Page 1 of 3 123 LastLast
Results 1 to 40 of 89
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Thumbs up MaxxECU Audi Master Thread & Registry
    Currently working on thread.
    6-24-2020
    I've elected the B5 S4 forums for the master thread as appears the most active & dedicated to aftermarket. There will be multiple Audi platforms here, to share information. In an attempt to streamline the thread please keep general comments to a minimum, if you're a wealth of information post away. I'll attempt updating this 1st post, opposed to ~4 pages of questions. Please use the following format in bold when posting so we as a community know what platform you are
    2008 B8 A4
    Bla, bla, bla, bla....
    Audi MaxxECU Registry: PM me only & I'll update the thread,
    opposed to pages of people informing me they're using it clogging up the thread : Username, year, platform, brief engine description, duration of usage
    MaxxEcu Registry:
    1) A1 A2 German, '97 Audi A4 B5, Comp 5152 2008cc 1.8t stroker, 0 time of using kit.
    2) Mikeb17, '00 Audi S4 B5, fully built 2.8 heads, top mount GTX2860RS, fully built bored 2.8 motor, 830 whp & 750 ft lbs torque. Using since November 2017.
    3) Meow, '00 Audi S4 B5, 2.7t with rods only & custom single turbo, 0 hrs run time.
    4) Xdewaynex, '99.5 A4 B5, built 1.8t HX35, 0 hrs run time.
    5) SlowrideBC, '00 Audi S4 Widebody, GTX2867R, R32 GTR diff, DSS axles, dog box, caged, e98) couple of hours on the dyno. AiM Power Distribution Module + AiM 10" dash + 12 button canbus keypad.
    6)
    MaxxEcu is an extensive engine management system, in my case thee biggest change possible, going from narrowband maf to wideband map, all plug and play. You use a bluetooth tablet to run an Android app called MDash giving you live data, and a laptop to change values. Laptop must be tangibly plugged into the car via a supplied USB to change values, no bt.
    Website: https://www.maxxecu.com/
    You Tube: https://youtu.be/OK3PIEB1YWE
    Update 7-1-2020: Car related tablets/laptop
    For a digital dash read out I went: Dragon Touch Notepad K10 10" ($89)
    For a mini laptop, for it's sole purpose for tuning went: Asus EEE 1001PX 10" ($75)
    Update 7-15-20
    FITTING YOUR MAXX ECU INTO ECU BOX INFO
    Per a stock ecu box, the provided picture is the only layout that works, even down to the way the Maxx harness lays.
    Shoving the Maxxecu plug through the car to have the ecu housed inside the cabin: Not ~possible currently, with out major cutting to enlarge the hole, unless you installed it during a full tear down and could get behind and under the dash rats nest to place the brain before the stock wiring is there. Even enlarging the ecu hole, there's no way to clip that connector to the Maxx ecu brain as the rats nest is there.
    I enlarged the ecu box hole, it was still difficult to get the connector through because just below the hole lays a ~5" long strip of electrical box connectors. The problem is there's not enough pig tail to drop the brain connector down the hole to reach past the inside rats nest to clip it onto the brain.
    But, I had a modified ecu box with a corner missing as I have control arm strut tower boxes welded in and wouldn't fit...I re plastic welded it days ago to see by sheer chance it'd fit into the ecu box...if it didn't...I would of had to lengthen the entire harness out ~18" so I could mount it under the pedals..but by the skin of my chiny chin chin it JUST fits. Funny, as the Maxxecu acutely pokes out and above the ecu box, yet the lid has a ~deep roof which allows for more space.
    7-17-20 Current issues: TBA Error (right outta the box). Mechincal tb/tps.
    TB closed butterfly value: .009%
    TB open butterfly value: .009%
    Throttle pedal position value: Flickers as fast as possible between 0% to 100% back and forth
    No change in values operating the pedal
    However! TB is recieving ~5v measured at the plug, tried a second tb same results, before Maxx car started and drove into the garage just fine on a flashed OEM ECU. After the errors, I reinstated the OEM ecu, no tb errors, proper voltage, and tba came out perfect on VCDS vagcom. Reinstalled Maxx, all the same issues.
