my Audi Dealer to have installed the ECS Big Bore Cast Aluminum Turbo Inlet Pipe and their Silicon Turbo Inlet Hose. After doing 5 or 6 pulls I can tell you that I could feel immediately the benefit of installing them. It’s like the Turbo is breathing so much better, and that traduced in a very positive way on how it pulls from mid to upper revs. I’m Very happy with it !
    Jul 09 2020
    New York
    FYI- After much pain and busted knuckles I found that Lowes had a Kobalt mini ratchet set with a closed back end. This took the job from more than an hour to less than 15 minutes in and out. If you're going to do this install I HIGHLY recommend finding yourself a mini ratchet with a closed back end. This will allow you to work much faster as you can push on the fastener to get the thread started. I also found that using a flat head screw driver to apply some friction on the head of the fastener helped when there is no preload on the bolt.
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    Quote Originally Posted by Turbo6S4 View Post
    That’s a good tip. I have one of those tiny ratchets that uses screwdriver bits. I seem to use it more than anything else I own . It was only $5 on Amazon
    Junior Member Two Rings
    Aug 15 2019
    Ohio
    Can you by chance supply a link to what tool you're referring to? Mine comes tomorrow, a 1 hr job will be 4 for me.
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    Quote Originally Posted by Rmont07 View Post
    Something like this! It’s a life saver.
    Jul 09 2020
    New York
    Apparently the one I got from Lowe's is not on their web site. I found this on Amazon which looks similar.
    https://www.amazon.com/dp/B07L4NY9R4..._aLzoFbPW8VP0PScreenshot_20200816-164213_Amazon%20Shopping.jpeg
    May 13 2015
    Georgia
    I just installed it about an hour of work with a mini ratchet. The bottom hex bolt sucks so bad! I wish ECS would had provided a better bolt for the bottom where a tool would be easier to grab it. Also the rubber grommet that comes with it would not adjust on the pipe, had to put some clear tape to hold it together until i had enough of the screws in. I did notice harder pulls once installed.
