    Apr 22 2020
    Hints for B pillar trim removal?
    Need to remove headliner, now trying to remove B pillar trim piece. Bentley shows two clips and says to "unclip", but as I pull it, it's cracking where the plastic wraps around.
    Any advice?
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Yeah, they're all going to crack like that... unfortunately. I like to get my finger(s) behind the top of it by starting off at the top-rear-side and sliding my fingers toward the middle, then get my fingertips near the clip locations and pull straight out. Before putting it back together I squeeze the metal clips together a bit with pliers to reduce the effort it takes to remove the B-pillar trim the next time. In fact I do this with all of those metal clips.
    2001 Corvette (C5) Z06
    Veteran Member Three Rings harryn's Avatar
    Dec 03 2016
    2021 Audi A4, 2000 Audi S4, 1995 BMW M3
    They shouldn't crack. Just remove the rubber seal pressed against the B pillar and lightly, using a plastic trim tool, loosen the b pillar, working up to the top corners of the b pillar. Lightly, using an angled trim tool on the top corners of the b pillar, push outward to dislodge the b pillar.
    If that doesn't work, you can, with some dedicated effort, lift the headliner out of the b pillars without having to remove the b pillars. I have never gotten this method to work personally, but apparently it can be done
    Apr 22 2020
    Thanks to all for the answers. Following Hiduke's link, I was able to get them released with minimal damage (there were already some cracks that may have gotten marginally worse). Actually I found it easier to pop both the clips from the same side - once one side was loose, I could gently pull it back and see where the second clip was and get the screwdriver in the proper place.