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    1) What Android unit shall I source?
    I am using a generic Samsung Galaxy 8" tablet. Its held to my windshield via a suction mount. I have it hooked up to power in the car so it stays charged. I have the tablet setup so I can monitor any information from the car. Its also setup to swap boost maps, turn on anti lag, and other misc settings. A tablet or any other android unit is a must to be able to read error codes and clear them.
    2) For tuning tablet vs mini-lap top, what shall I look for?
    I highly recommend picking up a laptop for tuning. I personally just use my gaming computer. I have to pull over to use edit the tune so size doesnt really matter. I dont store my computer in the car. If its tuned right then you shouldnt need to store a computer in the car. I think this comes down to personal preference more than anything.
    3) Helpful advice from long time user
    When installing I recommend putting the ECU above the kick panel area (b5 s4). Its a tight squeeze but the wires can make it up through the ecu box from inside the cabin. Join the FB groups because there are a lot of knowledgeable people there. This ECU is as complicated or as simple as you want it to be. The deeper your build, the deeper you can go into utilizing everything this ECU offers. From traction control to individual egts and widebands. The base file is exactly what its called... a base file. It is meant to get the car started and ready for tuning. Its not meant for going out and ripping on things. If the car doesnt run perfect on the start up, dont fret, contact a tuner (not me). Im happy to help as much as I can! let me know if there are any other questions I can address.
    Aug 25 2013
    any recommended vendors to purchase this from?
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by narth327 View Post
    I know Blake has em on his site but for whatever reason it’s more expensive than msrp that Max’s list on their site, so I’d reach out to Max and see if you can purchase straight from them
    Feb 28 2005
    Tempe
    Where to buy & answers:
    I recieved a qoute straight from Maxxecu before I was ready to buy, their qoute was higher then their advertising price, after insurance, shipping, and exchange rate (maybe) the price increases a bit. However! When I inquired again ready to buy, also wanted a longer main harness made, they informed me they no longer ship to the US and to go through a US dealer:
    The main guy appears to be (where I bought mine):
    Aussie Imports, Steve Nichols, 1-859-983-4966
    US dealer directory
    Alamo Autosports
    Brice +001-(817)-860-4300
    ANCLA INC
    Andres (Andy) Lamus +001 786 264 1706
    Aussie Imports LLCDistributor
    Steve Nichols +001 859 983 4966
    Auto Authority
    Rafael Fuentes +001-(203)-752-0683
    DAS Performance
    Eric Paquette +001-(978)-453-0807
    DME Racing
    Andy Sawyer +001 336 785 4845
    DUDMD Tuning
    Dmitriy G +001 253 315 1515
    European Tuning Specialists
    Blake Beadle +001 619 438 0289
    Exoticycle Motorsports, Inc.
    Johnny Dorbin +001 941 360 3278
    Fast Enough Performance
    Chris Kopitzke +001 859 258 2015
    Great Lakes Racecraft
    Andy Leslie +001 616 325 5571
    Leash Electronics
    Randy Westmoreland +001 501 515 1693
    LPS FAB
    Justin Linder +001-(509)-308-3146
    Motorcycle Performance Specialties, Inc.
    Dan Rudd +001 321 972 8282
    Odum Specialties
    Rick Odum +001 618 695 9400
    Pito Tuning Performance
    Pure Power Performance
    Harvey Grissett +001 (803)-731-5993
    RC Performance
    +001-(910)-276-4942
    SCHNELL ENGINEERING
    +001 6474788121
    ShorTuning
    James Short +001-(859)-583-8948
    Stotz Racing
    Kent Stotz +001 847 352 9292
    Willettrun Automotive LLC
    Brett Willet +001 409209 9659
    Win Racing
    Brian +001-(630)-978-8856
    Xtreme Motorsports
    Allan Abrams +001-(251)-209-3030
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Quote Originally Posted by mikeb17 View Post
    How did you manage to fit the connectors through the slim opening of the ecu box, assuming the opening for the S4 is the same for the A4.
