Results 1 to 4 of 4
    Junior Member Two Rings
    Jan 20 2020
    Central NJ
    22" wheels with 285/35/22 Tires
    Hello All!
    I must have read through the wheel and tire thread a thousand times, and can not figure out if anyone has yet to successfully run the larger ( taller and wider) than OEM setup.
    Im looking to run a 22" wheel ( Most likely the Rohana RFX11 22x10.5 ET35) with the Conti DWS06 285/35/22 tires. Im figuring it'll stuff a little more tire to clear some of the gap ( I have the air suspension anyway) and close comps to the typically run 21" wheel and 295/35/21 Conti DWS tires.
    The Numbers result to a .4" smaller width over the 21" setup above, with a .8" taller height. The main thing for me, is having some meat on the sidewalls ( as I chase a snowstorm every now and then) so its a 3.9" sidewall (on the 22s) vs the 21s with a 4.1"--so just about the same.
    Anyone have any luck on either their Q5 or SQ5?
    2020 B9 SQ5: Prem Plus, S Sport, Fine Nappa Leather, Bang and Olufsen, Carbon Atlas, Black Optics
    AWE Non-Res Exhaust/ Intercooler/ Airgate Carbon Intake
    ForgeMotorsport Vented DV
    JB4 Tuner
    Airmatic Lowering links
    RS style grill
    VFF 103s: 21x10 ET30 (Brushed Titanium w. Red centers) on Conti DWS 295/35/21
    2012 B8 S4: Prem Plus, 6spd, Dual Pulley Stg 2, AWE Track Exhaust, RocEuro Intake, SOLD
    Veteran Member Four Rings Chris.green's Avatar
    Aug 09 2017
    Atlantic Canada
    A 285/35 will not fit unfortunately. You can’t exceed 29.3” diameter due to the upper control arm clearance.
    Your best options for 22’s will be 265/35, or 295/30.
    The 265 will give you the most sidewall that really possible if that’s what you are looking for.
    2020 SQ5 | Glacier White Metallic
    BC Forged TD03 | CETE Lowering Module | Forge DV
    034 Transmission Insert | CTS Turbo Inlet
    AWE Coldfront | RocEuro Intake | 034 Strut brace
    IG: chrisssgreenwood
    Jan 20 2020
    Central NJ
    Quote Originally Posted by Chris.green View Post
    Thanks for the insight man! Time to dig some more!
    JB4 Tuner
    RS style grill
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    Look at running 285/30/22.... that should work. Or 295/30.
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
    2022 Audi Q8 3.0T Glacier White
