Originally Posted by
jd_rs3
Are you positive it is the heat shield? I assume so, since it is making a mark. I recently installed the IE catted DP and there was plenty of clearance. We experienced a similar noise and assumed heat shields, but it ended up being the 2 forward subframe bolts that mount to the steering rack that needed torqued again. So make sure all of those bolts are torqued *again*. Beyond that, pics could help and maybe some others have suggestions. If the heat shields are bent where they should be, they should not be making contact. Is the noise worse when you are turning?
Got it all figured out. Took it to my local exhaust shop and they adjusted the pipes and cat to the correct spots which resulted in more clearance which leaves the heat shield lower and problem solved. I currently have another problem now which is throwing these codes.
When I go and delete the codes the only one that stays is this one until i turn the car on again and the rest pop up again.
Even after I replaced the rear oxygen sensor and harness extension. Reason for replacing is because they were routed wrong and got extreme heat from the downpipe. Have new ones in place and still having problems with codes coming up. Really don’t want to take it to audi and have them make a big deal about it since it is aftermarket. If anyone can help or give me an idea of what it might be I’d appreciate it.
Sent from my iPhone using
Audizine