    1998.5 A4 1.8TQM My Build
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    I have modified the ECU box. I added the "extra" corner, then the ECU and PnP adapter fits inside.
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    How are you guys enjoying the MaxxEcu so far, I'm seriously debating on getting this for my B5 A4 project.
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by aaronamerica View Post
    Have you looked into the Ignitron? Seems really popular for the 1.8T guys.
    http://www.ignitronecu.com/
    Check out their FB page it has tons of good info in there plus the developer is on there often answering any questions.
    Once they have everything for the 2.7T running smoothly that’s what I plan on running, for the price, support, and options I feel like it’s the best deal.
    Jul 05 2016
    Bloomfield NY
    Can add me to the list! I just ordered one
    Sent from my SM-N986U1 using Audizine Forum mobile app
    Junior Member One Ring
    Oct 09 2008
    New England
    Got mine.
    Quote Originally Posted by A1 A2 German View Post
    Same, I got mine from Steve. He's in Kentucky I think.
    Do we have an archive setup for basic config settings yet?
    Oct 09 2008
    New England
    crickets...
    Veteran Member Four Rings B5carl's Avatar
    Apr 29 2017
    2001 A4 1.8t AWM 5-speed Quattro(SOLD)
    Boston, MA
    Subscribed. I'm gonna be using this sometime in the near future on my 1.8t
    Feb 28 2005
    Tempe
    I can share base files for my 1.8t, the base was supplied live remote tuning via remote access per my laptop by Steve Nichols.
    Currently up and driving.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by qu4ttro_drew View Post
    crickets...
    The Base map for 2.7T is included with Mtune - just load it up if you're using their plug in solution.
    Feb 28 2005
    Tempe
    Quote Originally Posted by NOTORIOUS VR View Post
    Clarification on my part, Steve went a little more in depth on mine, above the above statement holds trues with just about every motor/combo. Every person should be able to tangibly install it and drive per picking which file/blend/combo of goodies you have with pre-written files.
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    I’m actually debating going stand-alone. However I was looking at ecu master. Does this offering work better with our cars?
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Jan 29 2009
    Quote Originally Posted by hibiscusS4 View Post
    Maxx is miles better than ECUMaster in just about every regard.
    Sep 09 2013
    That is good to know. Do we know if Max ecu has the potential to work with the oem cluster?
    00 allroad pj ko4
    Feb 28 2005
    Tempe
    The cluster, Vagcom and cels work perfectly.
    I use a tablet as it tells me everything, plus more, which allowed me to remove all kinds of previously installed hardware like my boost guage, L2 Innovative Wideband, shift light set up, etc...as this is all of that. It was kinda nice to pull 50 yards of wiring and gizmos out from under the dash. You don't need to do anything to make the oem cluster to work, it's automatic, you also do not need a tablet up and running to drive.
    Sep 09 2013
    Wow! That sounds really nice. This is important to me because the car still needs to pass emissions and I’m assuming max ecu can’t help me with that.
    So keeping the cluster and having that adapter harness is key for putting the oem ecu back in.
    00 allroad pj ko4
    Jan 29 2009
    ^^ Correct, standalone ECU's will not have or set necessary PID's for the OBD protocols - so no emissions compliance. This is the case for any standalone.
    Someone recently even made the OEM (euro) IMMO work with the MaxxECU - so OEM keys, cluster, etc.
    The flexibility of the Maxx is very impressive - if there is something you want to do that it can't do you're able to do it yourself if you like.
    Nov 13 2018
    Ocean city NJ
    I’m pretty sure with the Ignitron ECU, after its configured, passing inspection is possible.
    Jan 29 2009
    Quote Originally Posted by Silverex View Post
    That would be ballsy on their part - I'm sure the EPA would have a field day with them if they allowed that.
