    Nov 03 2019
    Unknown fault via ODB Eleven Pro
    Hello,
    I made an scan with odb11 pro and It found 3 unknown faults.
    Can’t be deleted yet via ODB11.
    Any ideas how proceed ? Thanks
    See attached picture
    Dec 25 2004
    Earth
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    Here is my personal experience with OBDeleven. Good for basic easy coding, but terrible technical support. When I have questions, the manufacturer just tell me to check their user forum and many questions in the forum are left unanswered.
    Nov 17 2014
    San Francisco, CA
    You cant remove it if red, it's green so it's not a permanent issue.
    It's most likely a long coding issue and the databus is expecting to talk to a module that isn't there.
    Factory usually doesn't code these cars very accurately. This doesn't mean you should just start changing things at random though.
    Sent from my Pixel 3 XL using Tapatalk
    Nov 03 2019
    I made all other scan and three faults were received again. This time I was able to delete them.
    I don’t know but know is solved.
    Thanks !
