- Replace Thermostat {ecstuning $54}
- Replace Water Pump {ecstuning $185}
- Replace Coolant Tube {Coolant Pipe ecstuning $126}
- Replace PCV Valve {PVC Kit ecstuning $162}
- Replace Engine Mounts ( installing the 034 Street Density ones )
- Install Mertop Headers
- Install Right angle 02 sensor (two Vibrant 11619 J-Style Oxygen Sensor )
- Change Supercharger Oil
- Carbon Clean (will be checking the valves )
- Replace Spark Plugs
- Rear Main Seal
- Inspect and clean MAP sensors
- Replace all pulleys (including tensioners)
- Replace Head Gaskets
Not sure about these ones
- Replace Coil Packs with RS ones
Decided not to do these items
- Replace Timing chain and guard (not needed with a new engine) {Kit from ecstuning $613 USD}
- Replace Timing Chain Tensioner, decided too much labour
- Injectors {set of six $926.04 USD} can be cleaned instead of getting new ones for $45 each
What does everyone think?