    May 10 2018
    MA
    Passing inspection is all down to how you wire it in. Wiring things in parallel should keep things happy. As a full standalone, probably not. But you're also coming to a point of age in the car where many of those inspections wouldn't be required in many states too. All depends where you live
    Nov 13 2018
    Ocean city NJ
    Yea EPA has been going nuts recently, even to small companies. Hopefully they wake up and realize sometimes these products are actually helping the environment.
    FWIW Ignitron doesn’t advertise it being able to and has the typical disclaimers. I found out from a user and was told you would have to configure it, so not like they ship them out like that. End user would have to make the adjustments
    Does make me wonder why Cobb doesn’t get hassled with selling a similar product like their Accessport? That’s a pretty big company with lots of $$$ to go after.
    Feb 28 2005
    Tempe
    Per the above content:
    With 100% fully running MaxxEcu, the transition back to ~oem spec is..........~25 mins.
    Bare in mind that's ME, being the largest conversion possible going from narrow band maf to wideband map...so I'm converting back to narrow band ecu's and a slap on maf housing intakes (along with the normal, injector swap to normal sized, ~oem ecu, etc). Aka, my swap back to and from MaxxEcu involves more work (yet still nominal).
    In other words, at 1 p.m. you could drive into your garage being ~oem, swap in Max, drive, pull back and reinstall oem....all before 2 p.m. I did this to work out a couple bugs, as I knew my oem setup was dialed in.
    EDIT: I want to be clear, if starting from 100% scratch it may take you ~2hrs to install Max the first time (they give you ~wideband raw 02 pigtails to make custom length harnesses) and you need to find a vacuum source for the Max brain. However, if already there the first time, it take very little effort to swap back and forth as the little things are done.
    Sep 09 2013
    Ya this makes a lot of sense. My idea would be to get a base map on my hardware when it’s done and dial it into a good pump tune.
    My real reason for wanting to go stand alone is due to wanting to run e85 on a flex fuel setup so I don’t have to worry about map switching or fuel content. Now being so close to the emissions cut off I might just wait and switch once I don’t have to worry about it.
    00 allroad pj ko4
    Jan 29 2009
    Pretty sure they have gone after all the big guys like Cobb, APR, Hondata, etc. Actually I've seen cases of the EPA going after the resellers of Hondata and the like and not just Hondata itself!
    Nov 13 2018
    Ocean city NJ
    Yea I saw that PFI got sued but pretty sure they don’t even know why yet. Hopefully RPM act gets passed and the epa chills out some.
    Jan 29 2009
    That would be good for everyone for sure!
    Oct 09 2008
    New England
    That would be great...
    - - - Updated - - -
    vwms16v(at)gmail(dot)com
    Sep 11 2009
    NE
    Does the software/ECU support NWS (equivalent of vanos/vvti)?
    Jan 11 2007
    Salt Lake City, Utah
    Quote Originally Posted by julex View Post
    You thinking of going MaxxECU? Still have the allroad?
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Sep 11 2009
    NE
    Quote Originally Posted by jibberjive View Post
    Yup and yup
    Jan 29 2009
    yes on/off style (like on the 2.7T) and fully closed loop VVT as well
    May 31 2005
    Dallas
    Finally got the maxxecu race plugin installed in my b5 A4 big turbo e85 setup, I had issues with tps as well but that was resolved by getting the voltage to it. The issue I have now is I can't get the car to start up.
    Veteran Member Four Rings rockcandy's Avatar
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Just to throw my name in the hat. I put the maxxecu in my car and it’s running on wastegate at 20psi. I’ll keep an eye on this thread or add if I can.
    B8 S4 owner who's lost his mind building his car. Come join me!
    Jan 29 2009
    That's pretty vague - that said contact who you purchased the Maxx from - all distributors are required to support you directly with technical issues
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Bumping this up, has anyone purchased a longer USB cable for the ECU so you can have the ECU in the factory location and laptop in the car?
    Sent from my LG-H931 using Tapatalk
