I used the 2x4 method. I wasnt into taking any acle bolts outs. Mainly because it was way more work. Lol. It's not hard, but slightly teadious i guess. This was the first car i have owned with this design of suspension, and it was hassle free. Other than a stripped end link, but thats just how thing go sometimes. The spreader tool made it easy. It took some wiggling and jiggling to make the night complete, but once the knuckle is out of the way, its cake. And since you are replacing everything, you'll have it all together (strut, spring, and mount) ahead of time so you can just swap the new stuff right back in. Rears are really easy. The 3 clips on each liner came off easy with a trim removal tool, idk how they should really come off though.
There is an evap canister on the rear passenger side that needs to come out to remove the shock. MINE i had to undo the bolt at the bottom, pull the bottom out to release the clip, lift it up, and push it inward to release the hook and pull down. You'll feel where it is from above. It's a little tedious again lining up the holes to get the bolts back in the control arm and dont mix the big ones up. The longer ones are for the shocks, the shorter are for the knuckles. I found it best to do endlink first, jack it up a bit and get the knuckle in, and then raise or lower to do the shock. You'll need to manuever the control arm front to back also while jacking to lime everything back up though. Unfortunately i had to do it 3 times in a week and a half, so it got easier each time.
But dont psych yourself out. Watch some videos a couple more times for whatever method you decide on, and take your time. If need be ask for some help here, or even one of the fb groups. But if it helps, its only 5 bolts per corner once you get all the covers and whatnot out of the way.
Sent from my SM-G988U using
Audizine mobile app
